Dazza your workmanship is astonishing, but more so your patience, slow and easy gets there, and it is looking great.Hydrostatic Dazza wrote: ↑Sun Sep 26, 2021 9:27 pm I had drawn up a tool box with tabs so the sides lined up so this was also in the little package from Model Engineer LASER, cooked up with 243 solder. This will hide the handle for the bypass valve.
IMG_6633 by Darrell McCulloch, on Flickr
IMG_6646 by Darrell McCulloch, on Flickr
IMG_6648 by Darrell McCulloch, on Flickr
Llewellyn Loco Works #1
Re: Llewellyn Loco Works #1
- Hydrostatic Dazza
Monday night in the Llewellyn Loco works Red Room workshop. Some KNUPFER hinges and 0.80 rivets. All is going to plan for this tool box.
IMG_6678 by Darrell McCulloch, on Flickr
IMG_6679 by Darrell McCulloch, on Flickr
IMG_6680 by Darrell McCulloch, on Flickr
IMG_6684 by Darrell McCulloch, on Flickr
- Hydrostatic Dazza
Thank you. What I try to do is push my skills, I am only following what others have done before. My need to is to learn and get the reward of satisfaction of it working out. Each little project part of the loco build is an enjoyment. I am learning more each day as I had no idea of garden steamers. I am not a moderl, it is not my thing since Airfix kits in the 1970's. I do not intend to make another garden steamer as I want to move on to making a 5" gauge loco in detail. (QR C17 class # 253 as delivered in 1921) Painting is the process I dread the most, but I have Chris Vines book and a few others to assist me.
- Hydrostatic Dazza
Dazza cries out to MAM
"Come see"
IMG_6692 by Darrell McCulloch, on Flickr
IMG_6705 by Darrell McCulloch, on Flickr
IMG_6694 by Darrell McCulloch, on Flickr
IMG_6700 by Darrell McCulloch, on Flickr
"Come see"
That is exquisite. Each part is a little project in its own right.
Darrell that is exquisite
- Hydrostatic Dazza
Thank you and also it is how I think and approach these things, as a little project, or I would be cowering in a corner, muttering incoherently and dribbling all over myself. (Some argue I do this now)
This whole build has escalated ten fold in complexity from the day I started this.
- Hydrostatic Dazza
Thanks Trevor. I am only following in the footsteps of others.
- Hydrostatic Dazza
Battery tray and a cunning plan for the charger lead port is being hatched. Also the tender horn keep is done,inspired by the Burma # 9 loco.
IMG_6838 by Darrell McCulloch, on Flickr
IMG_6843 by Darrell McCulloch, on Flickr
IMG_6873 by Darrell McCulloch, on Flickr
IMG_6834 by Darrell McCulloch, on Flickr
IMG_6870 by Darrell McCulloch, on Flickr
- Hydrostatic Dazza
So far the charger port plan has worked out
IMG_6879 by Darrell McCulloch, on Flickr
IMG_6880 by Darrell McCulloch, on Flickr
IMG_6881 by Darrell McCulloch, on Flickr
IMG_6884 by Darrell McCulloch, on Flickr
IMG_6887 by Darrell McCulloch, on Flickr
IMG_6888 by Darrell McCulloch, on Flickr
- Hydrostatic Dazza
I have to work out the path and connections for the flow of electrons to the loco, so line it all up for the first time.
IMG_6889 by Darrell McCulloch, on Flickr
IMG_6891 by Darrell McCulloch, on Flickr
IMG_6890 by Darrell McCulloch, on Flickr
IMG_6893 by Darrell McCulloch, on Flickr
IMG_6892 by Darrell McCulloch, on Flickr
- Hydrostatic Dazza
The first servo fit up. The cylinder drain servo is behind the front buffer beam
IMG_6894 by Darrell McCulloch, on Flickr
IMG_6896 by Darrell McCulloch, on Flickr
Absolutely stunning. I think I've said it before but I wish I had even a fraction of your talent, patience and eye for exactitude. Every minute detail is a mini masterpiece - even down to the door covering the charge socket!
- bambuko
I would be interested in more detailed description of what servo does what? pleaseHydrostatic Dazza wrote: ↑Fri Oct 08, 2021 12:45 am The first servo fit up. The cylinder drain servo is behind the front buffer beam ...
I am guessing - regulator, blower, reverser and...?
Thank you for sharing!
- Hydrostatic Dazza
From left to right of pic. Regulator, Whistle, Blower and Reverser. The Cylinder drain servo is behind the front buffer beam. The cylinder drain servo is not installed at the moment but it has been and it is the only one I have made the operating linkages for at this time.bambuko wrote: ↑Fri Oct 08, 2021 6:08 pmI would be interested in more detailed description of what servo does what? pleaseHydrostatic Dazza wrote: ↑Fri Oct 08, 2021 12:45 am The first servo fit up. The cylinder drain servo is behind the front buffer beam ...
- bambuko
OK, so I missed the most important - the whistle
Thank you for the explanation
- Hydrostatic Dazza
While Captain Plod waits for some samples of small electrical plugs for the tender to loco stream of electrons to flow down, he got the S16 cow catcher casting a good going over with the files and fitted it up. Not part of the original plan however, after the troubles with the pesky cows at the Orchid House loop senior management who grew up on a farm likes cow catchers so....
IMG_6909 by Darrell McCulloch, on Flickr
IMG_6905 by Darrell McCulloch, on Flickr
IMG_6901 by Darrell McCulloch, on Flickr
IMG_6903 by Darrell McCulloch, on Flickr
- Hydrostatic Dazza
Sunday in the Red Room while MAM was assisting with a wood firing at her Pottery club. Much modified Swift16 tank loco steps, chopped and filed and then soldered up and fitted. Some bicycle blade spokes were used as solder fingers. Spokes are very useful in the workshop. Loco Steps are fitted the tender steps to be fitted up tonight.
IMG_6912 by Darrell McCulloch, on Flickr
IMG_6913 by Darrell McCulloch, on Flickr
IMG_6914 by Darrell McCulloch, on Flickr
IMG_6918 by Darrell McCulloch, on Flickr
IMG_6919 by Darrell McCulloch, on Flickr
I find it quite amusing that S16 flatly refuses to post bits to Canada under any circumstance but WILL post them to Australia!
- bambuko
indeed,
alternatively you could find these very useful as well (titanium soldering strips):
https://www.andrewberry.co.uk/product/t ... f-5-or-10/
