Best source for styrene (HIPS) sheet?
Post by ge_rik » Fri Feb 01, 2019 2:21 pm
I know this has come up before, but after searching the forum for a good while, I've not found an answer.
I'm after some A3 sheets of white styrene (1mm, 1.5mm and 2mm thick) as my stocks are running low. I can't remember where I got my last supplies from but I know it was reasonably inexpensive. Searching on eBay seems to unearth sources at what I consider to be silly prices - either that or only A4 sized.
Anyone know of a decent source of supply?
Re: Best source for styrene (HIPS) sheet?
Post by philipy » Fri Feb 01, 2019 2:32 pm
Rik,
I've got my last couple of purchases from www.homecrafts.co.uk/high-impact-polystyrene-sheets. They do large sheets, which aren't always easy to come by, and a range of colours, although white uis often out of stock in my experience.
Post by ge_rik » Fri Feb 01, 2019 2:44 pm
philipy wrote: Fri Feb 01, 2019 2:32 pm Rik,
Thanks Philip
Looks promising
Post by Peter Butler » Fri Feb 01, 2019 3:14 pm
Homecrafts are my preferred supplier too and offer free delivery above £40.00 (if I remember correctly?) which is easily achieved when buying several of the thicker sheets. Packing is always first class and delivery prompt.
Post by ge_rik » Fri Feb 01, 2019 3:23 pm
Peter Butler wrote: Fri Feb 01, 2019 3:14 pm Homecrafts are my preferred supplier too and offer free delivery above £40.00 (if I remember correctly?) which is easily achieved when buying several of the thicker sheets. Packing is always first class and delivery prompt.
With that endorsement, I feel confident they are likely to be the best.
FBGR
Post by FBGR » Sat Feb 02, 2019 8:16 am
The sheet size of 915 x 610 mm is almost bigger than my workbench.
I get my ‘plasticard’, in A3 sheets from https://www.stationroadbaseboards.co.uk ... lastic.htm
I don’t usually spend more than about £30 an order (including postage), and you can get quite a lot for this sum.
J0hn
The world's going to end very soon --- so I'd better try to get something finished by then
Post by ge_rik » Sat Feb 02, 2019 10:23 am
FBGR wrote: Sat Feb 02, 2019 8:16 am The sheet size of 915 x 610 mm is almost bigger than my workbench.
J0hn
Thanks John
Another good source
Post by -steves- » Sun Feb 03, 2019 2:44 pm
I always found good cheap A4 sheets on eBay, not sure about A3, never looked.
