IP Coach Kits
- dougrail
Re: IP Coach Kits
I ended up building two of those blasted things -but I finished them with sweat, perserverance and some grit. Even painted them Penrhyn authentic black too. Not a very popular model however. I think mine were plywood. I think the main issue is that they're flat edge, no tongues or grooves to aid construction when you're putting the bodies together and the instructions need a little thinking over.
Tingewickmax
Re: IP Coach Kits
I have built a few of IP's kits, mostly from their Darjeeling range and all of laser cut plywood construction. They fit together well and are generally well thought out. However, they tend to be of a light construction and benefit from adding a bit of weight low down. This feature can give them a rather unsatisfactory "rattle" as the trundle along. Detailing is basic compared to other makes mentioned in this thread, it depends on your priorities. Wheel turning and bearing fit can be a bit basic giving them another strange "cheap" sound dimension when running compared to others.
While your stated needs are for "freelance" I would urge you to check the dimensions of what you are buying will look "right" with the intended loco that will pull them. I built some of IP's VoR coaches and they were woefully out of proportion to a Roundhouse VoR loco, sold them and bought Brandbright instead. I have noticed with the Darjeeling stock I have bought that someone has been playing a bit fast and loose with their replication when compared to the well documented prototypes. But then you want freelance stock not prototypically correct ones
Construction and painting is straight forward - medium thickness superglue or a more conventional wood glue, like Titebond 2. Painting - sanding sealer (essential with MDF) then a coat or two of Halfords filler primer, depending on how much "wood grain" you want to show. Rub back between coats. Finally a coat of the right primer to match your colour coat and then 2-3 of those, again Halfords is ideal. Then apply any satin/matt coat finish if you don't want gloss. Remember to mask to create some unpainted strips/areas for glue when you are applying overlays so you get a good bond. Any staining should be done before gluing and painting. IP do a nice range of decals, for specific railways, but there are some specialist who will make sets that can represent your "line".
As they say, "You pays your money, you makes your choice" and "You only get what you pay for". Fully agree that IP's owner, Ivan, is generally good on the customer service side.
- IanC
Re: IP Coach Kits
My experience of IP kits is limited to two of their now withdrawn Roundhouse sized coaches and two vans. These are from the pre MDF days being of ply construction. The coaches have only just beem completed and one of them has a slight wobble due to either the wood twisting or the frames not quite being square. I have allowed for adjustment in the axleboxes so will remove them and refit with a shim which should cure the problem. Otherwise construction was straight forward.
I like the simplicity and basic design as it allows detailing and customisation to ones choice. I agree about appearance with motive power though. I am considering more coaches, but many have been ruled out of consideration purely because they would not look good in my opinion behind my locomotives.
- dougrail
Re: IP Coach Kits
That was something I noticed - Penrhyn no.2 was built then sprayed in Halfords primer. It had warped ever so slightly which is a shame. I have to admit, AnDel and SW16 kits have been a more pleasurable build. I had problems in 2013 when the wood totally warped beyond rescue, then 2017 building the LPs has been somewhat of a grind.
However I will thoroughly commend Ivan's customer service when parts were missing. Top stuff there.
- pippindoo
Re: IP Coach Kits
I have a rake of IP's Beginners freelance coaches, built exactly 'as per' except for the Guards/Luggage van which has window bars, and all have kitchen roll applied to the roof with diluted PVA glue to represent felt. They were a pleasure to assemble with no problems whatsoever and despite a a relatively long, fixed wheelbase, have done a lot of running on various lines and behaved impeccably. As can be seen, they are of a larger loading guage to match Accucraft locos, seen here with my Lawley class DELILAH.
- Lonsdaler
Re: IP Coach Kits
Must get round to finishing (I mean starting
) the three I have in a box somewhere. The single one I have completed is getting lonely!
I did shorten the wheelbase to just under 6 inches, which helps negotiate tighter curves, and I articulated one of the sole bars to help it negotiate uneven track (not my track, obviously!!
