Electric Chassis
- Tony Bird
Electric Chassis
Hi,
I have just finished an electric chassis for a child's toy. Being only 100 mm long I think it is the shortest chassis that I have made that will hold up to 4 AAA cells so it could be radio controlled. I have another similar chassis to finish which I think I will rig for 4 cells and maybe fit radio when I can afford it.
Regards Tony.
Regards Tony.
- Tony Bird
Re: Electric Chassis
Hi,
Been meaning to ask, is that chassis just one extrusion?
The chassis is made from 25 mm x 19 mm x 3 mm aluminium channel, 1"x 3/4"x 1/8" in old money. The other part that the battery holder is fitted to is 25 mm x 6 mm aluminium which is held by screws to the channel.
I have just finished a slightly larger version with a bigger can motor and AA rather than AAA cells. It is fitted with 29 mm Binnie wheels and the gear ratio is 30:1. The body is fitted with modified Binnie couplings and Mamod buffers. Without the R/C the cost of conversion is about Β£12. Video at:
https://youtu.be/RlazvI-jDrg
Regards Tony.
Regards Tony.
I do admire your chassis (ie chassises - plural?), Tony. They look simple but are blooming effective. I might be tempted to have a go at making one myself. My success with my own chassis-making to date has been lamentable. I think I will have to invest in a pillar drill / drill press though to keep things square.
- markoteal
Agree - your chassi (My 'own' Yorkshire plural) Tony are always really neatly produced, including the wiring on this one - soooooooo good!ge_rik wrote: Mon Apr 23, 2018 6:47 pm I do admire your chassis (ie chassises - plural?), Tony. They look simple but are blooming effective. I might be tempted to have a go at making one myself. My success with my own chassis-making to date has been lamentable. I think I will have to invest in a pillar drill / drill press though to keep things square.
That is so cheap and looks a easy build.
Thanks Tony for posting
I need a pillar drill has well Rik. I have put my order in with Anne, might get one for my Birthday. heres hoping..
- IanC
That's set me thinking about building my own battery powered loco. Lack of equipment and skill are my biggest obstacles. Would a pillar drill cost more than buying a kit?
I got one in Lidl about 6 months ago for, I think, Β£60. They have them as their weekly special buys from time to time. I've been keeping half an eye out for some time since I saw good reviews of them. I have to say I haven't used it yet, so can't really comment on value for money.IanC wrote: Fri Apr 27, 2018 12:05 pm That's set me thinking about building my own battery powered loco. Lack of equipment and skill are my biggest obstacles. Would a pillar drill cost more than buying a kit?
Saw one last week Phil at Lidl, let Anne know this would be great for my Birthdayβ¦.
Β£56 it was.
- IanC
Thanks for that Phil. Lidl isn't one of my regular shops. I'll have to start checking them out.philipy wrote: Fri Apr 27, 2018 1:06 pm I got one in Lidl about 6 months ago for, I think, Β£60. They have them as their weekly special buys from time to time. I've been keeping half an eye out for some time since I saw good reviews of them. I have to say I haven't used it yet, so can't really comment on value for money.
At the risk of being accused of hijacking, we don't use Lidl regularly either, but I think they put them on their website a week or so ahead and if Rod has seen them recently, a quick trip might be worth it.IanC wrote: Fri Apr 27, 2018 2:38 pm
- GTB
Even a small chinese made bench drill can give you better results than trying to drill sideframes and coupling rods by hand.ge_rik wrote: Mon Apr 23, 2018 6:47 pm I think I will have to invest in a pillar drill / drill press though to keep things square.
When buying a bench drill do this quick check. Use the handle to extend the quill and see if you can rattle the chuck around using the other hand. A good one won't have any slop when you do this, avoid the ones that do...... I didn't know this when I bought mine years ago and there's no way to adjust it, so I only use it for drilling holes in wood.
Also get a suitable drill vice and clamp it to the drill table, as holding metal parts by hand when drilling is not a good idea. I've seen someone end up with six stitches in the palm of his hand when he tried drilling a 6mm hole in a strip of 1mm thick steel.
- Tony Bird
Hi,
I am fortunate in having a fairly well equipped workshop. However it wasn't always so, so I thought I would have a go at making a chassis using just hand tools as I did in days gone bye. I did use a mains powered electric drill, but all the other tools used were hand tools. The bit you might be interested is the drilling of accurate holes and for this I bought a vertical drill holder with vice for Β£15.
My drill is old and has a speed controller on the trigger which is useful at is allows the speed to be set before the trigger is locked for drilling.
This is a jig I made for increasing the hole size of gears wheels. wheels and pulleys.
The finished chassis, all holes were drill with the drill which when held in a vice was used to dress the ends of the axles after they were cut to length, even the aluminium channel was folded by hand, well with the help of a hammer.
The finished chassis photographs were too large so I will resize them and post them later.
Regards Tony.
Regards Tony.
- Attachments
- IMG_4069 LR.jpg (43.52 KiB) Viewed 16538 times
- Tony Bird
Hi,
The three chassis made by hand?
The same folded channel was used for each.
L to R axle mounted motor, channel chassis and a motor unit that can be screwed to the underside of a model.
Other than the half hour or so it took to fold the channel it wasn't much slower than my usual way of making chassis. It did take a bit out of my hands and wrists, out of practice or just older, probably both?
Regards Tony.
Regards Tony.
Thats great Tony thank you. Thats a really cheaper way of having a bench drill, although like you say, it may take it out of our hands and fingers with the old arthritic jointsβ¦.
I picked up an old bench drill for Β£20 at a market day.
You just need to check for play in the chuck so you know it will drill straight although I doubt it would be good enough for critical hole drilling for a live steamer.
Flipping heck Tom, when did you get that and can you get me one please.tom_tom_go wrote: Sat Apr 28, 2018 11:22 am I picked up an old bench drill for Β£20 at a market day.
- Tony Bird
Hi,
If the drill bit runs reasonable concentric there is no reason it shouldn't be used for any job within its capacity.
Regards Tony.
Regards Tony.
