I have purchased an old Billy loco (one with a square gas tank) and I want to fit a chuff pipe. There seems to be 2 problems with this. 1. I can't remove the smoke box as the steam feed pipe to the cylinders goes through a large hole in the smokebox base and not a slot as in later models and 2. the steam exhaust pipes are very short and go into a short piece of flattened tube wrapped around them.
Has anyone got a solution to these issues?. I am happy to dismantle the loco to any extent, just cant seem to get the smokebox off> Is it a push fit onto the end of the boiler as current models?
Old Roundhouse Billy
steveh99
- TonyW
1) You'll need to take the boiler off the frames. Once that is done you can remove the smokebox, which is a push-fit on to the boiler, by passing it along the superheater pipe.
2) The flattened tube will pull off. You can specify a longer pipe length when you order the chuffer pipe to accommodate the shorter exhaust pipes.
- TonyW
My pleasure! If you're going that far anyway it would be worth changing the circular hole in the smokebox in to a "mouse hole", i.e. open to one edge, and modifying the fixings so it can be easily removed in the future.
