Wild Rose ~ Quarry Hunslet
dewintondave
Post by dewintondave » Mon Feb 08, 2016 1:45 am
Whilst waiting for some paint to dry... I've been cutting out the frames from sheet steel. I have a lifetime supply of 1.6 mm :)
It's hard work with a hacksaw. Filing the edges flat was aided with a long straight edge and sighting through.
Here's the frame blanks cut to length
Best wishes,
Dave
dewintondave
Post by dewintondave » Sun Feb 28, 2016 9:02 am
I've been cutting those lovely cut-outs in the frames, lots of sawing and filling. Then lots of drilling for spacers, and heaps of 8 BA tapping in the spacers. I start the tap square in the bench drill. But, first I remove the quill return spring...
Filing, filing
Frames and spacers
Best wishes,
Dave
dewintondave
Post by dewintondave » Mon Mar 07, 2016 6:32 am
I've been working on the buffer beams.  The chassis is bolted together.  It was nice to do some turning again, the axle bearings were turned yesterday from gunmetal.
I couldn't resist sliding the wheels on
I've a supply of 8BA screws from my local supplier.
Best wishes,
Dave
dewintondave
Post by dewintondave » Fri Mar 11, 2016 9:47 am
The buffer beam height is perfect for the LGB stock...
Best wishes,
Dave
dewintondave
Post by dewintondave » Sat Mar 26, 2016 5:03 am
At last a rolling chassis. The coupling rods are finished. I shaped the cranks in blocks of two blanks soldered together, the profile is a bit different between the pairs, so I'll put each pair on their own side of the loco, and not mix them.
Checking the clearances
Rolling chassis
This is how I modify screws. I needed 1/4" AF for the cranks, to keep the rods on, but had no bar stock. I converted four 4 BA screws into 8 BA
Now I need to think about the cylinders...
Best wishes,
Dave
Dannypenguin
Post by Dannypenguin » Sat Mar 26, 2016 9:43 am
Wow this is all looking really good, I'm following this with great interest :thumbright:
Dan
dewintondave
Post by dewintondave » Sun May 08, 2016 4:19 am
A month ago I made a gentle start on the smokebox as I wait for some cylinder materials. I'm using steel sheet for smokebox endplates and wrapper
Here's the progress so far. I like using roundhead screws for the rivet look, these were used on the live diesel bodywork
Best wishes,
Dave
dewintondave
Post by dewintondave » Sun May 22, 2016 5:39 am
Last weekend I started on a flange to mount the boiler barrel to the smokebox.
Disc blank cut out and mounted on mandrel
Outside diameter turned
Centre removed and bored to just pass the boiler barrel OD. Strip cut out and filed flat.
Strip bent to shape around a handy former. Ready for silver brazing
Fully brazed. It took many heatings and adjustments to get the strip placed just right. My first go with cadmium free silver solder
Although a little heat distorted, I was pleased with the concentricity
One week later, boiler barrel fitted to smokebox. 8 BA all the way
Best wishes,
Dave
Post by LNR » Sun May 22, 2016 7:21 am
Hi Dave!
Nice job, be interested to know what you thought of the Cadmium free silver solder, assuming you have used the cadmium stuff before. Hear many reports of it not flowing as well as the old stuff.
I'm afraid I have enough of the cadmium stuff to see me out, so can't see myself changing, but be interested to hear your opinion.
dewintondave
Post by dewintondave » Sun May 22, 2016 9:03 am
Hi Grant, the cadmium free went fine. My old silver solder will soon run out, so I bought a stick of the cadmium free to try. The ring had two spots where it had pooled, I think at the end of the flux line, and me over enthusiastic stick feeding. When the job was finished, I re-fluxed and re-melted them and it flowed nicely without any other aid
Best wishes,
Dave
Post by LNR » Sun May 22, 2016 10:46 am
Thanks Dave, I reckon your a game man soldering a ring that thin and then machining it to fit. Concentricity doesn't have to be far out when you involve the lathe. Congratulations.
dewintondave
Post by dewintondave » Sun Jun 12, 2016 10:05 am
I made the chimney base from steel. One of the first operations was to mill the smokebox profile on its base. I did this in the lathe, with my old Emco Unimat 3 flycutter.
