Diesel Outline...
- dewintondave
Re: Diesel Outline...
Here's a photo of the available space and current gas feed arrangement
Best wishes,
Dave
Dave
Left hand side looks like you could fit a Roundhouse type gas tank?
Your live diesel is huge, I love it!
I will be emailing you Dave for the pdf plans. Have you updated them also.
I love the clatter, it sounds brilliant. You would think it was a Diesel.
Would it be able to run 32mm.
- dewintondave
That's it Tom, that's what I'm thinkingtom_tom_go wrote: Wed Oct 31, 2018 9:15 pm Left hand side looks like you could fit a Roundhouse type gas tank?
It is, I'm looking forward to seeing the Hunslet alongside it
Best wishes,
Dave
Dave
- dewintondave
Hi Rod, they aren't my plans but LBSC's from the 1930's which I used for the outline and the general layout - he used a gramophone worm and gear. The original was a 32mm gauge - standard gauge loco. Mine could be re-gauged to be 32mmFWLR wrote: Thu Nov 01, 2018 6:38 am I will be emailing you Dave for the pdf plans. Have you updated them also.
Best wishes,
Dave
Dave
Morning Dave, or is it afternoon.
Just sent an email to you mate. Thats great for 32mm both waysβ¦
- dewintondave
Sent! It's morning nowFWLR wrote: Thu Nov 01, 2018 7:15 am Morning Dave, or is it afternoon.
Best wishes,
Dave
Dave
Would that be Friday morning Daveβ¦dewintondave wrote: Thu Nov 01, 2018 7:00 pmSent! It's morning nowFWLR wrote: Thu Nov 01, 2018 7:15 am Morning Dave, or is it afternoon.
Just sent an email to you mate. Thats great for 32mm both waysβ¦![]()
- dewintondave
- dewintondave
I was just having a look under the loco to see if there was any space
Best wishes,
Dave
Dave
Itβs so confusing Dave. On the forum it shows, Fri Nov 02, 2018 8:56 pm. I posted my reply to you at,Fri Nov 02, 2018 7:54 amβ¦Only 1 hour difference mateβ¦
You are 24 hours in front of us up here in the Northern Hemisphere arenβt youβ¦?
Anyway back to your loco. Are you thinking of R/C Dave. It looks a bit tight under there. But Iβam sure ge_rik could help with that. Or may be your quite capable yourself.
The front looks like your best bet but you might have to make your own tank unless an Accucraft one might fit?
- dewintondave
- dewintondave
Here's the original gas tank, a converted steam boiler. It could be put inside a tank wagon.
Best wishes,
Dave
Dave
- dewintondave
This afternoon I rearranged the gas valve to make it more compact. The dome on the top where the gas is drawn off
Best wishes,
Dave
Dave
That looks better Dave, why do you need such a large gas tank though?
- dewintondave
It was a pleasurable repurposing of the boiler Tom. And it works well with not getting too cold with the gas expansion due to its size
Best wishes,
Dave
Dave
Thanks Dave for putting me straight.
So what are your plans for underneath, if any mate.
- dewintondave
dizzysteamer
HI Dave I,m very impressed with your building work and your clever idea's as a newbie to steam loco's I am finding bit interesting seeing idea's put into practice
Well done
dizzysteamer
Well done
dizzysteamer
