TVT - Start of Steam Operation
Re: TVT - Start of Steam Operation
Post by Old Man Aaron » Wed May 13, 2020 9:38 am
Beautiful modelling and photos as always, Graeme.
Post by Andrew » Wed May 13, 2020 11:40 am
I agree with the others - lovely photos of lovely trains.
I really enjoy how the trains you run reference the real thing - although I don't think I'd want to fill those beautiful carriages with football fans...
Post by Old Man Aaron » Fri May 15, 2020 8:43 am
Andrew wrote: Wed May 13, 2020 11:40 am I don't think I'd want to fill those beautiful carriages with football fans...
I thought the same thing. One can only imagine the sheer amount of ongoing repairs to coaching stock during those days..
Post by GTB » Fri May 15, 2020 9:21 am
Andrew wrote: Wed May 13, 2020 11:40 am - although I don't think I'd want to fill those beautiful carriages with football fans...
The TVT is set in in the late 1920s, in a fairly remote part of Victoria. Football on Sat. afternoon and church on Sunday morning was basically all there was to do in winter, so a football excursion would be a family social event. It still is in rural areas.
Also every chance the local cop was in the club and kept the drunks under control, or kicked them off to walk home.
Post by GTB » Mon Sep 07, 2020 5:57 am
The track has been in hibernation during winter, but here 'spring has sprung and the grass has riz'......... As have the weeds......... :roll:
There were a couple of sunny days about a week ago, so committing some weedicide was indicated. 8 litres of Roundup later and I think I got all the capeweed, for a while anyway. The secateurs have also been busy and there is now a TVT structure gauge size hole in the shrubbery where needed.
The Hayden's tram loco has been back in the workshops lately to try and improve it's steaming. The cylinders have been lined down and a larger burner jet fitted, which seems to have improved things, although it still needs a lot more running in. At least the burner is more stable and it can now maintain pressure while running without being run flat out, but it's still a long way from being my favourite loco.
Anyway, yesterday dawned clear and calm, so it was a good opportunity to see how the loco ran on the track with a load. It usually pulls a string of timber bogies, but the side tipping wagons that I finished during the first shutdown have never had a run, so they were involved in this test run as well.
There is a photo of this loco late in it's life with the SR&WSC pulling a few side-tippers during the Hume weir construction, although by that time it had a proper cab and looked less like a traction engine and more like a railway loco.
The first photo shows the train heading north just entering the curve at the end of the long straight.
Seventeenth Steam Run 1.jpg (294.27 KiB) Viewed 48596 times
The second photo shows the train cooling down at the end of the run, back in the yard.
Seventeenth Steam Run 2.jpg (198.93 KiB) Viewed 48596 times
The run went well enough, so the loco has been added to the paint shop 'to do' list. A full degrease,then paint the new bits and touch up any wear/handling damage to the rest of the paintwork.
Post by FWLR » Mon Sep 07, 2020 9:32 am
Some brilliant photos Graeme, those side tippers do look very nice and impressive.
Worthy of a round of applause :hello1: :hello1: :hello1: :hello1: :hello1: :hello1: :hello1: :hello1: :hello1:
I know they aren't clapping, but they do look like they are.... :roll: :roll:
Post by ge_rik » Mon Sep 07, 2020 1:34 pm
For some reason, I missed the photos taken in May, so am just playing catch-up. I really like the look of that long goods train - but then goods trains are always far more interesting to my mind than passenger trains. Pleased to see you are managing to get outside and run trains again, Graeme.
Tropic Blunder
Post by Tropic Blunder » Mon Sep 07, 2020 4:09 pm
Those tippers look fantastic Graeme as does that converted steam tram. Are there any books that you know of detailing the state board of works projects and their railways? I've been looking for photos of the Perrys and the Malcolm Moores pre conversion but they're very thin on the ground.
Hopefully this fine weather continues for a while longer
Post by Old Man Aaron » Tue Sep 08, 2020 12:48 am
The tippers and Baldwin compliment each other well. Interested to see how the latest round of mods to the loco pans out over time.
Curious to hear how you go about degreasing a loco for touchup? I'd like to weather my Fowler, but wouldn't consider a blast with automotive degreaser, followed by hot water in the laundry tub, to be adequate surface prep.
