Other Gauge Stuff
Other Gauge Stuff
Post by FWLR » Fri Dec 07, 2018 9:37 am
While I was looking on a shopping site for middle Daughters Craft Site. I came across this. If I was doing OO gauge model rail I would have bought this. They do have others also.
https://www.etsy.com/uk/listing/5373625 ... ro=1&frs=1
What do other members think....
Re: Other Gauge Stuff
Post by philipy » Fri Dec 07, 2018 10:48 am
They loook good at first glance but when you look more closely they are very flat. i.e, no flanges and no angles to girders, no bolt/rivet or reinforcing plate detail, etc. Some of it could be added subsequently I guess, but would need quite a bit of work to make them look anything much.
It seems to be a war diorama site, so they would probably be OK as back ground scenics to blown up tanks or whatever.
BorisSpencer
Post by BorisSpencer » Fri Dec 07, 2018 11:20 am
They certainly seem reasonably priced for the amount of laser-cutting involved.
I am currently working on a cunning plan to resurrect some of my 00 stuff, it's been languishing in the loft (several different ones) for nearly 40 years.
Post by bazzer42 » Sat Dec 08, 2018 9:56 pm
They do look very cheap for the bridge you get but being flat as Philip said they're probably best suited to a larger layout where the lack of detail may be less noticeable.
