The Leawarra Nayook Railway
daan
Post by daan » Sat Mar 17, 2018 12:43 pm
Great scene, the dozer looks the lot! Like a picture in 1:1 scale!
Post by ge_rik » Sat Mar 17, 2018 5:18 pm
Great photo, Grant. Another example of how to set up a scene to create realism. Can't get enough of it.
I'm thinking of building a gantry to offload logs at my sawmill - something along these lines -
Post by philipy » Sat Mar 17, 2018 5:39 pm
Rik, I don't want to hijack Grant's thread, but when I saw your sawmill in position earlier, I assumed that you would be building something exactly along these lines to off-load logs.
Post by LNR » Sun Mar 18, 2018 5:26 am
No problem Philip, this is where ideas develop.
Rik, a gantry would look really good, would that be inside the building or extending out from it?
I think it's interesting to research the process of breaking down logs into sawn timber, to get a feeling of the layout and the equipment required. Its made me realize I'm doing it wrongly, my wagons should be carrying sawn timber instead of logs.
I'm guessing your mills were a permanent affair, where as many small Australian mills were often set up in the bush, and only stayed operational till the timber ran out or became uneconomic to harvest.
I'm looking forward to your mills completion, I remember the alterations you made to get the timber sidings into your landscape some time ago, you were obviously thinking well ahead.
Post by FWLR » Sun Mar 18, 2018 10:25 am
ge_rik wrote: Sat Mar 17, 2018 5:18 pm Great photo, Grant. Another example of how to set up a scene to create realism. Can't get enough of it.
That would be some build again Rik. :thumbright:
Post by bazzer42 » Sun Mar 18, 2018 10:28 am
Those pictures were a real treat, getting the garden railway juices to flow again :D Saying that we have 3 to 4 inches of snow at present :roll:
Post by tom_tom_go » Sun Mar 18, 2018 11:21 am
It's -1 here in my part of the UK with a thin layer of snow so I debating whether to do some coal fired running today or not!
Post by ge_rik » Sun Mar 18, 2018 12:50 pm
LNR wrote: Sun Mar 18, 2018 5:26 am ..... would that be inside the building or extending out from it?
Hi Grant. I'm thinking it would extend out from one end. I've figured that if the production line of logs in and planks out was U shaped, then the same gantry could be used to offload logs and to load the planks.
I'm working on the assumption that the railway will bring logs and take away the planks and so the sawmill will be permanent. I think my mobile crane could be used to load logs at intermediate stations - though maybe its arm would need extending somehow to reach the middle of the wagon. Hmmmm....... The logisitics are quite fascinating.
Post by LNR » Mon Mar 19, 2018 9:11 am
Outside at one end would certainly look the business Rik, were it inside you wouldn't see much of it.
From what I have read, logs in one end, broken down to large flitches or heavy boards, across at the end, then up the other side being edged and ripped to sizes would seem quite feasible.
Post by LNR » Thu Oct 18, 2018 2:11 am
Decided I had better steam a few locos with the Great Southern Steam Up coming in early November, so the Hunslet got a run on an overcast and rain threatening day.
Oct. 2018 3.JPG (116.4 KiB) Viewed 5946 times
A brief check and oil round by the boys.
Oct. 2018 1.JPG (170.58 KiB) Viewed 5946 times
Too busy on the down. The loco has run around and ready to return to Leawarra.
Oct. 2018 2.JPG (198.39 KiB) Viewed 5946 times
A quick shot on the bank leaving Warringine.
Mitch stack
Post by Mitch stack » Thu Oct 18, 2018 5:04 am
Great Shot Grant, I wont be at GSSU this year to meet you because i have other things on that weekend You might see me there next year with another loco instead of Goblin. Hope you have seen progress on my tramway.
Mitch
Clockwork
Post by Clockwork » Thu Oct 18, 2018 7:25 am
Nice pictures Grant I really like the shot of the boys in the inspection pit area. :thumbright:
Kevin :thumbleft:
Post by ge_rik » Thu Oct 18, 2018 7:49 am
Great sequence of pix. Is that sedum growing alongside the tracks?
Post by FWLR » Thu Oct 18, 2018 9:01 am
Clockwork wrote: Thu Oct 18, 2018 7:25 am Nice pictures Grant I really like the shot of the boys in the inspection pit area. :thumbright:
I agree with Kevin, brilliant shot there Grant.
IanC
Post by IanC » Thu Oct 18, 2018 10:11 am
They are great pictures with my favourite being the one in the station with the overgrown tracks. It just oozes so much atmosphere for me and sums up narrow gauge railways. Thanks for sharing.
Post by Lonsdaler » Thu Oct 18, 2018 10:13 am
Even your scrub growth is to scale! :!:
Really scenic and realistic photos again Grant. :thumbup:
Post by LNR » Thu Oct 18, 2018 11:46 am
ge_rik wrote: Thu Oct 18, 2018 7:49 am Is that sedum growing alongside the tracks?
Not Sedum Rik, which if I've got it right is a succulent. Don't know what it is but it's a prolific grower in cooler times, has very little hold on the ground (you can sort of comb it out with your fingers) and dies off very readily when temps rise, leaving seeds galore for next time.
Post by Andrew » Thu Oct 18, 2018 11:56 am
Wonderful pictures! I love the paint finish on the loco, the simple one carriage train, the cab-first running, and - as others have said, the atmosphere the vegetation creates...
Post by ge_rik » Thu Oct 18, 2018 3:57 pm
LNR wrote: Thu Oct 18, 2018 11:46 am Not Sedum Rik, which if I've got it right is a succulent. Don't know what it is but it's a prolific grower in cooler times, has very little hold on the ground (you can sort of comb it out with your fingers) and dies off very readily when temps rise, leaving seeds galore for next time.
Well, whatever it is, it looks spot-on for scale weed growth beside the railway. I'm experimenting with sedums (seda??) in a couple of places in my garden which dry out quickly in the summer. Everywhere else generally stays quite damp and so moss and MYOB grow in profusion, but not along the back edge of the garden.
Post by LNR » Fri Oct 19, 2018 2:32 am
Bagnall got a run today,
2018 Oct. 1.JPG (90.16 KiB) Viewed 6057 times
Raising steam on shed.
2018 Oct. 8.JPG (150.99 KiB) Viewed 6057 times
On the down, Warringine Valley Bridge.
2018 Oct. 7.JPG (224.09 KiB) Viewed 6057 times
Back amongst the weeds at Nayook.
2018 Oct. 9.JPG (207.93 KiB) Viewed 6057 times
On the up, that curve again.
2018 Oct. 11.JPG (131.63 KiB) Viewed 6057 times
Simmering on the turntable after the trip.
