Remodelling Bulkeley Station
Re: Remodelling Bulkeley Station
Post by FWLR » Thu Feb 13, 2020 7:59 am
So do I Tom.... :thumbright: :thumbright:
Post by ge_rik » Sat Feb 15, 2020 1:05 pm
I've now finished widening the raised bed at Bulkeley reduce the precariousness of the siding at the front of the bed.
More info on the landscaping here.......
https://riksrailway.blogspot.com/2020/0 ... keley.html
Post by Peter Butler » Sat Feb 15, 2020 1:55 pm
Whilst out walking the dogs, I couldn't help thinking about your current progress in railway construction.... here in West Wales we are in gentle breezes and light rain (I don't like to exaggerate!) courtesy of 'Dennis', whilst I picture you outside in shorts and sandals, with transmitter in one hand and sipping chilled beer from the other.
From the picture posted above it looks as though I was correct?
Post by tom_tom_go » Sat Feb 15, 2020 2:55 pm
Looks great Rik, the weather in Kent is awful at the moment.
Post by ge_rik » Sat Feb 15, 2020 4:22 pm
Peter Butler wrote: Sat Feb 15, 2020 1:55 pm Whilst out walking the dogs, I couldn't help thinking about your current progress in railway construction.... here in West Wales we are in gentle breezes and light rain (I don't like to exaggerate!) courtesy of 'Dennis', whilst I picture you outside in shorts and sandals, with transmitter in one hand and sipping chilled beer from the other.
Ah! Not quite. You might notice the frost on the ground in a couple of pictures of the raised bed under construction - and Dennis is rearing his head as I write this.... :shock:
Post by FWLR » Sun Feb 16, 2020 8:17 am
I really do think you explain how to do a proper job on building retaining walls Rik. It's the same principle I would imagine to build any wall. Get the foundation right and you are half way there.
Thanks Rik for another build, brilliantly explained in your excellent Blog
Post by ge_rik » Sun Feb 16, 2020 9:25 am
FWLR wrote: Sun Feb 16, 2020 8:17 am I really do think you explain how to do a proper job on building retaining walls Rik. It's the same principle I would imagine to build any wall. Get the foundation right and you are half way there.
Thanks Rod
I try to remember what I needed to find out when I started building my railway and then share what I've learned in case others need similar info. My dad taught me how to mix concrete and lay bricks when I was a teenager and I always think of him when doing jobs like this. I can still hear his voice if I put too much water into the mix - "Don't let the liquor get away!"
GAP
Post by GAP » Mon Feb 17, 2020 9:29 pm
ge_rik wrote: Sat Feb 15, 2020 1:05 pm I've now finished widening the raised bed at Bulkeley reduce the precariousness of the siding at the front of the bed.
Looks good Rik Lots of possibilities for a new scene to be built on the newly acquired land.
Next step a bit more brick work to blend the 2 walls on the right hand end together this will remove that angle area that will cause an issue with the grooming of the lawn, unfortunately a bit of land will have to be sacrificed to do this.
That would be the excuse I would use for another land grab disguised as an improvement.
Post by ge_rik » Tue Feb 18, 2020 9:10 am
GAP wrote: Mon Feb 17, 2020 9:29 pm Next step a bit more brick work to blend the 2 walls on the right hand end together this will remove that angle area that will cause an issue with the grooming of the lawn, unfortunately a bit of land will have to be sacrificed to do this.
:thumbup:
Sounds like a good plan to me .......
GAP
Post by GAP » Tue Feb 18, 2020 10:23 am
ge_rik wrote: Tue Feb 18, 2020 9:10 am
:thumbup:
So work starts next week then?
Post by Peter Butler » Tue Feb 18, 2020 10:44 am
Why wait until next week? Rik appears to live in Shangri La there, sheltered from the storms we are enduring elsewhere.
Post by ge_rik » Tue Feb 18, 2020 5:36 pm
A few more jobs to be done before another land grab ...... Weather permitting! :?
Users browsing this forum: Sam95 and 45 guests
