transfers on glazing
JMORG
Post by JMORG » Tue May 23, 2017 11:38 pm
Hi all,
Just adding the finishing touches to FR van 2. It has "no smoking" signs that sticks to the glazing, can anyone recommend a good sealant to use that wont go opaque?
Cheers
Re: transfers on glazing
Post by Peter Butler » Tue May 23, 2017 11:47 pm
Sometimes I use Canopy Adhesive to fix glazing in window frames. It looks like milk when applied but dries clear.
JMORG
Post by JMORG » Wed May 24, 2017 12:18 am
Hi Peter,
I'm not too sure how the transfers would react to canopy glue. Would you recommend it?
Post by Big Jim » Wed May 24, 2017 7:04 am
Humbrol sell a stuff called Decalfix, never tried it myself. But it might be worth a quick experiment.
Post by Peter Butler » Wed May 24, 2017 11:00 am
JMORG wrote: Wed May 24, 2017 12:18 am Hi Peter,
Sorry but only used it on glazing where it does dry clear, not sure about transfers. Are they attached inside or outside of the windows?
JMORG
Post by JMORG » Wed May 24, 2017 11:48 am
Unfortunately, both the DJB and the IP transfers I have are external! I'll try a few test pieces before tackling the carriage! I'll post the completed article later in my broken ankle forum.
Post by Peter Butler » Wed May 24, 2017 4:47 pm
Could you use a double skin.... two thin sheets of glazing with the transfer trapped in between?
