First time scratchbuild project - Bagnall steam loco
Tom85
Re: First time scratchbuild project - Bagnall steam loco
Post by Tom85 » Fri Jun 05, 2020 9:27 am
I haven't had as much time as I would like to work on the Bagnall recently (know the feeling, eh?) but have at least managed to get some work done to complete the chassis. The photo shows the underside of the chassis, now in primer, with the motor block removed for painting, with holes added for the various switches and connections. I spent some time deciding where these should go, given the loco's limited internal space. On the underside of the loco will be the DPDT switch (to switch between run and charge) and the charge socket. The speed controller will be mounted through the cab floor (hoping to disguise it as a handbrake standard) and the reversing switch on top of the tank extensions inside the cab. The inside of the boiler will house the 3x NIMH AA cells, which it's just the right diameter for. The temptation is to forget about all this and crack on with building the body, as I don't really enjoy wiring, but it certainly seemed wise to consider all of this before putting the whole thing together.
Also in this photo is the 'firebox' with a home-made regulator handle, so at least the driver will have something to hold on to. I'm also incorporating a light-up 'fire' using a flickering orange LED. Might come across as something of a gimick, but I think it will add a bit of interest and life to the model.
Hope everyone else's projects are going well, and wishing you a good weekend.
Tom
Post by philipy » Fri Jun 05, 2020 10:15 am
Looking good so far.
Yep, I agree its a good idea to get it all planned ahead ( something I'm woefully bad at doing, myself!) and as for flickering fires.. THAT I agree with 100%! :lol: :lol:
Garethh
Post by Garethh » Fri Jun 05, 2020 2:59 pm
This is looking ace, I can’t get my head around working with plasticard for some reason so am especially impressed!
Post by FWLR » Sat Jun 06, 2020 9:04 am
Plasticard is very easy to work with Garethh. You just need to take your time when cutting it. The possibilities are huge in modelling building and rolling stock. Have ago, you might be quietly suppressed. Have a look at Peter Butler's thread, just put a search in for his "Time to build a railway...but where" a little warning though, it's a very big thread.... :lol: :lol:
Tom85
Post by Tom85 » Sat Jun 06, 2020 1:15 pm
FWLR wrote: Sat Jun 06, 2020 9:04 am Plasticard is very easy to work with Garethh. You just need to take your time when cutting it. The possibilities are huge in modelling building and rolling stock. Have ago, you might be quietly suppressed. Have a look at Peter Butler's thread, just put a search in for his "Time to build a railway...but where" a little warning though, it's a very big thread.... :lol: :lol:
I agree. I've never worked with it before this project and have found it pretty easy to work with. Give it a go :)
Garethh
Post by Garethh » Sat Jun 06, 2020 3:29 pm
Cheers for the encouragement, maybe the next build will involve some plasticard!
Post by FWLR » Sun Jun 07, 2020 6:49 am
FWLR wrote: Sat Jun 06, 2020 9:04 am Have ago, you might be quietly suppressed.
Suppressed...... :oops: .....Surprised. :lol: :thumbright:
Tom85
Post by Tom85 » Sun Jun 14, 2020 4:49 pm
Hope everyone's having a good weekend. A quick update on this weekend's progress on the Bagnall. I've been adding overlays to the cab and side tanks using a method (as usual) picked up from Rik's blog. I used thin, oversized overlays of plasticard, with 'rivets' embossed in them with an old centrepunch, glued to the body and then trimmed to shape. In the photo, some parts are more or less finished but others still need to be trimmed and filed to shape (front spectacle plate).
Meanwhile, the boiler section has been completed and primered. I'm particularly pleased with the smokebox door, home-made from odds and ends. The dome, on the other hand, is a whitemetal item - the only non-homemade part I have so far used (other than the motor block). Sadly, no-one has yet put a dome specifically for a 16mm scale Rye and Camber Bagnall on the market yet (expecting a bit much there, I suppose) so finding one that looked right was a bit of a chore, specially since dimensions aren't usually given. The one I eventually found is for a Gauge 1 LNWR 0-8-0 apparently, from Walsall Model Industries. I think it looks the part, even if it perhaps isn't quite tall enough. The safety valve was made from offcuts of plasticard, masking tape, and solder wire.
Post by LNR » Mon Jun 15, 2020 12:25 am
Coming along nicely Tom, with the boiler in primer you can start to see what you've done. The smokebox door does look good.
Post by FWLR » Mon Jun 15, 2020 5:45 am
Great start on your loco Tom.
Can I help with a suggestion on the holes for the spectacle plate. If you have any wood drill bits, the ones that have the long point, you can drill the plasticard quite easily and get a better finish. I do mine secured on a wooden block with clamps and going slowly with the speed on the drill, it does do a much better finish and only needs some light rubbing with sandpaper or emery block. I use the nail files that women use and men if they admit it. :lol: :lol:
You can use normal bits, but they tend to bite the Plasticard and you end up ripping the card...And you never know, one day the wood bit may come in useful.
