IanC
Post
by IanC » Tue Jun 19, 2018 2:12 pm
mymodeltrain wrote: Tue Jun 19, 2018 1:13 pm
IanC wrote: Tue Jun 19, 2018 12:37 pm
mymodeltrain wrote: Tue Jun 19, 2018 12:46 am
I agree, that is why I didn't want to use airbrush to begin with; I tried to find a simple and quick way. But now as no other choice available, I return to use airbrush. The preparation and cleaning are time consuming for airbrush; further, I also have to design a negative flow booth since I do it in my garage.
I use acrylic and enamel paint. With acrylic I mix my own thinners using IPA, water and add flow retarder and flow improver. I get the best results by making a very thin mix and slowly building up lots of coats. I don't particularly like airbrushing with acrylic, but for some things it's the best option.
For a small project, I guess buying ready-to-use paint for airbrush would be economical . I didn't know that we have to mix many things in the paint formulation, thanks for sharing. BTW, what is IPA?
IPA is Isopropyl Alcohol. Here's the video where I found the process for making my own.
https://www.youtube.com/watch?v=T8k3BJC80IQ
The IPA I get from Ebay. 1 litre cost me about £5 and I've got loads left over yet. I tend to use a little more fluid retarder and flow improver than suggested. The fluid retarder and flow improver are from Windsor & Newton. Hardly any improver and retarder are required so will probably last me a lifetime!
Cheep and cheerful, but for me I have control over the quality. Since I started using the mix I've found it much easier to airbrush with acrylic. Less tip drying too. The only trade-off is a slightly increased drying time.
mymodeltrain
Post
by mymodeltrain » Tue Jun 19, 2018 2:36 pm
IanC wrote: Tue Jun 19, 2018 2:12 pm
Thanks for the information and the video, very convincing; I guess the fluid retarder and flow improver are available in Michaels or Hobby Lobby. I was frustrated with my airbrush skill in the past, most of the time I struggled with blockade and cleaning the tips and other parts, testing the formulation/flow/viscosity, all failed. I noted that for the same formulation and type of paint, different colors gave me different results. I was lucky with red but not others. I don't know if my assumption is correct but that was my experience, and since then I gave up. I hope the simple but robust Badger airbrush will boost up my enthusiasm with airbrush painting.
Post
by Lonsdaler » Wed Jun 20, 2018 9:58 am
Ian,
Thanks for posting this. I've avoided air brushing after disappointing results when model boating back in the 90's! This sort of advice makes me think I should try again. Have you considered doing a step by step guide to your method in the 'Help and Advice section? (Please!
IanC
Post
by IanC » Wed Jun 20, 2018 10:09 am
Lonsdaler wrote: Wed Jun 20, 2018 9:58 am
Ian,
It might take me a while to get round to doing a guide. I'm not an expert either just someone who has persevered read, and watched loads of videos on the subject. What I do is not original.
I'm happy for now to answer questions. I'll try and put some words together if it helps.
Post
by Lonsdaler » Wed Jun 20, 2018 10:16 am
IanC wrote: Wed Jun 20, 2018 10:09 am
Ian,
I'm not trying to pressurise you Ian
. I know you have made models for other people and you seem to have your head around air brushing. Like you, I should delve deeper into the web of the wide world, and not expect you to provide it for me!
