The Awchit and Cyder Railway
laurence703
- Dr. Bond of the DVLR
- Retired Director
Having visited the Leighton Buzzard railway with Laurence I then went on to have a quick steam up on the A and CR.
I took River Tang along, she behaved herself rather well, I think Laurence rather enjoyed it when he had a go.
I managed to set a record for the slowest lap at 2mins and 20 seconds non stop - I was rather pleased.
Next up came a comparison with the Roundhouse L and M loco.
Its a rather large lump of locomotive... The A and CR is a good example of what can be done in a small space - the rocky scenic section at the bottom with the pond is my favorite - a good railway for sitting and watching the trains go by with a cup of tea. Thanks go to Laurence 703 for a good day!
laurence703
It's been a while and I've been busy...
I've added in the last bridge, its not exactly L&B friendly but it is leek and manifold friendly but that'll be changed in time.
Also a small amount of ballasting has happened, its loose stone chippings I found on a siding at work...
Jaws the snowplough has been modded once more and acts as a great ballast plough... still... I have a rubber strip to add.
My other half's Bertie certainly looks the part...
The sweet pea tunnel / over bridge is in full swing...
And finally, running in winter has never been so easy! especially with the honeysuckle being no more!
That's it for the time being... the line's first open day is Saturday so everything will be tested... Probably going to need more sidings... there is a plan that involves much destruction of the shed...
laurence703
It is indeed... My Dad goes into shed and passes stuff out... Shed is removed and the roof kept... decking replaces shed and roof goes above decking... Current sidings removed and ramp put in to slightly raised steaming bays on decking with stock sidings underneath... Could possibly extend mainline from waterfall to the stock sidings...
IrishPeter
laurence703
- Soar Valley Light
laurence703
LnBmad
laurence703
Apologies.. Life's hectic... Ok so blue Bertie has a new home with LnBmad... And I have another Bertie but this time it's crimson lake. Also superior has returned from the wizard of wigfa with an overhauled bottom end.
On the railway front, Awchit station has gained a water tower and there are plans afoot to slightly extend the railway... By blowing up the shed...not literally of course, it's just I hate it and want it gone as it takes up too much room in the garden and is full of spiders... So with it gone the pond's waterfall will move around a bit and the line from Cyder station will curve away from the current route and around the fence line... This means that the removable bridge section will become redundant, but not completely useless as I have plans for it that involves a bit of chopping and changing. With some luck it will improve the look of the garden and give some more space. This means that my two long sidings in front of the shed will go and be replaced by the mainline so a new location for the sidings will be sought out after the demise of the spider cave... A new cupboard will appear on the patio above 50p corner giving the possibility of a short tunnel... Got to have somewhere for the lawnmower and strimmer...
laurence703
- Soar Valley Light
