IP brake van
IP brake van
I have managed to get the shed built and an unexpectedly free afternoon has allowed me to make a start on an IP Brake Van.
This I acquired second hand, but un-started. I think it may be one of Ivan's earlier efforts.
It does go together reasonably well but I can't say that I am overly impressed with some of the panels as none of them seem to be quite square. They are out just enough to make fitting everything up a bit of a fiddle, but not enough to be really noticeable before you put things together. I don't know if this is just a bad one as other IP kits I have built have gone together with out much hassle.
Mind you as the wide assortment of Dai's on the PMR don't really do subtle, I am certain that the slighty iffy panel fit can be put down to some over energetic fly shunting.
Next task is to drill some holes for some coach bolt heads. Just out of interest, would wooden framed wagons be all bolted together or would some of the panels be nailed on? (Basically do i need to drill holes on all the framing?)
- IrishPeter
Re: IP brake van.
Sorry, but frames were largely bolted, and underframes were held together with quite a lot of ironmongery. Nails cannot take a lot of gip, so they are mainly useful for non-load bearing parts of the structure, and even then, only when one is doing a cheap and cheerful job.
Peter in VA
Peter in VA
Re: IP brake van.
Slight change of plan, I still haven't found my box of microstrip so the strapping with have to wait.
I decided to put window frames in, these are a third depth in the aperture so that gazing can be put in and another bit of framing can be put in the rear. I think I will use well diluted pva to stick the glass in. This should avoid the fogging you can get with Superglue. Hopefully this, with the rear frame will hold it all well enough.
The doors were so out of true, I remade one and fitted the other in the open position.
I think it needs a working tail lamp, why, I am not sure as I don't have a railway and I don't run in the dark, It just seems like a good idea. Chuffed 2 Bits self contained ones are unavailable at the moment. Does anyone know of another supplier that does working ones that carry their own batteries?
Re: IP brake van.
Jim, for the installation of window glazing I recommend Canopy Adhesive which is designed for the purpose the name describes. It is a milky liquid which dries perfectly clear and leaves no residue or fogging, I have some so I know it works.
Re: IP brake van.
Thanks Peter, I will give that a go.
Re: IP brake van.
I love your mug Jim, I need one of those for work.
Self-contained lamps:
http://slrmodels.co.uk
Otherwise, make one and hide the battery under the deck. I did this on my IP van using a coin cell battery. It powers one LED for ages.
Re: IP brake van.
Thanks Tom, I will have a look at SLR.
The mug was a present from Secret Santa last year at College, apparently I had raised bloody-mindedness to a new level and had started to scare younger colleagues with an outlook of Eeyore/Victor Meldrew proportions. As I come from a line of cantankerous old buggers, I took this as a compliment. I am currently training my son and heir to take on the mantle of well aimed, instructional and educational stroppiness.
Re: IP brake van.
A bit of bolt detail has now been applied with plenty more to do.
Coach bolt heads on the outside and nuts on the inside. Strapping made from very old (Priced in £/s/d) microstrip.
My eyes are now well and truly crossed and unable to focus on anything more than 6 inches away.
Re: IP brake van.
Yes. I have plenty in stock for this build but I hope they are back in production soon.
Re: IP brake van
Looking good Jim, you must be pleased with the additional work which is going to make all the difference to the end result.
Re: IP brake van
I am hoping it might disguise some of the less well cut parts.
It will be weathered to the point of decrepit and again this should help.
It would be unheard of for the PMR to possess an item of rolling stock that was anything less than three-parts knackered.
Re: IP brake van
All the ironwork has now been completed. I have to say that attaching the rivets/bolts is quite therapeutic.
Re: IP brake van
What David said. Going to look good in colour.
Re: IP brake van
That is looking nice, did you find it easier the more you did? It's finding a method that works for you. I can't honestly say I find it therapeutic but it is rewarding to see some texture emerging on a slab of wood or plasticard.
Re: IP brake van
Thank you Gentlemen.
A bit more work progress, sprayed grey last night. I wanted a very rough, aged finish so I didn't mix the paint particularly well before I sprayed it. This gives quite a mottled effect with different tones across the body. Two planks I masked up to keep the grey off, these were then toned down a bit with mucky thinners. a few other planks were painted with a slightly different colour to represent repairs. A quick roughen up in a couple of patches, followed by some brown to give it some rotten areas (paint still a bot wet, hence the slightly shiny appearance)
I don't know if I am going to bother picking out the strapping in black, I can't see that the PMR would waste time and paint on doing this. Although the bolt heads on the two bare wood planks will be picked out in silver as new fastenings would have been used.
As for the poster....
It would appear that the PMR's cash saving, no clock policy has backfired in a rather unfortunate way.
Re: IP brake van
Bit hard using a sundial while rounding a curve though. Still laughing!!!
Re: IP brake van
Surely if you provided company pocket watches this hilarious practice would cease?
