Slaters transfer application??
JMORG
Post by JMORG » Sun Sep 10, 2017 10:08 am
Hi,
Anyone used Slaters transfers? We're trying to understand the transfer instructions but it doesn't make much sense!
Re: Slaters transfer application??
Post by Big Jim » Sun Sep 10, 2017 12:53 pm
They used to be of the water slide type. Cut out, soak and then apply using tweezers when they lift of the backing. Varnish if you feel the need.
I don't know if they have changed recently
Post by FWLR » Wed Sep 13, 2017 12:53 pm
Are most water slide transfers like that, i have just got a Binnie Engineering Wagon Kit and that has some water slide transfers with it. :thumbup:
Post by Big Jim » Wed Sep 13, 2017 1:05 pm
Did you get anywhere with these Jason?
JMORG
Post by JMORG » Wed Sep 13, 2017 5:44 pm
They're quite unusual in application, you require meths instead of water and "pressing" the transfer down on the surface and peal the top away. Also, each character is separate, so good luck with the long characters!
Post by Big Jim » Wed Sep 13, 2017 6:27 pm
Ahh Methsfix. I had forgotten about them.
