Something a bit unusual - a steam railmotor
Re: Something a bit unusual - a steam railmotor
A real masterpiece, beautifully designed and superbly constructed, I love it!
Exquisite workmanship. A real beauty.
I couldn't agree more - and what a wonderful colour!
Peter Butler wrote: ↑Sun Apr 04, 2021 11:00 pm A real masterpiece, beautifully designed and superbly constructed, I love it!
What more need I say .......
I can't find an emoji for drooling, so just use your imagination .......
Once again thank you all for the kind comments. I've almost caught up with where I am at the moment so the reports might slow down a bit after that ! Next time the lining
Brian
Where did the last three weeks go ?
Here is the next stage, firstly the brass panel made to cover the hole in the roof with hole for the chimney/safety valve.
Next a shot of the roof covered with a piece of fabric from an old shirt.
And a close up of the roof painted. It was just sprayed with grey primer and rubbed down lightly to remove some small blobs (it was an old tin !). Quite pleased with the texture of it and the way you can still get an impression of the planks underneath.
Finally the lining completed and the roof fully painted. The lining wasn't quite as perfect as I'd hoped but after a bit of tidying up it looks good under the 6ft rule. Maybe even get away with 3ft ! Originally I wanted gold lining but when I tried it it wouldn't go on nicely and surprisingly didn't show up very well so I started again and found another colour from Humbrol which I think looks ok. I'd also started varnishing the interior by this stage.
Brian
Beautifully lined, a very steady hand at work there. I find that high gloss paint and strong light can be cruel sometimes, so finish my carriages with Halfords Satin Lacquer, which gives a lovely smooth top coat with no reflections.
I have tried (and failed) to find an alternative, on-line supplier, so Halfords is the only one I know.
That paint job is superb and you have nothing to be ashamed of there. The lining is as good as the rest of it.
I agree with Peter about flattening the gloss finish, though.
Beautiful!
I love the lining...
I like a satin finish myself but with all the different types of paint I'm just a little bit nervous about spraying something over the top after a nasty experience with my Roundhouse Garratt. I spent hours lining it and was very happy with the result. I started to spray it with satin varnish, Humbrol I think, and the lining paint immediately started to bubble up. I had to remove it all and start again. I'm not anxious to repeat that ! I suppose I could paint and line a test piece and try the Halfords lacquer on that.
Brian
Totally understand what you say.
I think the Halfords stuff is Acrylic and that should be OK over most paints - but don't quote me!!!
Halfords offer Clear Lacquer (high gloss), Satin and Matt Lacquer (does what it says on the tin!) but only the clear has the description of being acrylic. However, they are all similarly presented and the satin can says.... 'converts all original paint to a satin finish'. It works for me.
I love the Steam Railmotor Peter. I saw the Stg replica on the Bodmin line and was planning a ride. Unfortunately it developed a fault and I missed my chance just got a photo of it in the shed.
On the Lining a friend who is a professional painter of 0 gauge locos uses a straw colour rather than gold paint because the end result looks better. Another friend who works in 2mm sometimes casts things like safety valves in gold as it doesn't tarnish like brass ( he does work in dentistry so is equipped to cast gold).
Don
Don
