What's the smallest point for 16mm industrials
Simon-m
Post by Simon-m » Tue Aug 25, 2020 7:35 pm
I'm looking at possibly making a micro / cameo layout & I would like to know how small a turnout can be made.
The locos will only be small simplex & ruston diesels so nothing to make the turnouts need to be big.
I've looked on templot for 16mm track but the track library doesnt have no 16mm track so I'm a bit lost.
Has anyone got any experience building small turnouts?
BorisSpencer
Re: What's the smallest point for 16mm industrials
Post by BorisSpencer » Tue Aug 25, 2020 11:22 pm
I've never made my own track work, but I have used Faller track and points on a small indoor running circuit.
You could always test your locos on a Faller point and then use it as a template to make your own.
Post by GTB » Wed Aug 26, 2020 5:13 am
Simon-m wrote: Tue Aug 25, 2020 7:35 pm I'm looking at possibly making a micro / cameo layout & I would like to know how small a turnout can be made.
The smallest radius prefab conventional turnout that Hudsons sold for 2’ gauge industrial use scales out at about 4’ radius in SM32.
Mamod/MSS turnouts are 2'6” radius, which is probably as small as they come commercially in SM32.......
The 16mm Assoc. website has templates for making 2’6” radius turnouts that can be printed out full size. Look under the 'resources' menu, in 'track drawings'.
Much smaller than that and you'd be looking at things like stub turnouts, or quarry type turnouts with single blades and no v-crossing.
gregh
Post by gregh » Wed Aug 26, 2020 6:20 am
in 45mm gauge I have built nominal 12" radius semicircle track and points. They can be negotiated by locos and wagons with 120mm axle spacings.
here's a video of a special rotating turnout I built.
Greg from downunder.
Post by Lonsdaler » Sat Aug 29, 2020 3:27 pm
gregh wrote: Wed Aug 26, 2020 6:20 am in 45mm gauge I have built nominal 12" radius semicircle track and points. They can be negotiated by locos and wagons with 120mm axle spacings.
That's very neat Greg. Did you ever incorporate it into a layout?
Post by Old Man Aaron » Sun Aug 30, 2020 3:07 am
Lot of interesting possibilities there.
gregh
Post by gregh » Sun Aug 30, 2020 8:27 am
Lonsdaler wrote: Sat Aug 29, 2020 3:27 pm That's very neat Greg. Did you ever incorporate it into a layout?
No, not yet. Other life problems have got in the way.
This video is related.
Simon-m
Post by Simon-m » Wed Sep 02, 2020 7:39 am
Gregh
That video is very interesting regarding the radius on which your models work.
I wonder if my ip simplex could negotiate a 1ft radius curve? I have a 5x2ft board I was going to butcher for a small cameo layout. I'm now wondering if it could be used with a radius curve for a hidden siding & expand on the original track design.
