Another new van for the PLR
Re: Another new van for the PLR
Post by philipy » Tue Aug 28, 2018 9:40 am
If I didn't know, never in a million years would I guess the origins of that van. Well done.
Post by Lonsdaler » Tue Aug 28, 2018 10:42 am
Good stuff - the weathering is just right :thumbup:
Post by Peter Butler » Tue Aug 28, 2018 10:49 am
Seeing the transformation of this vehicle from its original form is a lesson in imaginative thinking. The modification and finish are both equally well done and it looks just right.
Post by ge_rik » Tue Aug 28, 2018 6:34 pm
Thanks folks, you're very kind. Quite pleased with the way this turned out. These bashes are always a voyage of discovery.
Post by ge_rik » Fri Sep 07, 2018 7:26 am
Van #2 now well under way, thanks to the kind donation of another van body from Bazzer42 of this parish.
Same technique as previously - end panels removed and ends glued back on to what remains
As the bottom slide for the doors is part of the chassis, I had to make my own from plasticard .....
...... and then use a bisected HLW chassis.
Needs a bit of tidying-up - a few gaps to be filled here and there and of course a paint-job. Oh yes, plus couplings and brake gear. Probably about three hours' work so far - but who's counting?
Post by bazzer42 » Fri Sep 07, 2018 2:11 pm
Blooming Norah! That was quick and I have two hartland chassis here.....but I may hang on to those :D
Post by ge_rik » Fri Sep 07, 2018 3:51 pm
bazzer42 wrote: Fri Sep 07, 2018 2:11 pm ... I have two hartland chassis here.....but I may hang on to those :D
Don't blame you, they're handy to have around.
Didn't want to leave it hanging around - the US box car I bashed recently had been sitting on the shelf for over 5 years. This way, I know it's done. And besides, I need another van to carry all those fruit boxes .... :)
Thanks again. Much appreciated.
IrishPeter
Post by IrishPeter » Sat Sep 08, 2018 10:09 am
The outdoor line is planned to be 32mm gauge/1:22.5 scale to represent 750mm/Bosnian/2'6" gauge, and also to allow me to tap into the LGB/LGB Knock-off odds and ends that I see going cheap from time-to-time. I am also a sucker for things like transporter wagons, and the larger continental style vans. I tend to find British stock a bit Bijou! In most cases I am looking at new wheelsets, a respray, and couplers, which is not too much of a pain in the neck to do. I have four Newquidas on the block at the moment and two of them are intended to be green for my 15mm/Ga.1 line, and the other two are going to the G3/Ga.0 side of things.
Well, that's the theory anyway. I could still be distracted by Feldbahn/WDLR type equipment and a more agricultural feel to things.
Peter in Va
Post by ge_rik » Sat Sep 08, 2018 12:03 pm
IrishPeter wrote: Sat Sep 08, 2018 10:09 am I tend to find British stock a bit Bijou!
I like bijou - I think that's what attracts me to narrow gauge in the UK - though I prefer 3' to 2' gauge stock (some of which is very bijou). I really must get around to modelling something Irish - mostly my stock is inspired by the Southwold and the Welshpool (which I know isn't 3'). Mind you, the Rye & Camber was 3' and their stuff was pretty bijou - especially the locos.
Post by Andrew » Sat Sep 08, 2018 3:22 pm
Lovely vans Rik - I especially like the streaks of rust on the door...
I'm currently van-less (MOTLITT van 11 having been withdrawn for heavy overhaul) so I'm tempted to try to do something similar with a couple of Faller vans I've had knocking around for years. I don't think such a quick fix is possible there though so I'll probably go for a genuine WHR one first. Those were positively rustic, I fear a model of one won't be the pride of the line...
IrishPeter
Post by IrishPeter » Sun Sep 09, 2018 1:06 am
ge_rik wrote: Sat Sep 08, 2018 12:03 pm
I tend to like the idea of unloading a 10 tonner into a 10 tonner, so Leek and Manifold is more my world than the 3 and 4 ton wagons used on the Ffestiniog. I guess the major influence with me is Calthrop - another Lincolnshire man - who liked to work everything to the max.. On the other hand, Irish BG stock was pretty small, so some of the Irish 3' gauge stock (which I also model) was decided 3 to 2 when transhipped to IBG.
Peter in Va
Post by ge_rik » Sun Sep 09, 2018 7:26 am
Can't decide if the doors on these wagons are supposed to be thin steel or plywood. I've been triying to track down any UK ng prototype vans with flush doors to see if there were any precedents.
Post by philipy » Sun Sep 09, 2018 8:41 am
From the pics, they look to me as though they are supposed to be steel. The timber horizontal slats on the body are quite prominent and the doors are just flat with bolt/rivet heads indicating internal framing/bracing, which suggest a sheet face. I suppose they could be plywood, but that seems less likely IMO.
Post by ge_rik » Tue Sep 11, 2018 5:43 pm
Second van now more or less finished. A little bit of tidying and of course weathering needed.
The HLW chassis worked out quite well - provided you don't look too closely.
Here's the new with the old.
Quite pleased with the outcome.
Many thanks to Bazzer42 for helping the PLR gain another new item of rolling stock.
Post by Andrew » Tue Sep 11, 2018 6:03 pm
I'm a big fan of weathering, and you've made a lovely job of "distressing" the first van, but I really like the contrast between the two - would you consider leaving the second in ex-works condition? I keep meaning to do it myself then get carried away with assorted grot colours...
Post by tom_tom_go » Tue Sep 11, 2018 6:05 pm
I agree with Andrew, maybe slightly weather the running gear but leave it pretty as a contrast.
Post by ge_rik » Tue Sep 11, 2018 6:12 pm
Not sure. The PLR doesn't do 'pristine'. I might give it a little light weathering just to accentuate the planking.
Post by Andrew » Tue Sep 11, 2018 7:05 pm
The odd pristine wagon would be a good excuse to build a carriage and wagon works...
IanC
Post by IanC » Tue Sep 11, 2018 7:45 pm
Andrew wrote: Tue Sep 11, 2018 7:05 pm The odd pristine wagon would be a good excuse to build a carriage and wagon works...
:lol: :lol: :lol:
Post by Lonsdaler » Wed Sep 12, 2018 9:21 am
Now it's that sort of careless remark that sets off a whole new chain of modelling! You ought to be ashmed of yourself :lol:
