Glendale Rocket Project.
- Tony Bird
Re: Glendale Rocket Project.
Hi,
The paint dried over night so the wiring was done this morning. With big brother. The carriage was finished. Finished! I am quite pleased with the results, though the six wheel drive was a little optimistic and I didn't allow for the pulley on the back of a wheel so had to move the axle and now only one securing screw can be used; this isn't a problem as the unused thread will still locate the chassis.
Regards Tony.
Regards Tony.
Great work again Tony, just went back to check the dimensions of the loco. No worries about traction either it would appear.
Great outcome. Will you be fitting r/c?
- Tony Bird
Hi Grant,
No for what is a very light model it works very well especially dragging a long wheel base carriage around 12" radius curves.
Hi Rik,
Maybe but would have to fit at least one other battery under the coach to up the voltage unless I use Lipo which as yet I haven't ever used.
Regards Tony.
Hi Rik,
Regards Tony.
Tony
If you do decide to try li-ion, happy to advise or assist if you need any help.
- Tony Bird
Hi Rik,
Thanks I might take you up on that. It is my wife's birthday in a couple of days and while she was out of town I thought I would get a card. On my way I passed a British Heart Foundation charity shop so I went in looking for an egg cup. No egg cup but a Glendale Rocket and carriage in as new condition along with some track. At £3 it was a it more expensive than the first. As I have just finished one and I have a couple of boilers to make it is unlikely anything will happen with it very soon but when I do make a start it will probably be for R/C.
Regards Tony.
Regards Tony.
Hi TonyTony Bird wrote: ↑Wed Jan 17, 2018 8:58 pm On my way I passed a British Heart Foundation charity shop so I went in looking for an egg cup. No egg cup but a Glendale Rocket and carriage in as new condition along with some track.
Regards Tony.
Blimey! Your charity shops seem to be a lot better stocked than mine. Very few have a decent selection of toys, and those that do seem to have stock which seldom changes.
Gee!
Hope you DID buy a card, I don't want the blame for that.
- Tony Bird
Hi Grant,
No worries! I did and it was even more expensive than my other major purchase of the day.
Regards Tony.
Regards Tony.
- Tony Bird
Hi Rik,
Cardiff has an amazing number of charity shops for a city with a population of about 450,000 they could almost claim to be a tourist attraction. In one street there a two RSPCA shops and it is only about half a mile long.
Regards Tony.
Regards Tony.
- Chris Cairns
Another fantastic SM32 conversion Tony, with yet another one waiting in the wings.
Like Rik & others I've yet to come across these amazing charity shop finds, but I do now carry my Jurassic Models 16mm scale ruler in my wallet to hunt out any 16mm scale bargains at the £1 shops.
- Tony Bird
Hi,
In between bashing and pickling boiler end plates I have put wheels on the new carriage which like its big brother has had its doors glued shut. The locomotive will pull both carriages at the same time but not around the tight curves of the test track. I will now have to look for some Postman Pat figures to drive and ride the train.
Regards Tony.
Regards Tony.
Tony, I wonder would a little more friction to the centre axle help. Could a little roller deflecting the drive band down slightly between the second and third axle work, though not wanting to get away from the simplicity of the project which is part of its attraction.
- Tony Bird
Hi Grant,
A very good idea and perfectly possible but alas not with the chassis as it stands as the motor would need to be moved a little, maybe when I have a go at Mk.2 I will try it. I have used a jockey pulley but in my a case sprocket to take up the wear on a chain drive electric locomotive chassis, the chain had worn but not enough that a link could be removed.
I have however improved the traction of the chassis, when building steam locomotives I usually balance them around the centre of the distance between the driving wheels. This usually requires a weight to be fitted to the front or rear buffer beam to achieve a rough balance. When I picked up the model it was very heavy at the back because of the batteries the motor not anything like balancing them. The hasn't happened before as all the chassis I have made have had the weight between the axles not outside.
So I balanced the model on its centre axle. It needed three and a half lead washers to balance the model. These washers were glued into the smoke box and then painted This done the model would stay in place with both front and rear buffer beams touching the table. The traction now is such that the motor will stall before the wheels slip. The Glendale Rocket now easily manages to pull both carriages and pushing it two Thomas the Tank Engine carriages as well. I have always found balance my steam engines improves their traction but never thought of trying the same on electric locomotive, to be fair most are probably nearly in balance anyway.
Regards Tony.
Regards Tony.
Good one Tony, I guess the basics of good loco design apply right down to your tiny locos size.
- Tony Bird
Hi,
As we go away tomorrow for a bit and I had got to a convenient stopping point with the boilers I am working on so to fill it time I thought I would do a bit of work on the Glendale Rocket Mk.2. Starting with cutting the body about to see if it was possible to fit thee AAA cells in the same place as Mk.1 had two.
This was a none electric version of the Glendale Rocket. The roof was removed along with the wheels and the first cut made. The body was dismantled. Part of the chassis was cut away. And filled to shape. Leaving it looking thus. The inside of the body had almost all the fixing points removed. Other parts of the model replaced. The body assembled with battery holder fitted. Body at end of play. So it looks as if I will be able to fit R/C to this model but it will be some time before it is completed as when we return it will be to finish the boilers.
Regards Tony.
Regards Tony.
- Tony Bird
Hi,
Having spent some time away I have been catching up with some drawing of things made that I might what to make again. I have also edited some video which has been added to the video of the Glendale Rocket, this video shows the Rocket performing after it had been balance and pulling both carriages.
https://youtu.be/gA5uMe0zN90
It will be several more weeks before we return to the UK and back to the workshop.
Regards Tony.
Regards Tony.
What a difference balancing makes, enjoy your break away Tony,