Post by GTB » Wed Sep 09, 2020 2:15 pm
Old Man Aaron wrote: Tue Sep 08, 2020 12:48 am Curious to hear how you go about degreasing a loco for touchup? I'd like to weather my Fowler, but wouldn't consider a blast with automotive degreaser, followed by hot water in the laundry tub, to be adequate surface prep.
The loco is an Accucraft Ruby. It is already well into the zone of diminishing returns, so the running is now pretty much as good as it will get. :roll:
Anyway this is my normal paint touchup process after an overhaul/rebuild.......
First step is a good spray with car engine degreaser and then rinse off with water under the garden hose. That gets rid of most of the steam oil and associated crud. It may need to be repeated, if the loco is particularly greasy.
Then I give the areas to be touched up a going over with an old toothbrush and a liquid detergent and allow it to dry overnight.
Next day, it gets a coat of etch primer in any areas with bare metal showing, then wait an hour and touch up with the topcoat. All done with an airbrush. Then leave at least a week for the oil based enamel paint topcoat to cure hard enough to be handled and at least a month for it to become oil resistant before running it again.
Any new parts that require painting are removed and get a going over with the toothbrush, but with Ajax cream cleanser instead of detergent. Then ditto with the etch primer and paint.
I don't normally strip any paint off parts before a touchup, unless it is already flaking off. Although I use a fibreglass pencil, or a sanding stick to feather out the edges of any chips.
To do a full repaint, the model would need to be completely dismantled and individual parts cleaned in an ultrasonic cleaner, or with the toothbrush and Ajax for parts too large for my ultrasonic cleaner. The really greasy parts like smokebox and cylinders might need a shot of engine degreaser first.
The problem with a loco that has been running for a while is that oil has got into every crevice at the front end. If you try and degrease and clean it while assembled, the oil will still be in all the crevices and will continue to seep out. Especially if the model is warmed to get rinse water to dry quickly, or to cure the paint faster.
Unfortunately, I think a loco that has done some running would need to be stripped down for thorough cleaning before weathering, as it would be equivalent to a repaint in this context.
Belluva
Post by Belluva » Wed Sep 09, 2020 7:57 pm
Just read this thread from start to finish. Is a wonderful inspiration. Can only dream of your loco collection. The modelling of the wagons and coaches is great.
Post by Old Man Aaron » Fri Sep 11, 2020 5:09 am
GTB wrote: Wed Sep 09, 2020 2:15 pm Unfortunately, I think a loco that has done some running would need to be stripped down for thorough cleaning before weathering, as it would be equivalent to a repaint in this context.
Cheers Graeme, I was thinking much the same things, but always good to hear how others do it. Know just what you mean regarding your Ruby - at this point, I'm somewhat grateful that mine runs at all!
Aaron
Post by GTB » Sun Sep 05, 2021 5:45 am
It's been a while since I posted anything here. What with shutdowns, lousy weather and life's little vicissitudes there hasn't been a lot of train running going on around here. The last run was before Easter I think, when we were out of shutdown for a short time and the kids were able to visit.
Anyway, Spring has sprung around here and having pruned the shrubbery and blown all the dead leaves off the track, when we got a bit of sunshine, it was time for a test run......
The Motor Mule got the guernsey, as it was too windy to run a steamer, so the works train was assembled and it set off. The mule makes a good test loco, as it has narrow wheels (O gauge profile, rather than the G1 profile I prefer) that will find any track fault, but it managed to get around without any derailments. Although there are a couple of spots that need attention from the track gang, as some of the rail has walked with temperature changes and some gaps have closed, while others have opened up too far.
The first photo shows it coming off the bridge at the start of the run. The second pic shows it running along the back straight. The batteries were still charged from earlier this year and it ran happily for half an hour. It would have run longer, but that's about the length of my attention span...... :roll:
Tenth Run 1.jpg (195.88 KiB) Viewed 46638 times
Tenth Run 2.jpg (221.45 KiB) Viewed 46638 times
Post by GTB » Wed Dec 08, 2021 4:09 am
Spring has turned to summer, not that you'd notice hereabouts, as we are currently in a La Nina event. The Aust climate wheel of fortune has turned and we now have floods in areas that were deep in drought a couple of years ago.
