Festiniog Railway Welsh Pony - 3 D printed
Re: Festiniog Railway Welsh Pony - 3 D printed
The modification:
I might modify the spool holder to make it fit better with the door on.
And now on to the bodywork. I am making the footplate handrails on the resin printer. Just to see it they work. These are to scale and therefor look rather delicate. However the other things I have made out of resin seem very resilient. In fact I think connecting rods made out of resin will be too flexible rather than too brittle.
So if these fail i can beef them up:
Very impressed by the new boiler parts. I've not tried printing things vertically like this. My cheapo printer certainly couldn't handle it as there's too much X and Y slop which gives any parts a corrugated look. I think my other printer might cope better, though - but it's got a large printbed (300 x 300), so I wonder if that might cause it to have a bit more give than your printer with its smaller bed. I'll have to give my larger printer a try on something tall.
- -steves-
I print roof's vertically on my Ender 5 and, the last one was 225mm high, but it printed greatge_rik wrote: βThu Jan 21, 2021 12:01 pm Very impressed by the new boiler parts. I've not tried printing things vertically like this. My cheapo printer certainly couldn't handle it as there's too much X and Y slop which gives any parts a corrugated look. I think my other printer might cope better, though - but it's got a large printbed (300 x 300), so I wonder if that might cause it to have a bit more give than your printer with its smaller bed. I'll have to give my larger printer a try on something tall.
I think that the issue is printing in ABS. It is a very unforgiving material to print with. I have had problems doing roofs as well. Probably I should use one of my spare nozzles and get PLA for printing roofs and the like.
That is a superb 3d print of your boiler Trevor, very impressed with it.
Don't think I could attempt to be cutting any holes in mine though mate. Anne would be so upset and I don't like doing that for fear of reprisals...
- -steves-
Wouldn't be a bad shout, PLA is much more forgiving for roof's, not sure I could print an ABS roofTrevor Thompson wrote: βThu Jan 21, 2021 7:35 pm I think that the issue is printing in ABS. It is a very unforgiving material to print with. I have had problems doing roofs as well. Probably I should use one of my spare nozzles and get PLA for printing roofs and the like.
- Attachments
- Printing in PLA
- IMG_20210122_074228.jpg (1.81 MiB) Viewed 6130 times
I have most of the model ready to assemble - but I am not satisfied with the gears I have used to provide the drive.
They are rather noisy, perhaps this is the problem with cheap plastic gears.
Anyway the chassis as it stands:
It does run, but it makes an un-prototypical racket!
I have taken to fine tuning my wheels in the lathe. Mounting them on a mandril allows me to turn the tread to exactly the same diameter on each wheel, and clean up the flanges as well. It seems to overcome the occasional problems I was having getting printed wheels to run true. Note that the number of skin layers and infil density I am using is making these almost solid. They seem to turn as if they were solid material!
It is about time I cleaned and oiled the lathe!
I have also started to assemble the tender:
You can also see the connecting rods, coupling rods and slide bars ready to attach to the chassis in the background.
I am making a copy of all the components (after I successfully assemble each section) with a view to offering the locomotive as a kit of parts in the for sale section of this forum when I have it completed.
I am currently awaiting a tool to enable me to make my own worms and worm wheels from brass - which I think will solve the noisy gear issue!
- -steves-
Looking very good so far Trevor, can't wait to see it complete.
Coming along nicely, Trevor.
I must try printing a roof, Steve, I've fought shy of it up until now.
Just had to replace the nozzle on my cheapo printer - my first major clog. Decided it was to gummed up to manage to clean it up properly. I suppose, after nearly a year, that's not bad.
- -steves-
Honestly, an upright roof comes out well. If in any doubt you can add a 1mm or 2mm wide support each side that just touches the roof, careful though, if the touching point is too small, it will just build separate structures, ask me how I know, lol.ge_rik wrote: βFri Jan 29, 2021 1:41 pm Coming along nicely, Trevor.
As for nozzles, I replace mine most times it clogs. If upping the heat doesn't clear it, then it gets replaced there and then.
Trevor will know this one, I assume ABS doesn't clog in the same way as I printed ABS at 205 degrees by accident and although it didn't stick to the base board, it did leave an almighty mess of ABS all over the place overnight, lol.
That is looking very good Trevor.
I assume the tender body is printed as 3 separate sides with the insides flat on the bed? The external surface finish looks excellent from what I can see.
I haven't had to replace a nozzle since I started using ABS exclusively.
Yes the tender was printed as 3 sides, a curved top, a base upside down on the bed, and two axle box sets. Tha axle boxes are joined by a stretcher so there is one print per side. I did think about making the springs work - but maybe next time!
The other comment I would make is that the quality of the surface of the prints is very good - probably the best I have ever had. The only difference is the supply of filament. I have been getting it direct from a company called PolyProps via their website.
I have made my own brass worm wheel and stainless worm which I hope will be much more suitable for this model. " Free hobing " the worm wheel using an M8 spiral flute tap:
Of course to fit its I had to disassemble the existing wheels which had been secured to the axles with foaming polyurethane glue. Initially I couldn't move them on the shaft and thought I was going to have to make new wheels. After applying heat from a soldering iron onto the ends of the axles they came free quite easily. So the wheels are re-usable. I have put it back together with the new worm wheel and re quartered the wheels:
I will try it in the morning when the glue has cured.
Beyond me I'm afraid but it certainly looks most impressive and I'm full of envy.Trevor Thompson wrote: βFri Feb 05, 2021 6:12 pm " Free hobing " the worm wheel using an M8 spiral flute tap:
Wow!!! This must be a first for the forum. Home made gears.....
