HGLW Wittenberg-Schafer Loco
Re: HGLW Wittenberg-Schafer Loco
My preferred option would be to build the body first and apply filler as required in any gaps, then smooth the areas before using any sealer.
I have much experience of using shellac and French polish during my career and wouldn't recommend spraying it as it will block the jet very quickly. I doubt it would be possible to clean any spray equipment afterwards.
If you can find a cellulose based equivalent that would be far better.
I am with Rik on this one narrow gauge is ruff and ready!
It looks good to me Rik. So good that the picture and your review has convinced me that one of these will be my next loco purchase.
Sounds good to me Peter, thanks. I'm used to blocked jets. It happens frequently with acrylics in the airbrush.Peter Butler wrote: ↑Wed May 16, 2018 1:32 pm My preferred option would be to build the body first and apply filler as required in any gaps, then smooth the areas before using any sealer.
Many thanks,
Agree - sanding the two top corners into rounded corners makes all the difference - make it look more prototypical to me - and the finish on that paintwork is spot on - its all about the number of think layers rubbed down in between
I'm about to place a Toolstation order but looking at Rik's finish beginning to wonder if it is overkill.
Rik, how did you bend that exhaust?
No, it isn't overkill. Wood always benefits from sealing. MDF is different as it is in effect a pulp, and as has been pointed out the glue used is water based. Properly sealed it will reduce the number of coats required to get the kind of finish Rik has acheived.
Sorry, only just seen this. I find that the 'New Posts' link doesn't always seem to find things I've not seen. Anyway, my apologies, I shouldn't blame technology!
I used copper tube for the exhaust as it was the only round metal I had of about the right diameter. To make sure it didn't kink, I threaded some brass rod through it and the just bent it by hand. If I'd had some brass rod of the right gauge, I'd have used that.
Here's my addition to this post - still on trial at the CHLR and needs a driver - will eventually become No.7 and be called Lightning ( a nod to the locos history) - predominantly be used as the PW loco for the line but with working LED lights, it will also be deployed on evening summer real ale trains - there will be a video to follow at some point
Lovely looking loco and a good reason for me to think more seriously about using my railway more frequently..... except for the distinct lack of Summer evenings!
I'm lucky that I live in the Costa Del KentPeter Butler wrote: ↑Wed Jun 20, 2018 11:11 pmLovely looking loco and a good reason for me to think more seriously about using my railway more frequently..... except for the distinct lack of Summer evenings!
Cute little critter.
The main station building is certainly a Modeltown resin kit, but looking at their website they don't seem to do the low relief versions anymore?
Hi - it was their wrinkly tin station kit built as two halves - the front and the back are the same so lend themselves to this - so I bought the kit then asked nicely if I could buy an extra part that sticks out over the platform and another chimney stack - he was more than happy to sell those to me - so I got two stations for the price of one and a bit The veranda on the first it to the right to extend the station covered area - and it would stick out and hit locos if it were attached to the front of the building
The only adaption to do is to cut the gable ends in half - I used a fine toothed hacksaw - support the weight and it works fine
Thanks Mark,markoteal wrote: ↑Fri Jun 22, 2018 9:44 amHi - it was their wrinkly tin station kit built as two halves - the front and the back are the same so lend themselves to this - so I bought the kit then asked nicely if I could buy an extra part that sticks out over the platform and another chimney stack - he was more than happy to sell those to me - so I got two stations for the price of one and a bit
That explains the mystery of the missing low relief version - there was never one! Tom, they do the same building as slate, tin, brick or wood finish. As Mark says, good value two for one modelling (almost)
Hi Derek,
Hope you haven’t sent for that Shellac, this is what I use and it’s far cheaper and just has quick drying.
I bought it in a 125ml tin.
