Recent Stuff on the FBGR
Re: Recent Stuff on the FBGR
I do like the VW van/pick-up but at 1:24 it is a little small. The ones I use are 1:18, just a fraction on the large side but closer to scale.
However..... location, location!!! If placed carefully they can look perfectly OK.
I have been slowly progressing, adding more bits to the road/grass/fence panels between the running line and the siding. I have now reached the bridge, so I thought I had better do an update.
This is the last portion fitted coming up to the bridge.
And this is looking back from the bridge towards the Station area.
This is the sorting out the next lot of panels for the area between the siding and the loco shed.
I mocked up a building and platform to see how it all fits together and check sizes. The mock-ups were made in foam PVC board, screwed together. The structures will be made in plasticard however, as I have found that the foam pvc moves and shrinks in sunlight.
J0hn
J0hn
The world's going to end very soon --- so I'd better try to get something finished by then
Looking great. Those two bushes look just the part between your line...
Itβs been a little time since I posted, but I thought that the slow progress that I was making was making the postings a bit boring.
Anyway, I can now report that the area of the plastic decking has now been completely covered, including all the fresh buildings/sheds.
The box bush got the deadly moth and died, and this leaves a bit of hole in the middle, but this will be filled with something (plant) in the spring.
Here are some pics of the completed area
DSCF5530
DSCF5533
DSCF5534
DSCF5539
JOhn
DSCF5530
DSCF5533
DSCF5534
DSCF5539
JOhn
That's all looking very good now, bet it must be very satisfying knowing that rot will never trouble you again.
That all looks wonderful, well worth the effort and enjoyable too, no doubt.
That does look very nice indeed. Bet running your locos are a real joy..
