Building a Church
- planty
Jon & Jim, if only I had read your post earlier this week! :D
All the tiles are attached now, I spent a few days in the office this week with blackened fingers!! (thankfully no mishaps around the church, just on my hands). Invested in a box of surgical gloves for next time!
Will put up some posts of the church in situ soon, just got to test a rain shower on it to work out where there needs to be some drainage working into the model.
JCSteam
By drainage do you mean actual guttering that works? The flat roof parts will be a tough one, as there should be a over shoot to the roof below, then a hopper either end of each apex with a downpipe to the ground, of course on any straight bit of roof striaght guttering with downpipes down the walls will do just fine, have you started ground works on the drains
- planty
- TonyW
Superb!
- planty
As you can see from the finished pictures on the previous page I went for drainage channels on the lower roof to shift as much water from the roofs off the side.JCSteam:119603 wrote:By drainage do you mean actual guttering that works? The flat roof parts will be a tough one, as there should be a over shoot to the roof below, then a hopper either end of each apex with a downpipe to the ground, of course on any straight bit of roof striaght guttering with downpipes down the walls will do just fine, have you started ground works on the drains :lol: ;)
The flat roof I'm not too worried about as there are gaps round the edge and the model if hollow so it shouldn't trap standing water.
The towers have a drainage hole in the centre of the top and then holes at the base.
I thought about putting some drain pipes in (I did on my station built a few years back), but if you look at photos of the real church a lot of the water was just dispersed outwards rather than taken down drain pipes. I thought about doing this for the towers too but decided it would be too fiddly! :D
- Dr. Bond of the DVLR
- Retired Director
IrishPeter
- planty
- planty
- planty
- planty