After milling, the blank was turned in the lathe, working both handles to get the large radius.
The job is secured to the mandrel by Loctite 609 retainer
Lots of heat is required to remove the job from the mandrel, the chimney base is now a lovely blue/black colour
Best wishes,
Dave
Keith S
Post by Keith S » Sun Jun 12, 2016 3:15 pm
It certainly is a pleasure to see the work in progress. It looks like a fine job so far. I am particularly impressed with the boiler/smokebox flange.
dewintondave
Post by dewintondave » Mon Jun 13, 2016 10:13 am
Keith S:118494 wrote:It certainly is a pleasure to see the work in progress. It looks like a fine job so far. I am particularly impressed with the boiler/smokebox flange.
Thank you Keith!
Moving to the other side of the smokebox, the smokebox door. This is made from a slice of free cutting steel soft soldered to a mandrel after the rear face was turned.
Rear face details just visible
Profiling the front face
Finished door still on mandrel
Hinge straps cut out of 0.6mm sheet with tin snips
Finished hinges. I used LBSC's "words and music" for the straps and lugs. I had to borrow the roundhead screws from the live diesel
The door is swinging!
Best wishes,
Dave
Post by philipy » Mon Jun 13, 2016 12:52 pm
Dave,
The big problem with your work is that I ran out of superlatives long ago! As always, I'm in awe.
dewintondave
Post by dewintondave » Tue Jun 14, 2016 10:00 am
philipy:118509 wrote:Dave,
Thank you!
Best wishes,
Dave
dewintondave
Post by dewintondave » Sun Jul 03, 2016 5:53 am
It was time to start on the chimney. I started at the top.
Gunmetal was used for the chimney cap. The blank was Loctited to the mandrel
Marking out the upper curved part
I filed this curved surface
Rough turned
Finish turned
Finished part
Tall chimney version
Cross-bar fitted
Out on the line!
It was a lovely morning for a cigar and coffee!
Best wishes,
Dave
robyholmes
Post by robyholmes » Tue Jul 05, 2016 9:37 pm
Fantastic! Love seeing your work.
dewintondave
Post by dewintondave » Mon Jul 25, 2016 9:50 am
robyholmes:118836 wrote:Fantastic! Love seeing your work.
Thank you!
I made a start on the cylinders. I like to use commercial plain bronze bearings for oscillator cylinders. They have a very good surface finish.
The port faces were bored in the lathe using the exact same set-up as was used for my large de Winton. Bored for the cylinders to be able to be soft soldered to them.
The faceplate required counter balance weights
The port face is soft soldered to the faceplate angle plate
I want the rear covers to be removable. I like screwcutting so decided to thread the end covers and the cylinder. An internal tool was ground for the cylinder, this took days... I've used 40 tpi as the pitch. As the threads were short I turned the chuck by hand. My wrist was aching like a teenager's afterwards!
Best wishes,
Dave
dewintondave
Post by dewintondave » Sat Oct 22, 2016 8:37 am
I thought I'd tackle the boiler next so that I could see where everything will go. I've been very slowly progressing.
A supply of 1.5 mm copper sheet, 2", and 1/2" copper pipe was already on hand. I've recently received some more sticks of the cadmium free silver solder (brazing rods) from Macc Models, I'm ready to make a sizeable investment in the boiler - lots of silver.
Some 4 mm thick steel was bought to make flanging formers. I was able to reuse a boiler endplate flanging former from my first loco build; the small De Wintons. Flanging is very satisfying with frequent stops for annealing the copper sheet.
Rounding off the throatplate / backhead former
Rework #1: Removing a thin strip from the wrapper using the piercing saw. The throatplate is already brazed in place.
Backhead and former
Firebox former with unformed plate
Progress so far
Best wishes,
Dave
