Buying a resin printer - any advice?
Re: Buying a resin printer - any advice?
Post by ge_rik » Tue Oct 26, 2021 12:49 pm
Well, it looks ok and, as far as I can tell, all the bits are there.
Annoyingly, the resin which I ordered at the same time, is still n its way, so I can't test it out. But then, it will have to be put away until Christmas ..... :(
Post by philipy » Tue Oct 26, 2021 1:26 pm
ge_rik wrote: Tue Oct 26, 2021 12:49 pm
Just a thought, you've mentioned buying the resin a couple of times but have you also ordered a fairly large quantity of IPA for the washing?( Unless you've got water washable resin, of course). Plus you'll need large quantities of kitchen roll and neoprene/nitrile disposable gloves.
Post by ge_rik » Tue Oct 26, 2021 6:26 pm
Thanks Philip.
Yes, thanks to your thread on resin printing, I've got 5l of IPA on order. Hopefully it'll come at the same time as the resin. I already have a box full of gloves and a large roll of that blue paper towel, so I think I'm covered (literally and metaphorically).
I've set up the printer and washer in the workshop, powered them up and levelled the bed, so just awaiting the arrival of the resin and ipa.
Post by -steves- » Tue Oct 26, 2021 6:45 pm
ge_rik wrote: Tue Oct 26, 2021 6:26 pm Thanks Philip.
Only fill the IPA washer container to a max of just under 3L and top up as needed. The reason being is that the build plate has holes in the top and if the IPA goes in there it goes everywhere when you take it out, ask me how I know, lol :lol:
Post by ge_rik » Tue Oct 26, 2021 9:32 pm
-steves- wrote: Tue Oct 26, 2021 6:45 pm Only fill the IPA washer container to a max of just under 3L and top up as needed. The reason being is that the build plate has holes in the top and if the IPA goes in there it goes everywhere when you take it out, ask me how I know, lol :lol:
:thumbup:
Post by Trevor Thompson » Thu Oct 28, 2021 9:30 am
Very exciting!
What are you planning to make first?
Post by ge_rik » Thu Oct 28, 2021 12:19 pm
Trevor Thompson wrote: Thu Oct 28, 2021 9:30 am What are you planning to make first?
Hi Trevor
I thought I'd have a go at some of the detailing for my latest loco. I'd like to redo the safety valve and whistle cluster which came out poorly on my FDM printer with PETG. I'd then like to see if I can produce some re-railing jacks and clack valves and maybe some gauges for the cab.
I'm also going to have a go a designing and printing some little brackets to hold the reflector sheet in my flat screen TV. The backlight has failed (a common fault apparently) and rather than trashing it, I've ordered some new LED strips from China to replace the faulty ones. Trouble is, the brackets holding the reflector sheet on are very brittle and I can't get them off without them disintegrating. I'm hoping I can design and print some replacements.
Post by -steves- » Thu Oct 28, 2021 7:03 pm
ge_rik wrote: Thu Oct 28, 2021 12:19 pm
Hi Trevor
I certainly have some clack valves, whistles etc if you want the stl files? Might be like you want them?
Post by ge_rik » Fri Oct 29, 2021 6:53 am
-steves- wrote: Thu Oct 28, 2021 7:03 pm I certainly have some clack valves, whistles etc if you want the stl files? Might be like you want them?
Yes please
Post by Trevor Thompson » Fri Oct 29, 2021 9:38 am
I am sure you will have fun learning to use it, its a bit different to the filament printer.
It does produce some lovely detailed parts.
Post by -steves- » Fri Oct 29, 2021 6:58 pm
ge_rik wrote: Fri Oct 29, 2021 6:53 am
Yes please
Will mail you what I have, might be a starting point if nothing else :thumbup: Hope they help :D
Post by ge_rik » Sat Oct 30, 2021 7:34 am
-steves- wrote: Fri Oct 29, 2021 6:58 pm
Yes please
:thumbup:
R
Post by ge_rik » Sun Oct 31, 2021 9:34 am
My first resin print - the default test piece.
The level of detail is quite astonishing!
I might just sneak in a few more "test pieces" suitable for detailing my new loco before putting it away for Christmas....... ;)
Post by Peter Butler » Sun Oct 31, 2021 9:54 am
That is a beautiful piece of sculpture, shame not to use it on a garden railway, possibly outside a school or library building. Completely out of period for you Rik, but more recent structures would work.
Post by philipy » Sun Oct 31, 2021 8:05 pm
ge_rik wrote: Sun Oct 31, 2021 9:34 am My first resin print - the default test piece.
Yes, I remember feeling pretty much like that when my green version of that first lattice cube test piece emerged. :)
Post by ge_rik » Sun Oct 31, 2021 8:37 pm
From now on, i'm going to have to be a lot more careful with my fine detailing when drawing models.