Sunday was a nice day though, so the TVT was running trains for the first time in a while.
When I was a tin lid growing up in country Victoria, one of the highlights of this time of year was the annual Sunday School picnic, along with the Anniversary and the Christmas Party. Picnic Day was a public holiday in the district and at a time when many families still didn't have cars, excursion trains were organised. The following photos show the same sort of traffic on the TVT.
The first pic. shows one of the timber tram locos with their only passenger vehicle, hurrying the mill families through the sunlight towards the connection with the TVT excursion train.
Eighteenth Steam Run 1.jpg (296.57 KiB) Viewed 46253 times
The mill train has arrived at the sidings and is waiting for the TVT train to continue it's trip. The mill crew will then service the loco and reverse the train, before repairing to the local watering hole until the excursion returns. If you look closely you'll see a couple of Banksia men lurking on a branch waiting for any unwary passers by........ ;)
Eighteenth Steam Run 3.jpg (268.29 KiB) Viewed 46253 times
The excursion train has crossed the bridge and is rolling south across the river flats on it's way towards the picnic grounds, with the TVT's new passenger van bringing up the rear. Perfect picnic weather, 21degC, no wind and not a cloud in the sky...... 8)
Eighteenth Steam Run 4.jpg (331.46 KiB) Viewed 46253 times
It's now late in the afternoon and the train crews wait while the passengers sort themselves out for the trip home in time for tea.
Eighteenth Steam Run 5.jpg (295.92 KiB) Viewed 46253 times
Post by Andrew » Wed Dec 08, 2021 2:04 pm
Wonderful photos, thank you!
That four coach rake is quite splendid...
Post by ge_rik » Wed Dec 08, 2021 2:52 pm
Great looking models. Glad you're getting some sort of summer at last. Goodness knows what sort of winter we're in for .... :roll:
Post by GTB » Tue Dec 21, 2021 1:10 pm
Another day in paradise, 21degC, a light breeze and not a cloud in the sky............. :D
Lately I've been going through the TVT rolling stock and modifying the wheel sets to my free wheel arrangement. The bogie goods stock was finished some time ago, but I've now finished converting the passenger stock and the 4 wheel goods stock. The timber tram stock designs are harder to modify and generally run in short rakes, so there's not much gain from converting that. The modification means that all the TVT rolling stock now runs just as freely on curves as on straight track. https://gardenrails.org/viewtopic.php?f=39&t=12455
With the weather turning on a nice day for running a steam loco, the opportunity was taken to test run the modified 4 wheel stock. The roadside goods is heavy and needs one of the bigger locos, so Bogong, the Big Black Baldwin, was rostered for the trip.
Of course the boiler came up to pressure before the train was fully marshalled in the yard and in the confusion I forgot to have the camera to hand. So the first photo shows the train well into the run, leaving the northern end of the black forest for the second time and coming around the curve into the wye junction.
Nineteenth Steam Run 1.jpg (286.75 KiB) Viewed 46035 times
The next photo was taken a little later as the train was passing around the southern curve.
Nineteenth Steam Run 2.jpg (262.35 KiB) Viewed 46035 times
A bit later the train was photographed coming off the bridge heading south again. The air was a bit warm today for much in the way of steam effects, but there was a little exhaust steam to be seen.
Nineteenth Steam Run 3.jpg (255.67 KiB) Viewed 46035 times
This loco usually obligingly stops in an easily accessible part of the track at the end of a run. Today it decided not to co-operate, so it had to be towed ignominiously back into the yard by the Motor Mule. :roll:
Nineteenth Steam Run 4.jpg (236.18 KiB) Viewed 46035 times
Post by ge_rik » Tue Dec 21, 2021 2:40 pm
That's an impressive looking goods train, Graeme.....
A balmy 4.5C here today at its peak..... :shock:
invicta280
Post by invicta280 » Wed Dec 22, 2021 11:15 pm
Looks like a fun session, with the Mule earning its keep.
Post by Lonsdaler » Wed Dec 29, 2021 10:49 am
So nice to be reminded of what good weather is - feels like it's been murk and drizzle or rain here in NW England since October :dontknow: Your line looks suitably low maintenance and backache free 8)
