Peckett Body Build - First Attempt - NOW FINISHED Pictures page 6
- IanC
Re: Peckett Body Build - First Attempt
Steve,
The quality and speed of your work are incredible. Very well done. Very Impressive.
- -steves-
Thank you very much indeed for the very kind wordsBertieB wrote: Thu Feb 14, 2019 2:57 pm Wow. Iβve had enough problems attempting some of this stuff in plastic, let alone bleedinβ metalwork. Terrific.
(First kit I attempted was the easy-to-build, GRS plasticard version of a Peckett like this and even that just about drove me insane)
The basic shape and sizes are the same as the GRS 3D printed kit, so I guess the overall loco would look very similar when finished.
- -steves-
The speed was faster than I expected too, to be honest, it went quite smoothly compared to how I thought it was going to be. Thank you for the very kind words.IanC wrote: Thu Feb 14, 2019 4:23 pm Steve,
- -steves-
Thanks Graeme, coming from someone who can and has built in metal before, that means a lot. I have a great deal of respect for anyone that can do this sort of thing as I know for sure it's harder than it looks.GTB wrote: Thu Feb 14, 2019 2:26 pmThat has come up very nicely and there is really nothing that suggests it is a first attempt. I know I wouldn't have gotten it to that stage so quickly.-steves- wrote: Wed Feb 13, 2019 11:11 am I am thinking of doing it plain black, with brass a chimney top and brass spectacles. I am very open to ideas on paint at this stage as I have no idea what will look best, do you have any thoughts, if so, please do post up and let me know.
In terms of colour, black would match the diesel in your avatar.......![]()
If you are limited to whatever paint colours you can get in a spray can then weathered satin black like your diesel would look like a hard working, but well maintained loco.
If you use an airbrush then the world is your oyster and you can mix your own colours. I paint my black steam locos in four shades of black, in varying degrees of satin finish. The most recent example being this one.
https://gardenrails.org/viewtopic.php?f=36&t=11815
Colour I agree, a nice mat black would suit, maybe with red buffer beams and red connecting rods. I do have an airbrush, no idea how good it is as I have never used it. Had it for a few years now, that and a little compressor to run it on. I say I have one, but in fact I have two that came in a kit together, maybe it's about time I dusted it off, took it out the box and actually tried it
I will spend some time looking at your link to see if it gives me any pointers and direction for what I may be about to attempt. I usually use spray cans, so this will be a massive step if I airbrush it as well
The picture below is the avatar picture, my only ever attempt at weathering. Not sure how good or bad it was, but it just never looked like I had hoped it to look, it just looks dirty rather than weathered
Again Steve for a first attempt that's great, although maybe not to much rust on the chassis maybe. But all in all a great job...
I have seen worse Steve believe me..........
She looks great in her final form. As others have said, it's certainly not displaying any indications of a first effort. You'll maybe need to plug a few gaps with filler but I suspect even the most experienced modellers would need to do that. Can't wait to see here in workshop grey. I like Graeme's idea of fifty shades of black....
- -steves-
As you say, a touch of filler here and there, not sure what to do about the gap between the cab and the saddle tank, maybe run a small brass strip around the edge to fill it, that's what I do for diesels and say it's a rubber expansion strip, lolge_rik wrote: Fri Feb 15, 2019 8:29 am She looks great in her final form. As others have said, it's certainly not displaying any indications of a first effort. You'll maybe need to plug a few gaps with filler but I suspect even the most experienced modellers would need to do that. Can't wait to see here in workshop grey. I like Graeme's idea of fifty shades of black....![]()
It is also now completely wired up, obviously on plugs so I can remove it as need be, but it charges with the switch left and is on with the switch to the right, so that's all good
- -steves-
Like I said, weathering is not my thing, never been any good with a paint brush from early days. Give me a bit of wood, plastic or it appears now even metal and I am right at homeFWLR wrote: Fri Feb 15, 2019 7:18 am Again Steve for a first attempt that's great, although maybe not to much rust on the chassis maybe. But all in all a great job...![]()
I have seen worse Steve believe me..........![]()
We shall see how this new one goes, but the multi shades of black is looking like it's worth a try, maybe
Mmmmm, I little tip if I may Steve.
