Post by Peter Butler » Sun Apr 25, 2021 10:19 pm
My Transporter Wagon is progressing, but more slowly than usual due to other gardening commitments. This is yet another of Jerry's well thought out kits which, despite the limitations of space, he has managed to fit superb bogies, each containing seven ball-race bearings for free and stable running, while still being able to negotiate fairly tight curves.....
Post by Peter Butler » Mon Apr 26, 2021 9:42 pm
The two wagon kits have the positions of all rivets carefully engraved which could be sufficient to show after painting, however, I chose to apply 'Nail-art' rivets to enhance the appearance, so, armed with a pot of glue, a cocktail stick and a glass of suitable lubrication (for me, not the model), I managed to attach 606 of the little beasties in one sitting!......
You can also see the chequer-plate I fitted to the side walkways. I'm unsure this was as on the original but I like the look of it.
Jerry
Post by Jerry » Mon Apr 26, 2021 10:39 pm
To easy Peter, :) I will have to add more rivets on my next creation ( girder bridge :roll: )
Post by FWLR » Tue Apr 27, 2021 8:42 am
Wow that is some patient you have there Peter. It really does make the model stand out though. Brilliance once again from you... :salute:
Post by ge_rik » Tue Apr 27, 2021 9:13 am
Wow! That's going to look great! Have you decided where to site a length of standard gauge track at the end of a siding?
Post by Lonsdaler » Tue Apr 27, 2021 1:10 pm
I really like the way this is shaping up Peter, and so many rivets allows a meditative state to develop whilst you work.
Post by Peter Butler » Tue Apr 27, 2021 10:20 pm
ge_rik wrote: Tue Apr 27, 2021 9:13 am Wow! That's going to look great! Have you decided where to site a length of standard gauge track at the end of a siding?
I do have one siding where I can install a loading bay or transfer site? It would just be a symbolic gesture only as there wouldn't be room to off-load the wagons, even if I could separate them as they are secured to prevent separation at inappropriate times.
I'm sure I mentioned this previously, the track gauge on the original transporter wagon, a pre-built GRS kit, came with a tanker wagon (Newqida) with its wheels set to maximum width within the axleguards. Due to this the load gauge is less than standard gauge, but more than SM32, so it looks acceptable, though not 100% correct. I see no reason why two narrow gauge lines of differing gauges should have a problem with this set-up.
Post by FWLR » Wed Apr 28, 2021 8:07 am
Correct me if I'am wrong Peter, I usually am.... Wasn't there a thread somewhere that mentioned and showed some photos of a transporter wagon showing it in use... :dontknow:
Post by Peter Butler » Wed Apr 28, 2021 11:43 am
The Leek and Manifold videos have a few images of the transporter wagon in use, this shows one being manually loaded....
https://www.youtube.com/watch?v=cDFURJZJfvs
Post by FWLR » Thu Apr 29, 2021 7:35 am
Thats the one Peter. Thank you for reminding me.
Post by Peter Butler » Fri Apr 30, 2021 10:30 pm
I think this project is finished now, all painted, weathered, lettered etc. and ready for its official portrait.....
The two transporter wagons have slight differences in design, as would happen in reality during service, however, they look perfectly well together and make an interesting feature on my preservation line, where anything goes!
Jerry's kit has been a real pleasure to build and adequately detailed to suffice without modification. I have added rivet heads (as previously mentioned), chequer plate footways, manually operated brake wheels at each end and brake-pipes to match the GRS wagon. All other detail parts are included in the kit, buffers, coupling hooks and chain and all brake gear components.
I am undecided about a load, could be just chains after delivery of something? They must run empty at some point!
georgesheppard
Post by georgesheppard » Fri Apr 30, 2021 10:41 pm
The rivet detail really makes this model! I love the great western detailing on the payload wagon.
Where do you buy the chequer plate from? I was looking for something similar only last night, is it something like this? https://www.hattons.co.uk/46143/plastru ... etail.aspx
Post by Peter Butler » Fri Apr 30, 2021 11:04 pm
Thank you George, in answer to your question.... I have no idea! During my many years of exhibiting I have stumbled on so many things at shows which I think would be useful one day, and this is one of those. Most likely it was amongst a selection of random embossed sheets and it caught my attention? I think it is probably made for 7mm scale, but it looks fine to me.
Perhaps someone with connections to the 'Gauge 0 Guild' might be able to help?
Post by philipy » Sat May 01, 2021 5:40 am
Beautiful wagons as we would expect from you Peter, well done.
Having said that, I'm slightly bemused by the livery of the load wagon. I realise that the BURPS is a preservation line and being your railway Rule 1 applies, but surely no preservation group would paint a GWR vehicle in a greenish shade, with a loco livery style "Great Western" and none of its correct wagon markings!
Post by ge_rik » Sat May 01, 2021 8:04 am
They look great together, Peter. Agree with previous comments about the quality of the level of detailing.
Antics sell plasticard 1/25 scale treadplate. Not sure if this is what Peter used.
https://anticsonline.uk/Product/Slaters ... N108390953
Post by FWLR » Sat May 01, 2021 8:31 am
I love them. Brilliant detailing as usual from you Peter. You do set high standards for us, which one day I may get to achieve.
Post by Peter Butler » Sat May 01, 2021 11:43 am
I think that's it Rik, good to know, well done.
Post by Peter Butler » Sat May 01, 2021 11:59 am
georgesheppard wrote: Fri Apr 30, 2021 10:41 pm The rivet detail really makes this model! I love the great western detailing on the payload wagon.
Post by philipy Β» Sat May 01, 2021 4:40 am
You can't please everyone!
The next one will be pink!
Post by Phil.P » Sat May 01, 2021 12:47 pm
I have a Grand Daughter who will be well-impressed, if it is, Peter!
Post by GTB » Sat May 01, 2021 2:35 pm
Peter Butler wrote: Sat May 01, 2021 11:59 am The next one will be pink!
Following the principle that there is a prototype for everything..........
https://www.flickr.com/photos/87791108@N00/4140437880
The loco is now running in preservation, but the preservation group don't have a sense of humour and have repainted it into something resembling the old VR blue and gold livery.
Users browsing this forum: Jbs and 13 guests
