Building a Church
- planty
I'll measure up at some point Grant. This is the latest pic from today, detailing of building sorted. Next it'll be windows and painting, lots of humbrol! Took a can and a half of primer.
James from Devon
- planty
Anyone know of any articles online or books that cover brickwork painting?
I had a reasonable go with some redbrick on a platform building but wouldn't mind reading up on what others have done before starting on the church.
I can't point you to any specific online articles but the basic technique is pretty easy and is much the same for brick or stone.:planty:117933 wrote:Anyone know of any articles online or books that cover brickwork painting?
Personally I start with the mortar. I mix up some mortar colour and paint the entire structure, ensuring it gets into the mortar courses.
Pick a base colour that is approximately what you want the building to look like when finished. Paint the whole thing in that colour - a small foam roller does a pretty good job and avoids getting too much into the mortar.
Next get various colours that are lighter and darker than the base and mix SMALL quantities of different shades. Randomly paint individual bricks/stones, spread across the entire building.
When that paint mix is used up, mix another one and repeat.
Of course, each batch will be a slightly different colour, which is exactly the point, and why you must randomly pick out bricks/stones across the building.
There is no need to paint every individual brick/stone and when you stand back and look at it, as long as the shaded variation is random but even, and the overall colour is what you want, thats it.
This is the basic technique I used on my post office and village shop:
http://gardenrails.myfreeforum.org/abou ... highlight=
I note you say about using Humbrols. I've used ordinary bog-standard emulsion on foam boards with no problems after several years outside. You might have problems with Humbrol attacking your foam?
- planty
Thanks Philip. Really helpful. Never thought of just using emulsion, might try that on a test piece to see whether I can get the colour I'm after. Be easier to get the quantities I need.
Emulsion paint seems to stay put on porous surfaces, eg concrete, however, I have never tried it on foamboard. I have used acrylic paint on a number of different surfaces and think it should work on your church. Artist quality acrylics in tubes from art shops shouldn't be expensive and will give you a greater variety of colour choices.
- planty
Well a few weeks has passed and I've finished the brickwork painting.
- planty
Next step is the windows, the aim with this is to print detail onto some crafty computer paper Inkjet Water-Slide Decal Paper.
Then apply these to some clear Perspex.
First batch of windows are done, they look blue as the Perspex backing is still on one side.
stoker
A few years back we visited New York....
And took a tour bus ride around the sights...
The guide soon cottened on to an English family and asked where we were from.
We told him that we were from Lincoln where we had a cathederal that was started in 1052(ish) and finished in 1120(ish)
'Oh' he replied,'It took 'em just half an hour to build?'
Where's me coat?
Where's me coat?
- planty
Sorted the base of the roofing out, time for the time consuming job of adding all the roof slates!!
For the top roof I'm looking to use the same technique I used on my station with cut up roofing felt. Looks really good when weathered in a bit. Not decided what I'm going to do for the side roof, same could work but the shape is a little more tricky!
I've just noticed that somehow I missed the last post on the previous page, about the windows. I've never thought of doing them like that but it's a brilliant idea. My only concern is whether the waterslide transfers will remain in place and the inkjet ink not run, outside when it rains? However it is also possible to get clear self adhesive vinyl sheets which should be waterproof especially if printed on a laser pinter.
- planty
I'm not too worried by the ink. I use an acrylic varnish spray on top of the dry ink. This allows you to place in water to slide off the decal, so if it can handle being submerged in a bowl of water it can handle a bit of rain :-)philipy:118826 wrote:I've just noticed that somehow I missed the last post on the previous page, about the windows. I've never thought of doing them like that but it's a brilliant idea. My only concern is whether the waterslide transfers will remain in place and the inkjet ink not run, outside when it rains? However it is also possible to get clear self adhesive vinyl sheets which should be waterproof especially if printed on a laser pinter.
I have thought of the decals sliding in the rain, for this model most of the decals overlap the size of the window so they are effectively trapped by the adhesive attaching the Perspex to the building. Fingers crossed!
- planty
For info the stuff I've used is:
Keen - Top Crystal Clear : Nitoracrylic Spray - Transparent
I think I got it from the same place as the decal paper
- planty
It's a pot of roofing felt adhesive (not tar). Just need to be careful with it as it gets everywhere!! The pot I had could be applied with a brush (use an old one though as I never got it clean!!)jim@NAL:118817 wrote:very impressive looking building what are you sticking the slates on with
JCSteam