Try some weathering on a scrap bit of brass that's been well cleaned and build up has you go. You will be suppressed how quickly you can see it weather. You can also see how much or little you would need to use on your models.
It's the same with the multi shades of black.....
- GTB
I wouldn't worry too much about completely hiding the gap. The saddle tank on a real one is a separate self-contained part and there is a small gap between it and the cab on the preserved Peckett at Puffing Billy near Melbourne. The gap is also visible on the builders photo.-steves- wrote: Fri Feb 15, 2019 5:18 pm As you say, a touch of filler here and there, not sure what to do about the gap between the cab and the saddle tank
Main thing is to get the gap as even as possible and as narrow as you can manage. I had to manipulate the cab front a bit and slot a couple of screw holes to get a reasonable fit between cab and tank on my Hunslet, which was my first loco bodywork in this scale.
- -steves-
Thanks Rod, I will give that a go and see what happensFWLR wrote: Sat Feb 16, 2019 9:30 am Mmmmm, I little tip if I may Steve.
- -steves-
Unfortunately the gap is not even and I have already tried to minimise it as best I can. I think I will just leave it as is and put it down to a learning experience as I am still extremely pleased with the end result and the feedback I have had on it. The rivets should arrive some time next week for the buffer beams and after that it's the long haul of painting it.GTB wrote: Sat Feb 16, 2019 10:21 amI wouldn't worry too much about completely hiding the gap. The saddle tank on a real one is a separate self-contained part and there is a small gap between it and the cab on the preserved Peckett at Puffing Billy near Melbourne. The gap is also visible on the builders photo.-steves- wrote: Fri Feb 15, 2019 5:18 pm As you say, a touch of filler here and there, not sure what to do about the gap between the cab and the saddle tank
Can't wait to see it in grey and then black.
It's looking fantastic Steve. I wouldn't worry about the gap, it's small to begin with but once everything is painted with primer, a couple of top coats and varnish on top, it will disappear, especially if you do paint it black.
- -steves-
Thank you.philipy wrote: Sun Feb 17, 2019 8:13 am It's looking fantastic Steve. I wouldn't worry about the gap, it's small to begin with but once everything is painted with primer, a couple of top coats and varnish on top, it will disappear, especially if you do paint it black.
I agree, black should hide a lot of sins,
- -steves-
Had the rivets turn up today, 1/32 and appropriate drill bit, wow they are small.
Took the idea from Rik's Peckett as I really liked the rivets on the buffer beams. I drill all the rivet holes, added rivets, then cheated and super glued them from the back, cut off the protruding excess on the back with a dremel, then sanded the back of the buffer beams until you couldn't tell they had been there. Very pleased with the result, thanks Rik
The dark marks on the bottom picture is just dust from sanding, nothing that will be seen after paint
Nice job Steve.
Very neat and time consuming but well worth the effort.... looking great!
- -steves-
Thank you, your kind comments are really appreciated.
As I said, it's all going to be a tad quite now, got some time out and a lot of prepping and painting to do before anything is worth taking another picture of, though I did add some strengthening brass across the back and sides of the cab as a friend at our local club pointed out that all Pecketts had them, thanks Ian
I also, on his advice moved the rear lamp bracket to the centre
Though I have forgotten to put the front one on and its already in primer now, balloons!!
Oh well that's one for the epoxy after it's painted now, lol.
Thanks for the credit on the rivets, Steve. As an avowed non rivet-counter, I never thought I'd be responsible for guiding someone else's rivet positioning. It's an honour ( I think). To be honest, I just figured that the rivets would coincide with brackets attached to the main frames. I like to keep things simple. ......
