Ringbalin Light Railway
- GAP
Re: Ringbalin Light Railway
Column Mountain construction continues.
The foam shell has been coated with Acrylic House Render coloured with an oxide, this is the same as what I used on the G Division to make a couple of banks.
https://ringbalin-light-railway.blogspo ... -make.html
Blog has been updated with pictures;
https://ringbalin.blogspot.com/2021/01/ ... -spur.html
Looks like you're making good progress indoors and out. Interesting to see you can use the same approach for both.
- GAP
Column Mountain is now complete.
- GAP
My next project is to turn this LGB 0-60- on the right Into something that resembles the Australian sugar cane diesel on the left.
This loco was always destined to be converted ever since it was bought.
It is not intended to be an exact copy but a representation of a sugar cane diesel.
There is a bit of scratch-building involved to change it from a US outline to something more Australian
Pictures, as always, will be posted as progress continues, plus the blog will eventually be updated as well.
Looks like progress is coming along well on both layouts. I struggle to keep going with just one. I've not touched my indoor layout for years....
- GAP
I have updated my blog page for the Stainz to Cane tank engine build.
https://ringbalin-light-railway.blogspo ... tainz.html
and my whole stick wagons
https://ringbalin-light-railway.blogspo ... agons.html
I am now calling them finished.
- GAP
Rik,
I have the advantage of living in a hot climate which drives me indoors (into the shed) during the middle of the day.
At 32C most days it is just way to hot and humid to be outside unless I am in the pool.
Once the cooler weather comes work will start on the large scale layout again, neighbours wouldn't appreciate if I started cutting steel/timber etc at 0530 plus it is not allowed till after 0700 anyway.
So I just sit in a shady spot, look at it and come up with all sorts of ideas of what to do next.
I have even sorted out how to take videos on a camera, just need to figure out how to get them online.
Not having too many problems with excess heat over here at the moment In fact, my 3D printer refuses to work if the temperature in the workshop is 5C or less which seems to be every other day at the moment I hate to think what my electricity bill is going to look like this winter
Anyhow, hoping to see a video of your trains in action sometime soon. I just upload mine to YouTube.
HO layout's coming on well, as is the 45mm. Haven't touched my indoor stuff in a long time either; in fact, it's all packed away..
After seeing the superb job you've made of the Stainz, I'm looking forward to seeing what you make of the diesel.
- GAP
I have just repainted and modified an LGB 20630 US side rod diesel into an Australian sugar cane loco.
The changes involved a repaint, removing all the US coupling stuff off the buffer beam, adding a new exhaust pipe and rearranging the horn and air cleaners.
Pictures of what it looked like before I started and what it looks like now.
Now all that is left is to weather it some more to make it look like it has been out in the paddocks.
Very nice, and quite a transformation! I particularly like the red cranks and rods...
- GAP
Thanks
Red counterweights and rods are fairly standard on most cane locos in Aust.
- gregh
Looks a whole lot better in yellow. Amazing what a difference a coat of paint makes. Well done.
Greg from downunder.
- GAP
Thanks Greg,
Wait till you see what it looks like after I went mad with the weathering, its now a black over yellow.
The yellow was just way to dazzling in real life so I toned it down a few notches.
- GAP
I initially went a bit heavy handed with the weathering so I toned it down a bit.
Picture shows how it is now including the 2 aircon units on the back buffer beam.
Possibly a little more toning down is required.
Looks right at home in the canefields. I've also found yellow difficult to weather, for the same reason. Quite like the squat appearance of the loco, it's reminiscent of the locos working the Redlynch line.
- GAP
I grew up just south of Redlynch (North Cairns) and that was a common occurrence everytime it rained and Freshwater creek filled up.
The locos on that line had specially lowered cabins so they could fit under the Kuranda/Tableland line they were originally from Hambledon mill at Edmonton if I remember correctly, later they went to Mulgrave when the Edmonton mill closed and the land was turned into sub divisions.
Living next to the Kuranda line is what started my love of steam engines as they ran right past our back fence and the drivers/firemen used to give us a wave and a toot.
When they got rid of the steamers the diesel electrics could not go through the water and the Kuranda run was cancelled till it went down.
Ahh the good old days, life was good in the 1960s/70s in North Queensland.
- gregh
Not sure I can give the weathering a thumbs up. But it's your loco.
- GAP
I did go overboard with the weathering I did not dilute the wash enough.
The wash was actually drying as soon as I painted it because the shed was so hot (about 38C).
I am planning to wipe a lot more of the wash off, the shown result was after I had removed some already, think that a less is more approach is needed in future.
I will put the Stainz conversion next to this one and copy the amount of weathering.
- GAP
I have been busy the last 2 days updating my blog to show the state of the railway at this point in time.
Added are descriptions of my locos and some rolling stock, this is in addition to the posts about the cane line feel free to have a look around.
