Second jigstone building
This is my second jigstone building in progress. It has been several months since I started the project but I will take advantage of Christmas Holidays for a final push.
More update of the progress.
I spent a few hours during the weekend to touch up the outside of the building. Further, I also put in a wood column and panel in the empty room. So far, everything is done for the exterior, now I will focus on interior.
I just add some more decorations for the building. It rained in the past 10 days in Nashville, the weather is wet but I saw some budding plants in the garden railway; I can't wait to see flowers soon.
I agree, the roof will be nice if we chose the right material; that is what I always struggle. The roof of the building is the same roof used for my house.LNR:121533 wrote:That's going to be a nice building when finished. That could live in the Australian scene with perhaps a corrugated iron roof. (thinking, thinking) Speaking of which, what is the roofing material you have used? I do envy you guys and your stone buildings.
I am always impressed with the results from the use of Jigstones. Limited only by your own imagination, the variety of structures is endless.
Either corrugated sheet or slates would be suitable to give a convincing finish on this building and be in character.
Does it have a purpose at this stage?
- andymctractor
Worth considering is that the roof is the part of the building most on view even if your railway is ground level and its worth it to get it looking as good as you can.
Brandbright is back in business though their 'Materials' section is still not stocked. I've used their brilliant roofing sheets before and can recommend them especially their corrugated iron. I'm assuming they will be producing these sheets again.
Failing that the National Show is in early April and there will be plenty of options available there. If you can't wait then I'm sure you will get some advice on building some of your own.
I would suggest you don't attempt to use the jigstones roofing sheets as they are very small and you would need to assemble the units and camouflage the joins.
Also, as you add to the building keep checking the weight of the whole thing. I have a terrace of 2 storey miner's cottages and I need my wife's help to get them onto the workbench.
Here is an old photo of a building I made for a friend. The roof is cut from a sheet of fibreglass moulded roofing slates and is robust enough not to require any supports or sub layer. This makes the job easier, if you can get hold of the stuff.
Good luck
Good luck
Andy McMahon
Andy McMahon
I have no idea yet, but probably a farm house. There is a large opening on the other end of the building, I may fit a tractor in. If you have any idea please let me know.Peter Butler:121541 wrote:I am always impressed with the results from the use of Jigstones. Limited only by your own imagination, the variety of structures is endless.
andymctractor:121542 wrote:Worth considering is that the roof is the part of the building most on view even if your railway is ground level and its worth it to get it looking as good as you can.
Good luck
Thanks Andy for the experience. I agree jigstone roof is too thin and too small, not very practical for large building. If use Jigston roof, I guess we must have a support roofing slates since I am afraid they can't stand by themselves if we join multiple pieces.
Yes, it is true, the building is very heavy but strong.
Your building is nice. I will keep learning from you and others.
Difficult to know what type of structures you need on your railway without some background info. It looks as though it could become a workshop, especially with a large entrance you describe, something like....mymodeltrain:121543 wrote:I have no idea yet, but probably a farm house. There is a large opening on the other end of the building, I may fit a tractor in. If you have any idea please let me know.Peter Butler:121541 wrote: Does it have a purpose at this stage?
Or possibly an estate office if you have open ground to fill?
For my own slate roof effect I use black Plastikard and have described the method elsewhere, but it is simply scribed into the width of slates and cut into strips to be laid onto a flat supporting plastic sheet, which makes it strong but lightweight....
Peter Butler:121545 wrote:Difficult to know what type of structures you need on your railway without some background info. It looks as though it could become a workshop, especially with a large entrance you describe, something like....mymodeltrain:121543 wrote:I have no idea yet, but probably a farm house. There is a large opening on the other end of the building, I may fit a tractor in. If you have any idea please let me know.Peter Butler:121541 wrote: Does it have a purpose at this stage?
Good idea, when I look at Andy McMahon's building I also have an idea of turning it into a workshop. I need to decorate abit inside, specifically, an interior wall should be installed to cover the jigstone wall.
