Plans for a couple of loco's
Does anyone have plans/drawings for Bacillus (Hudswell Clarke)
and Microbe (Hunslet)
from the Knostrop Sewage works. I've spent the last few years studying microbiology so scratch building them for the garden railway is quite appealing
Thanks,
Thanks,
- Killian Keane
I love these little locos - being a winding twisty line, the CHLR positively gets excited by small locos.
Look quite similar to the locos used on the Rye & Camber tramway - albeit they were supplied by Bagnall but they are very much 'of the moment'.
Its a real shame one of these hasn't been made as a RTR or a kit (unless you know differently- I'd be at the front of the Q!
Re: Plans for a couple of loco's
Not sure where the Hunslet Engine Co.archive is currently located. Hunslet took over Hudswell Clarke, so HC drawings will be wherever the HEC ones are located.pskipper:123252 wrote:Does anyone have plans/drawings for Bacillus (Hudswell Clarke) and Microbe (Hunslet)
Microbe is about the same size as a Hunslet Waril class, so you'd be looking at 7/8" scale to build it from Roundhouse parts, if you wanted a live steamer.
While a builders G/A is useful, if you aren't hung up on attaining absolute accuracy, knowing a few dimensions means you can come up with a sketch plan from photos.
The Hunslet builders photo you have is near enough to dead side on and there are articles around on how to use the projection method of correcting for the photo parallax. I built my Fowler 0-4-2T from a builders photo., catalogue dimensions and a couple of photos of it in service.
looking through my library, the Plateway Press reprint of Hunslet catalogue sheets quotes some dimensions for Microbe. It was 8' 2 1/4" to top of chimney, 5' 7 1/2" over cylinders, with a rigid wheelbase of 4'.
Can't find anything on Bacillus, but it would likely have been the same height. The photo needs more correction than the Hunslet one though.
Thanks for all the replies, especially the measurements for Microbe. I've had a go at warping the Bacillus picture so that it is closer to a side on view and assuming a 4 foot wheel base the loco comes out at 8'6" so I'm probably not too far out I've also found a small picture of Bacillus in 3/4 view so have front details too.
presumably Hudson's supplied the railway these locos ran on as Microbe features in a couple of photos in the recent reprint of the 1915 Hudson catalogue. Still available from the Narrow Gauge Railway Society.pskipper:123299 wrote:I've also found a small picture of Bacillus in 3/4 view so have front details too.
The photos show it with a train of tip wagons, from a front 3/4 view, so the smokebox and cab front details are on view.
Maybe they are now housed at Statfold Barn - http://www.statfoldbarnrailway.co.uk/hu ... ection.phpGTB:123293 wrote: Not sure where the Hunslet Engine Co.archive is currently located. Hunslet took over Hudswell Clarke, so HC drawings will be wherever the HEC ones are located.
- artfull dodger
Hi Philip.
Statfold do hold the Hudswell Clark drawings, or at least,those that still exist. Give them a call and ask for the Hunslet Archive.
They supplied me with 4 Drawings for w/no.1172 Alpha.
More directly helpful, years ago, Tom Cooper published an article by Don Townley about Microbe. I have scans of the drawings and will try to pm them to you over the next couple of days.They are on the desktop computer and I'm sending this from my tablet!
Mike
Mike
Thank you, that is very helpful
I met Tom Cooper when I was young, we were on a family holiday in Wales and from a slightly old advert tracked down what we thought was the Merlin shop. Embarrassingly it was shortly after he had, in his own words, had the company stolen from him. He was a real gent and invited us in for a cup of tea and talked railways with me but I think my parents were quite glad to leave as he was still somewhat irate about Merlin.
Hi Philip
2 emails sent.
Building on a comment above, Microbe is small!!
My first attempt at modelling this was just after the drawings were first published. The boiler was going to be a 32mm diameter 'pot' but I lost momentum on the build when I realised first, that the boiler was too low-set on the frames for a pot-boiler to be viable and also that the duration of the run would be quite short. (This was long before top up bottles and Goodall valves).
Now, I have a new build underway, this time in 7/8ths scale and with a single flue boiler.
Since it is my thing, I'm scratchbuilding but It would be easy to use Roundhouse parts, either in 7/8ths or by rubber-banding slightly and using a scale of 3/4" or 20mm, still on 45mm track.
Good luck with the build and thank you for posting the picture of Bacillus - it's the first I've seen.
Mike
2 emails sent.
Mike
Look forwards to seeing pictures of your Microbe when it's finished. I'm not sure whether I'll go live steam or just steam outline for these two as they are so small. I did find another picture of Bacillus, this one in service, thanks to a website having a copy of an ebay listing so have a front view if the plans no longer exist...
I'm curious about what the thing on the front is, obviously a later addition as it wasn't in the works photo.
Thanks again for the drawings
Could it be two lifting jacks with the handles crossed?
I wanted to say that but thought I would be wrong...
Ah! hence the cautionary "could it be".
Blowing the pic. up in Irfanview helps.
