Newqidas on the Block
- IrishPeter
Re: Newqidas on the Block
I didn't think it was THAT obscure! The Wikipedia article is a bit skewed, by the way, as the author tended to avoid Evangelical commentaries on the Articles.
Anyway... the first Newqida got a coat of dark green this evening which means that Eau d'Nil is now inevitable. I decided that the 1945-1955 livery gave me a bit more wiggle room when it comes to the mythical history of the Skebawn and Castleknox, though I will follow the top stripe only style favoured on the Cavan and Leitrim. I suppose I had better start looking for someone to make some Eau d'Nil class numbers and door numbers. Narrow Gauge was a bit hit and miss on the old Flying Snail! I am now trying to think of some other ways to 'Irish them' as at the moment they just look vaguely less German. Next job is to reset the Norwegian couplers at 33mm.
The second NQ started loosing its German lettering and data plates this evening, but will not be dismantled until the first one is reassembled. Norwegian chopper couplers are inevitable, but as this one is due to go to the 32mm gauge side of things they will be set at 24mm.
Peter in Va.
Peter in Va.
For reasons I can't put my finger on I've always really like the Flying Snail logo. Not much call for it on my Welsh Highland carriages, but maybe I could apply it to a spare Big Big Train tipper?!IrishPeter wrote: ↑Thu Sep 20, 2018 4:56 am Narrow Gauge was a bit hit and miss on the old Flying Snail!
Looking forward to seeing pictures of the finished carriages in due course...
- IrishPeter
One oddity of the CIE was that whilst they seemed to stick the Flying Snail on just about everything, even narrow gauge carriages! It was something of a design classic, unlike the Broken Wheel which succeeded it. Thankfully, they were a lot more sparing with the Broken Wheel. I only remember it on locomotives and some wagons, never on a railway passenger vehicle, though it appeared with some frequency on buses.
Irish Rail's logos - except for the original "Set of Points" (1988-92 vintage) - have all been a bit laughable. The language police got rid of the original brand - which was based on the English name, though if someone had been quick they could of argued that the set of points stood for Iarnrod not Irish Rail . The stylized IE of the nineties and noughties was usually referred to as 'the Plug' whilst the latest logo looks like something for a cell phone app, but I have not heard what the gricers are calling that one!
The various liveries had nicknames too - the forty shades of green being a humorous reference to the 1940s and 1950s CIE liveries as they aged, younger modellers call the 1960s black and orange/golden brown livery 'black'n'tan' thanks to a much repeated anecdote, and the original IE livery is referred to as tippex thanks to the white stripes applied to the old Supertrain livery. Surprisingly, the variant of the orange and black livery that adorned the Mk 2ds and the Mk3s usually got its proper name 'Supertrain.' God alone knows how that happened! The old GSR Dark Grey livery now seems to get called 'Sheep Dip' as it looked as though the loco had been dipped like a sheep, and then had its buffers picked out in red!
English Enthusiasts always look a bit confused when you used to describe something as being "tippex with the plug logo." Much of my gricing in Ireland was done on Baby GM hauled trains of tippexed Cravens and Mk.2s, including a real hellfire run behind a late departing pair of Babies on the Friday night train to Ballina. The scenario was 10 Cravens, 700+ passengers, and the on time 90mph Mk 3 set right behind!
Peter in Va
Peter in Va
- IrishPeter
P.s. Spite prevailed. I will see if I can get a photo tomorrow.
Peter in Va
Peter in Va
As in you've gone for "black and tan"? Wow!!! Looking forward to seeing that...IrishPeter wrote: ↑Fri Sep 21, 2018 4:44 am P.s. Spite prevailed. I will see if I can get a photo tomorrow.
Peter in Va
Slightly highjacking - is it possible to fit chopper couplings to the Newqida coaches?
Chris Auckland
- IrishPeter
Two possible methods. If you can go with a low buffer/coupler height it is possible to bolt the buffer straight to the arm that held the original LGB coupling. Otherwise one needs to alter the end of the vehicle to create a solid buffer beam so you can attach the whole coupler complete with its box.
Now I will go away and see if I can think of a third.
Peter in Va.
- IrishPeter
I think the Black and Orange livery suits them quite well. I chickened out on trying to paint the window frames black - at least for now. CIE rarely (if ever) left metal window frames bare metal. A little bit of attention with an old knife blade is needed to remove slight over spray, then I can add some small white numbers at either end of the golden brown band. The golden colour is a bit bright, but will tone down when I eventually weather the underframe and lower panels.
Next question is - do I reinstate the mould plastic interior, or fit it with longitudinal seating as with the change of scale from 1:22.5 to 1:20.3 the length of each seating bay is reduced from about 4'9" to about 4'4", which is getting into the same knee-knocking realm as "Festobahn" 21 and 22! If I don't use the plastic interior for the two black and orange NQs they can be recycled into the wooden bodied 'heritage stock' for the outdoor line, so nothing wasted!
I am now trying to decide if I do the other CIE conversion, or the first of the 2'6" gauge carriages.
Peter in Va
Peter in Va
- Attachments
- CIE stock1.JPG (300.51 KiB) Viewed 5891 times
Peter, TBH I couldn't imagine the newqida's in black & orange, but I have to say that's really impressive. Well done. It certainly suits them and you've done an excellent job.
Love the black and orange, doesn't sound like it should work but absolutely does! Similar to the WHR/FRs odd yellow and grey livery for PW items
Chris Auckland
- IrishPeter
The conclusion of the matter was that they get longitudinal bench seats for their role as CIE rebuilds. 63mm is about 4' 2.5" in 15mm scale, which is too much of a 'knee zipper' to be tolerated. One nice follow-on project would be a 'pre-rebuild version' based on the high arc roof vehicles built for the BC&RBR in the 1880s with ten small windows rather than seven slightly bigger ones. Not that I need any more projects...
Still brewing on whether the next vehicle will be for the outdoor line or the other CIE rebuild.
Peter in Va
Peter in Va
I think the colour combination looks brilliant and it stands out from the rest of the usual colours you see…
Well done Peter.
Well done Peter.
- IrishPeter
The last comment - about the BC&RBR - has me wondering if the brake van I built to their design survived the move, or whether it was one of the early scratch builds that I pitched to save space. They were a bit primitive when compared to many of the passenger vans but they lasted until 1940-ish.
Peter in Va
Peter in Va
I do like the look of that! A brave and bold decision, but I reckon it's paid off...