Tom85
Post by Tom85 » Tue Jun 16, 2020 9:00 am
Thanks for the idea Rod - I'll certainly invest in an appropriately sized wood bit for my next model.
The main panels are made of 1.5mm plasticard and I used a hole-cutter (the plumber's sort that you put in an electric drill) and they did ok, but not the smoothest cut. For the 0.5mm overlays that didn't work at all - just tore the material, as you say. I spent last night finishing them off by trimming the overlays bit by bit around the holes in the thicker material, and obtaining a smooth finish by wrapping some sandpaper around the same hole-cutter bit and using that as a sort of make shift reamer. All trial and error but got a nice smooth spectacle plate hole in the end
Post by FWLR » Wed Jun 17, 2020 8:35 am
Just remember though Tom, no matter which way or how you cut Plasticard, slow and steady is the best. Taking time to cut any material for building models is the best. For cutting Plasticard with a knife I always try to cut along a metal ruler that is clamped down on to the card if possible. And cutting away from the piece you want to use. It's so easy for the knife to slip, it sometimes has a life of it's own... :roll:
pandsrowe
Post by pandsrowe » Wed Jun 17, 2020 12:41 pm
One way of dealing with the problem of tearing in the thinner sheets of plastic card is to sandwich the card between two pieces of scrap timber, clamp together and then drill the required hole/s. I have done this on a number of occasions using whatever I had to hand, sometimes ply sometimes MDF and certainly on one occasion a couple of scraps of 2" x 1" battens. However that was when I was using an ordinary twist drill to make the required hole, normally a hole saw would not have enough depth of cut to go through the thickness of the batten.
Post by ge_rik » Wed Jun 17, 2020 5:02 pm
For some reason, I've missed the updates on this thread. It looks really interesting. Great to see the progress you're making and I'm really happy you've pinched an idea or two of mine (which I probably pinched from someone else).
Keep up the good work. So far so (really) good.
Post by Lonsdaler » Fri Jun 19, 2020 10:22 am
I've found this tool excellent for cutting circular holes in plastic sheet
http://www.olfacutters.co.uk/Olfa-CMP-1 ... ass-cutter
They sell sturdier versions too.
Tom85
Post by Tom85 » Fri Jun 19, 2020 10:42 am
ge_rik wrote: Wed Jun 17, 2020 5:02 pm For some reason, I've missed the updates on this thread. It looks really interesting. Great to see the progress you're making and I'm really happy you've pinched an idea or two of mine (which I probably pinched from someone else).
Thanks very much Rik! As I've said before, the loco building section of your blog was both the inspiration for, and a lot of practical help with, this project. In particular the Southwold 2-4-2T project. I wouldn't really have known where to start without it. Without experienced modellers sharing their experiences, newbies like me would never get started.
If you do decide to have a go at scratchbuilding one of these, I'd love to see how you get on. They are really appealing little locos and I'm sure you'd do a great job with one. As for me, I'll keep everyone updated with my progress but I do seem to suffer from 'grassfire syndrome', i.e. as soon as I get stuck into one project, I'm already planning the next one, or several...
Tom85
Post by Tom85 » Fri Jun 19, 2020 10:48 am
Lonsdaler wrote: Fri Jun 19, 2020 10:22 am I've found this tool excellent for cutting circular holes in plastic sheet
OK just ordered one of these. Good find Phil, cheers
BorisSpencer
Post by BorisSpencer » Fri Jun 19, 2020 11:00 am
FWIW:
I tend to use a punch to cut round holes in plasticard, I inherited quite a range from my grandad many years ago.
They also have the advantage of creating a disk which can then be used as fuel filler caps etc.
Post by ge_rik » Fri Jun 19, 2020 11:17 am
BTW If anyone isn't familiar with the Rye and Camber you might want to browse through an account of my visit to the trackbed from seven years ago on my (other) blog.
http://ngruk.blogspot.com/2013/04/rye-a ... amway.html
Considering it's been defunct for seventy years, there's still plenty left to see including some of the original rails.
I've included quite a few public domain archive photos on the blog post which show just how exquisite the little Bagnall locos were.
Tom85
Post by Tom85 » Mon Jun 22, 2020 6:08 pm
A quick update. The cab / tanks assembly has now been given a first coat of primer, after which I've been applying filler to rectify small deficiencies, mostly around the spectacle plate inserts (made from strips of 0.5mm plasticard). Also shown is the underside, with M3 square bolts added. I decided it would be a good idea to be able to detach the body from the chassis easily, in case of any future wiring problems (quite likely given my soldering 'skills') or, perhaps, the addition of radio control.
