It is a mix of sharp sand and cement in the ratio 4:1. There is no budgie grit in it - the sharp sand used has some grit in it already. The sand is Kelkay build mate sharp sand and was picked up at my local garden centre.
Wadebridge Light Railway
- steamgeorge
Re: Wadebridge Light Railway
Thanks. Must see what sort of sand they have at our local garden centre. I usually buy a bulk bag of builders' sand which is fairly uniform an uninteresting when mixed with cement.steamgeorge wrote: ↑Sun Oct 14, 2018 3:27 pm
I agree the halt is looking good. I do have a soft spot for halts in general.ge_rik wrote: ↑Sun Oct 14, 2018 3:32 pmThanks. Must see what sort of sand they have at our local garden centre. I usually buy a bulk bag of builders' sand which is fairly uniform an uninteresting when mixed with cement.steamgeorge wrote: ↑Sun Oct 14, 2018 3:27 pm
Rik, I always get sharp sand in 20(?)Kg bags from Wickes, B&Q, etc. I should think you'd get it from your builders merchants as well.
- steamgeorge
Hi all,
I have reached a dilemma over coach livery . I picked up some unfinished IP engineering roundhouse coaches second hand and I am currently painting them in WDLR livery. I know what colours to use but I don't know what pattern to use. I have been experimenting with the coach colours and would like your opinions and suggestions to help me. There are some photos of 2 coaches and some of my other coaches. The new coaches don't have to match my existing ones as they won't be in the same train due to the size difference. I have lettered the liveries to make referencing them easier. The livery is green lower half and a white upper half but they could be painted all green if it suites
George
George
- Attachments
- This livery matches the talyllyn coach but I think the green is too low and makes the coaches look out of proportion. (Livery B)
- IMG_20181014_213206231.jpeg (109.01 KiB) Viewed 5813 times
- close up of the livery
- IMG_20181014_213055322.jpeg (148.72 KiB) Viewed 5813 times
- This is the livery I thought suited the ip engineering roundhouse coaches the best. (livery A)
- IMG_20181014_213113078_HDR.jpeg (173.36 KiB) Viewed 5813 times
- This is one of my original coaches. They would all of been painted this way if they would of had small panels above and below the windows that could of been painted white ( it looks wrong without)
- IMG_20181014_213151611.jpeg (104.84 KiB) Viewed 5813 times
- This is a Talyllyn coach I built from a kit but painted in my livery.
- IMG_20181014_213135313.jpeg (112.45 KiB) Viewed 5813 times
The IP Roundhouse coaches are not the easiest to paint. I have two of them and had been looking out for more for ages to extend my rake. Mine are painted red and cream. I think I have posted pictures of them somewhere! If I can't find the location to post a link I'll take some pictures if interested.
George, could you not go up to the bottom of the windows with the green and see how it looks then.
I think it could be because the IP are two compartment and they look compressed compared to your other coaches.
If by painting with the green to the bottom of the windows doesn’t look right, you can always re-paint again. Annoying I know, but until you try it…………
- steamgeorge
Like this...FWLR wrote: ↑Mon Oct 15, 2018 8:49 am George, could you not go up to the bottom of the windows with the green and see how it looks then.
- Attachments
- Imagine the colour was consistent (this is for mock ups only)
- IMG_20181016_220246396.jpeg (133.1 KiB) Viewed 5641 times
- steamgeorge
I would be very interested to see those coachesIanC wrote: ↑Sun Oct 14, 2018 10:56 pm The IP Roundhouse coaches are not the easiest to paint. I have two of them and had been looking out for more for ages to extend my rake. Mine are painted red and cream. I think I have posted pictures of them somewhere! If I can't find the location to post a link I'll take some pictures if interested.
George
George,
I will be running them this weekend so I'll take some pictures for you. I did find the ones I took, but they were taken before completion. I'll post them over the weekend.
- steamgeorge
That would be brilliant, thanks
Well it looks better, don’t you think.steamgeorge wrote: ↑Tue Oct 16, 2018 10:08 pmLike this...FWLR wrote: ↑Mon Oct 15, 2018 8:49 am George, could you not go up to the bottom of the windows with the green and see how it looks then.
Tricky without those upper panels, isn't it?
Personally I think Option B's best - although I'd be tempted to try it with the black bits in green - even the small amount of cream seems to be enough to say "two-tone livery"...
Good luck,
Good luck,
Have you already glued the axle boxes in place?
If not, suggest you get these and the wheels painted or chemically treated as it miles easier to do this way.
- steamgeorge
Unfortunately they were already glued in place when I bought them. I will just have to use a small brush on the axle boxes however, 2 of the coaches have painted wheels already.tom_tom_go wrote: ↑Wed Oct 17, 2018 11:32 am Have you already glued the axle boxes in place?
George
- steamgeorge
Here is an update on the coaches. I have tried painting one in all green with white upper panels, I think it looks good and I prefer it to livery b (even though it looks miles better with the green raised to just below the windows). It helps make the coaches look smaller because they stand out less. However, it does look very green. Here are some photos of all three coaches, the new livery, and how big they are compared to some of my other stock. Sorry about the quality of the photos; they were taken on my phone in low light levels.
George
George
- Attachments
- Look at the height difference between the Manning Wardle and the coach!
- IMG_20181018_223010917.jpeg (164.94 KiB) Viewed 5540 times
- The original coaches are dwarfed by the other coach
- IMG_20181018_222933784.jpeg (146.16 KiB) Viewed 5540 times
- A comparison between livery a with black outline or green outline.
- IMG_20181018_222708327_HDR.jpeg (175.14 KiB) Viewed 5540 times
- livery a with more green
- IMG_20181018_222611011_HDR.jpeg (196.68 KiB) Viewed 5540 times
- All 3 coaches together
- IMG_20181018_222647466.jpeg (190.5 KiB) Viewed 5540 times
George, here's a picture of my IP coaches. The lighting wasn't great and they have a gloss finish so they weren't easy to photograph.
- steamgeorge
Thank you for the photos, I will use a livery very similar to them as I think it suits the coaches well.
George
George
George, despite being well over 10 years old, and not the most detailed coaches I like 'em. If I came across any I'd certainly add them to the pair I already have. I look forward to seeing your finished rake.
- steamgeorge
History was made at the WDLR last Sunday, we had our first ever visitors to the railway! Bruce and Peter of the West Cornwall Light Railway came over for the afternoon, both bringing an engine and stock. Bruce brought a Regner Vincent and Peter brought his Roundhose Karen. We made the most of the sunny afternoon with some good running. I steamed my Accucraft LnB Taw. Here are some photos of the afternoon.
- Attachments
- Bruce's Vincent
- IMG_2693.jpeg (149.37 KiB) Viewed 5345 times
- Karen and Taw at St Kew Highway
- IMG_2729.jpeg (173.38 KiB) Viewed 5345 times
- Karen approaches Trethevan halt
- IMG_2723.jpeg (156.02 KiB) Viewed 5345 times
- Karen with Taw in the distance
- IMG_2721.jpeg (175.13 KiB) Viewed 5345 times
- A busy moment at St Kew
- IMG_2702.jpeg (189.13 KiB) Viewed 5345 times
- Karen rounds the loop
- fullsizeoutput_5b.jpeg (183.16 KiB) Viewed 5345 times
