Festiniog Railway Welsh Pony - 3 D printed
Re: Festiniog Railway Welsh Pony - 3 D printed
Post by FWLR » Fri Jan 22, 2021 11:34 am
That is a superb 3d print of your boiler Trevor, very impressed with it.
Don't think I could attempt to be cutting any holes in mine though mate. Anne would be so upset and I don't like doing that for fear of reprisals... :lol :lol
Post by -steves- » Fri Jan 22, 2021 4:19 pm
Trevor Thompson wrote: Thu Jan 21, 2021 7:35 pm I think that the issue is printing in ABS. It is a very unforgiving material to print with. I have had problems doing roofs as well. Probably I should use one of my spare nozzles and get PLA for printing roofs and the like.
Wouldn't be a bad shout, PLA is much more forgiving for roof's, not sure I could print an ABS roof :oops:
Printing in PLA
Printing in PLA
Post by Trevor Thompson » Fri Jan 29, 2021 12:39 pm
I have most of the model ready to assemble - but I am not satisfied with the gears I have used to provide the drive.
They are rather noisy, perhaps this is the problem with cheap plastic gears.
Anyway the chassis as it stands:
It does run, but it makes an un-prototypical racket!
I have taken to fine tuning my wheels in the lathe. Mounting them on a mandril allows me to turn the tread to exactly the same diameter on each wheel, and clean up the flanges as well. It seems to overcome the occasional problems I was having getting printed wheels to run true. Note that the number of skin layers and infil density I am using is making these almost solid. They seem to turn as if they were solid material!
It is about time I cleaned and oiled the lathe!
Post by Trevor Thompson » Fri Jan 29, 2021 12:44 pm
I have also started to assemble the tender:
You can also see the connecting rods, coupling rods and slide bars ready to attach to the chassis in the background.
I am making a copy of all the components (after I successfully assemble each section) with a view to offering the locomotive as a kit of parts in the for sale section of this forum when I have it completed.
I am currently awaiting a tool to enable me to make my own worms and worm wheels from brass - which I think will solve the noisy gear issue!
Post by -steves- » Fri Jan 29, 2021 1:25 pm
Looking very good so far Trevor, can't wait to see it complete. :thumbup:
Post by ge_rik » Fri Jan 29, 2021 1:41 pm
Coming along nicely, Trevor.
I must try printing a roof, Steve, I've fought shy of it up until now. :pale:
Just had to replace the nozzle on my cheapo printer - my first major clog. Decided it was to gummed up to manage to clean it up properly. I suppose, after nearly a year, that's not bad.
Post by -steves- » Fri Jan 29, 2021 1:54 pm
ge_rik wrote: Fri Jan 29, 2021 1:41 pm Coming along nicely, Trevor.
Honestly, an upright roof comes out well. If in any doubt you can add a 1mm or 2mm wide support each side that just touches the roof, careful though, if the touching point is too small, it will just build separate structures, ask me how I know, lol. :oops:
As for nozzles, I replace mine most times it clogs. If upping the heat doesn't clear it, then it gets replaced there and then.
Trevor will know this one, I assume ABS doesn't clog in the same way as I printed ABS at 205 degrees by accident and although it didn't stick to the base board, it did leave an almighty mess of ABS all over the place overnight, lol. :oops:
Post by philipy » Fri Jan 29, 2021 2:17 pm
That is looking very good Trevor.
I assume the tender body is printed as 3 separate sides with the insides flat on the bed? The external surface finish looks excellent from what I can see.
Post by Trevor Thompson » Fri Jan 29, 2021 5:04 pm
I haven't had to replace a nozzle since I started using ABS exclusively.
Post by Trevor Thompson » Fri Jan 29, 2021 5:07 pm
philipy wrote: Fri Jan 29, 2021 2:17 pm That is looking very good Trevor.
Yes the tender was printed as 3 sides, a curved top, a base upside down on the bed, and two axle box sets. Tha axle boxes are joined by a stretcher so there is one print per side. I did think about making the springs work - but maybe next time!
Post by Trevor Thompson » Fri Jan 29, 2021 5:10 pm
The other comment I would make is that the quality of the surface of the prints is very good - probably the best I have ever had. The only difference is the supply of filament. I have been getting it direct from a company called PolyProps via their website.
Post by philipy » Fri Jan 29, 2021 5:21 pm
Cheers.
Post by Trevor Thompson » Fri Feb 05, 2021 6:12 pm
I have made my own brass worm wheel and stainless worm which I hope will be much more suitable for this model. " Free hobing " the worm wheel using an M8 spiral flute tap:
Of course to fit its I had to disassemble the existing wheels which had been secured to the axles with foaming polyurethane glue. Initially I couldn't move them on the shaft and thought I was going to have to make new wheels. After applying heat from a soldering iron onto the ends of the axles they came free quite easily. So the wheels are re-usable. I have put it back together with the new worm wheel and re quartered the wheels:
I will try it in the morning when the glue has cured.
Post by philipy » Fri Feb 05, 2021 7:21 pm
Trevor Thompson wrote: Fri Feb 05, 2021 6:12 pm " Free hobing " the worm wheel using an M8 spiral flute tap:
Beyond me I'm afraid but it certainly looks most impressive and I'm full of envy. :)
Post by ge_rik » Fri Feb 05, 2021 7:29 pm
Wow!!! This must be a first for the forum. Home made gears.....
Post by Trevor Thompson » Tue Feb 09, 2021 8:37 pm
I suppose the locomotive is essentially finished. I am now thinking about finishing touches:
I have created the nameplate, and am printing the handrails for the water tank - and they are not actually printing properly (yet).
In the early photos I can see that the loco has oval plates on the cab sides. I am looking for a photo of the original makers plate - can anyone help with that?
I can see that the second one is probably a Boston Lodge plate stating a rebuild. I wonder what that would have had on it prior to 1900? I have a photo of the current one of those so maybe that is a starting point.
And of course I can see a photo of the rebuilt engine in what looks like a dark brown. I presume that represents a result of research and should be the victorian livery. Of course what I want to find out is what livery would she have carried in the 1880's or 1890's?
Post by Andrew » Tue Feb 09, 2021 8:56 pm
Hi Trevor, that's looking great!
My book of 7mm FR drawings says that the Englands were probably delivered in a "deep red", which had "changed to a slightly lighter shade, sometimes described as brick red". Lined with a black band, bordered with gold or yellow...
I think I'm right in saying that WP's current livery, although lovely, isn't based on a historic one...
Hope that helps!
Post by philipy » Tue Feb 09, 2021 8:58 pm
Coming on well Trevor. Can't help with the details you are looking for but I'd guess that some of our Ffestiniog afficionado's may be abe to.
Post by Andrew » Tue Feb 09, 2021 9:01 pm
Ah, it changed again after the last Fairlies arrived in 1879 - more later!
Post by Andrew » Tue Feb 09, 2021 10:00 pm
Sorry, was in the middle of a telly programme with the family...
So... "The introduction of the last two Fairlies... heralded a period of more elaborate lining. The black band was edged with fine red, yellow and black lines, and the panels were bordered with a fine red line. It is certain that at this period the base colour of the locomotives was a deep maroon... The maroon lasted until the 1930s."
Sounds like the liveries currently sported by Palmerston and ME?
You'd better get the lining pen out!
