Garden railway questions
Arthur Sleep
Post by Arthur Sleep » Wed Dec 16, 2015 6:26 pm
Hello everyone
Now to put it straight, I know barely anything about railways in the garden. Having a large but narrow garden, I thought it to be a good idea to build an o gauge mamod track. However, I will not have very much time to build it. I have heard oo gauge isn't good in the garden, and having had experience with mamods - I have a MM1 and an SW1 -
I thought a mamod engine would be good as all the others are so much money you could buy an apple laptop and we all know how much they are... So basically I am asking for advice, help, and anything else related to the GR world.
Thanks
Post by Soar Valley Light » Wed Dec 16, 2015 7:40 pm
Hello Arthur,
It sounds like you have an interesting if challenging space to work in. I can't claim to be any expert in garden railways, I'm still at the Civil Engineering stage myself, but I've done a good deal research and a good deal more planning!
As a starter, how narrow is 'narrow'? It sounds like it will be the limiting factor for your track alignment and may well be the most critical element of how well a garden railway will work for you.
Arthur Sleep
Post by Arthur Sleep » Wed Dec 16, 2015 7:53 pm
Soar Valley Light:114864 wrote:Hello Arthur,
Thanks Andrew. When I say narrow, I mean maybe 3-6 metres in width. I can't measure it at the moment as it is dark and cold outside, but it's not too narrow, it goes round the back of the house like this [ .
Post by MDLR » Wed Dec 16, 2015 8:15 pm
The first thing you need to do (if you haven't done it already) is to join the 16mm Association www.16mm.org.uk - as part of your Joining Pack you'll get a handbook on garden railways which may well answer many of your questions, a DVD with video of other lines (good to pinch ideas from) and most importantly a local area group whose brains you can pick!
Arthur Sleep
Post by Arthur Sleep » Wed Dec 16, 2015 9:33 pm
Thank you!!
Itareus
Post by Itareus » Thu Dec 17, 2015 11:27 pm
Some other things to think about :
Is you garden level or will you need viaducst & tunnels ?
(Think of the extra work & costs).
Do you see the line being at ground level or raised ?
(As you get older raised is good :) but more engineering & cost).
Do you want a continuous run to watch the trains go past or something else ?
Will you have a mixture of locos (live steam, clockwork, battery, rail fed) ?
What sort of control system for the locos (manual, radio, through rails or a mixture) ?
Loads more to think about - the above are just some to get you started.
Would be a good idea to measure up the available space and draw up a plan of your garden so that everybody can see what you have to work with.
Whatever you decide Arthur the main thing is to enjoy building and running your line !
Chris M
Keith S
Post by Keith S » Fri Dec 18, 2015 5:57 am
I recently joined the 16mm association. I am looking forward to their DVD and magazine because I, too, have an oddly-shaped and small garden.
Arthur Sleep
Post by Arthur Sleep » Fri Dec 18, 2015 2:01 pm
Ok thanks
Sir Clothem Cap
Post by Sir Clothem Cap » Sat Dec 19, 2015 7:26 am
The newer designs from mamod are superior to the original design. I started with mamod track but changed to peco sm32 track which is superb for running all sorts of o gauge trains. Second hand track is often available on ebay if money is restricted. Points are the most costly part of the railway. Design you layout and build a station while the weather isn't being kind.
OO is a nightmare outside as the smallest twig can cause derailment. 32mm is ideal in limited size gardens
Arthur Sleep
Post by Arthur Sleep » Sat Dec 19, 2015 8:36 am
I thought the older mamods would be better. Thanks for the information.
Sir Clothem Cap
Post by Sir Clothem Cap » Sat Dec 19, 2015 4:05 pm
Old ones are still great but the technical spec of the more recent ones has really got better including double action pistons, in line oiling and gas firing.
On saying that the sl1 and its variants keep me happy too.
Arthur Sleep
Post by Arthur Sleep » Sat Dec 19, 2015 4:44 pm
I think for my first engine I'll try an sl on eBay
Sir Clothem Cap
Post by Sir Clothem Cap » Sun Dec 20, 2015 9:59 pm
A very good place to start. Mamod loco's run well on sm32 track, you do need to have the largest curves possible in your garden area as it helps keep fast running locos on track.
Users browsing this forum: No registered users and 43 guests
