Paint on Mamod Locos
Do you need to use heat resistant paint on the bodywork (cab tanks etc) of the Mamod locos????
- grumpfuttock
The modified Mamod shown here:-
http://www.tumblydowncottage.dk/html/bo ... _no_2.html
was first sprayed with heat resistent semi-matt black paint, and then I added panels of Humbrol blue on the front of the tanks, sides of the tanks and cab sides. I was a bit dubious of how it would stand the heat, but the loco was steamed many times and the Humbrol paint is as good now as it was when first applied. I did thin down the Humbrol paint quite a bit--trying to avoid brush marks, and applied 3 coats with a brush. I had expected it to look awful, but to my surprise it came up very well. I had also worried about how the oil paint on (cellulose based? ) heat resistant paint would react. A trial on a piece of metal proved that there would be no problem.
John.
"I am not an armchair modeller, I have a garden railway, so I am a deckchair modeller."
I just use ordinary humbrall matt black on the boiler of mine.
The eat sheild Ive never bothered painting though i just put some wd40 on it every once in a while to stop it rusting to much.
Cecil your engines on Fire!
Its a Mamod it does that.
