16mm Scale Rule
I've had a very nice reply to an Email I sent to John Angell enquiring about possible use of his original artwork for a scale ruler.
I've pasted a relevant comment below, what do fellow Forum members reckon?
The problem with posting a scan of the artwork on a group website is that no two printers seem to be set up quite the same. I know my printer will print at 100% to scale, because that's my job at stake and I have everything set up correctly. However, unless both the scaling and the number of pixels to the inch are right, and the printer is completely reliable, trouble will ensue. What do you think?
Alternatively, look out for an old imperial 5/8" scale rule, with each 5/8" divided to represent 12 inches! (Thus two feet scale 1 1/4", = O gauge. They turn up on eBay from time to time.
- Sir Clothem Cap
MoelygestLR
I have to deal with this a lot, printing scale plans of buildings out from CAD programs sometimes. There are a lot of problems and iv found unless you have the specailist lay out software (I use adobe InDesign, but there will be others) problems may occur.
Indesign will allow you to scale the artwork of the ruler to ensure that it is to scale on the computer file then you can save it as a pdf which will save these settings and print it off.
of course as mentioned it does mean you have to have your printer set up correctly! all in all tricky (and not necessarily cheap!)
Re: 16mm Scale Rule
Just seen this thread and it is still gone straight over my headβ¦β¦β¦
Re: 16mm Scale Rule
Looks like handbags at dawn over a scale ruler. Can't see the fascination with a ruler that has fooot indicators every 16mm...pretty basic if you are trying to scratch build something. Personally I would mark a steel ruler up if I wanted one.
Still confused Rod?
Still confused Rod?
Re: 16mm Scale Rule
Errrrm think I may have it Derekβ¦..
Taking some time though to computeβ¦.
Re: 16mm Scale Rule
When N gauge modelling it would be having a ruler with 1 2 3 4 Etc at 2mm spacing, for oo gauge at 4mm spacing...I've done the computing for you
Re: 16mm Scale Rule
Thanks matebazzer42 wrote: Sat Jun 02, 2018 9:46 am When N gauge modelling it would be having a ruler with 1 2 3 4 Etc at 2mm spacing, for oo gauge at 4mm spacing...I've done the computing for you![]()
