Stuart's occasional loco thread - Boot Lane Works 'Lilibet'
Re: Stuart's occasional loco thread - Boot Lane Works 'Lilibet'
Post by Andrew » Tue Apr 16, 2024 12:51 pm
I like that very much, a lovely little loco!
StuartJ
Post by StuartJ » Tue Jun 11, 2024 1:26 pm
So, pretty much done apart from a few details. I have plans for an alternate set of buffer beams with side buffers, and also a cab that wlll slot into the rear bufferbeams instead of the rail. The handbrake and reversing lever will stay unfixed until I have thought this through a bit more.
I have made the following changes to the basic kit:
  • Replaced bufferbeams with timber, and added neodymium magnets into frame stretchers to secure them
  • Replaced supplied couplings with H Jones Engineering FR Waggon buffers
  • Replaced all the supplied brass rod for slide bars, piston rods, handrails etc with steel
  • Wrapped most of the 3D printed surfaces with thin styrene to avoid sanding - cylinders, smokebox, tank wrapper, firebox wrapper, cab sides
  • Altered the cab arrangement to give a bit more space and different handrails
  • Replaced the supplied modern safety valves with a bonnet made from the lid of one of my father's insulin pens
  • Replaced the supplied brake column with a Cambrian ModelRail one
  • Added a Talisman/Trenarren Models reverser
There are 4x AAA Nimh batteries and a LocoRemote miniB in the tank for power and control.
Boot Lane Works Lilibet by Stuart, on Flickr
Post by Peter Butler » Tue Jun 11, 2024 4:36 pm
Very nice, I like that a lot!
Post by Old Man Aaron » Wed Jun 12, 2024 5:50 pm
Schmick. Real schmick. :thumbup:
Post by ge_rik » Wed Jun 12, 2024 6:53 pm
Lovely loco, beautifully finished :thumbleft:
Post by LNR » Thu Jun 13, 2024 1:49 am
A superb surface finish and great matt colours. Real museum quality.
Post by Lonsdaler » Sat Jun 15, 2024 1:27 pm
Nicely done.
StuartJ
Post by StuartJ » Tue Jul 02, 2024 6:41 pm
Thanks all. I've been able to make the second set of bufferbeams this week. These have side buffers instead, and also have a second magnet in the back of the beam so that they are held much more firmly. The buffers are the Cambrian ModelRail 'modern' Talyllyn buffers backdated with some plywood discs (ex Timpdon Models carriage roof vents). The drawhooks are from Tenmille as the Cambrian ones were even bigger.
The LocoRemote MiniB fits neatly in the boiler, attached to 4xAAA Nimh batteries with a sticky pad.
Post by ge_rik » Tue Jul 02, 2024 7:06 pm
Beautifully finished. Not just outside but inside as well.
Post by drewzero1 » Tue Jul 02, 2024 9:59 pm
I think the switchable bufferbeams are a great idea! Both sets look like they've turned out well. Interested to see what you come up with for the cab. :scratch:
Preseli Chris
Post by Preseli Chris » Tue Jul 02, 2024 10:45 pm
Hi Stuart.
Just Come across your build thread and very good it is too.l noticed Captain Haddock on the footplate. One wouldn't be able to tell your locos are of plastic construction due to their fine finish. You have done an excellent job on them .l also have problems with the Revell Contacta glue. It can be really frustrating when it dries up in the needle applicator. Although I usually forget to put the cover back on .I use a peco fine track pin to clear the blockage and swap the end of the needle so the poly glue dissolves the dried up glue . We all suffer from low modelling mojo from time to time . Good to see you have got yours back.
Chris.
Yr Tren Nesa Wedi Mynd
Post by Andrew » Thu Jul 04, 2024 1:20 pm
What a lovely loco - and beautifully finished too!
StuartJ
Post by StuartJ » Sat Jul 13, 2024 11:48 am
Thanks all
I suspect that 4xAAA may be too high a voltage, going from initial testing across the carpet! I hope to take it to an open day at the end of the month, where I can test it properly on an actual railway (I live in an apartment).
drewzero1 wrote: Tue Jul 02, 2024 9:59 pm Interested to see what you come up with for the cab. :scratch:
Ideally it needs a proper Manning Wardle wrapover cab, but that would need to be brass which is beyond my skills and facilities. Some options/inspiration below; given that it will be removable I can always make more than one!
StuartJ
Post by StuartJ » Mon Jul 29, 2024 2:14 pm
A visit to the lovely Barle Valley Railway on the weekend provided an opportunity to test some of stock I have been building over the past few years. The Manning Wardle performed faultlessly, although it did display some hunting when running cab first which caused Driver Haddock to wobble off, narrowly missing the pond!
20240728_145403 by Stuart, on Flickr
20240728_145602_1 by Stuart, on Flickr
The performance of the Brush battery loco was rather disappointing, until I realised that it was slipping badly. I left off the weights included in the kit, reasoning that the change from a small LiPo battery to 3x AAA would make them unnecessary but clearly I was wrong. Easily fixed though.
Post by Andrew » Mon Jul 29, 2024 2:40 pm
That loco and landscape combo is the very essence of garden railwaying - just lovely...
Post by Old Man Aaron » Thu Aug 01, 2024 3:50 pm
Superb work all round. :thumbleft:
StuartJ
Post by StuartJ » Fri Aug 02, 2024 1:44 pm
Thanks both
I can't take any credit for the railway though!
https://centralsomerset16mm.wordpress.c ... -78-scale/
I visited this line as a child back in the late 1980s (when it was still 16mm scale) and it's been in my head as the ideal garden railway ever since. It's very much a "railway in a landscape" - @Andrew Your line reminds me of this, especially the section down the bank past the pw hut/coach
StuartJ
Post by StuartJ » Fri Apr 04, 2025 10:48 am
Some progress on the cab. It proved hard to cut the large holes for the spectacle through thin brass sheet, despite the best (and very generous) efforts of a friend who offered to have a go at it. I had a brainwave though, and sent my CAD file off to Model Engineers Laser https://www.modelengineerslaser.co.uk/ which quicky produced the below blank.
Manning Wardle laser cut cab sheet by Stuart, on Flickr
I was able to bend up the brass blank using a large vice and some tube as formers; the bends aren't quite in the right place (too high up) so it's come out taller and narrower than intended, but it fits, it's square and it didn't snap so I have run with it! I have since made the lower section from styrene and the two halves are now glued together and ready for painting.
Post by Old Man Aaron » Tue Apr 08, 2025 3:54 pm
Very nice work in forming that, it suits the loco. :thumbup:
Post by ge_rik » Tue Apr 08, 2025 5:34 pm
Looks great!
