bambuko loco works 0-6-2 (Fowler)
BorisSpencer
Re: bambuko loco works 0-6-2 (Fowler)
Post by BorisSpencer » Mon Nov 11, 2019 12:17 pm
Just to add, the chassis I bought from Steve some time ago had blackened wheels, after a couple of test laps around the garden the tyres and flanges were shiny silver just as you would expect.
Also when I retreat the deck boards that form my track bed I don't worry about getting preservative on the rails, as after running a few train the top and inside of the rail head is back to bare metal, just as per prototype.
bambuko
Post by bambuko » Mon Nov 11, 2019 1:02 pm
Perfect :!:
@ BorisSpencer - it's good to have confirmation of my theory :D
That what I was aiming for :thumbright:
Post by FWLR » Tue Nov 12, 2019 8:31 am
bambuko wrote: Fri Nov 08, 2019 3:20 pm
What do you think guys? (and girls, if there are any here?)
You mentioned "girls' first Chris.... :lol: :lol:
bambuko
Post by bambuko » Tue Nov 12, 2019 10:42 am
FWLR wrote: Tue Nov 12, 2019 8:31 am ...You mentioned "girls' first Chris.... :lol: :lol:
That's beacuse I am an incorrigible dinosaur :mrgreen:
ps I have been locting the wheels on axles since yesterday - not taking chances and leaving it for 24 hrs to set before touching, because it would be right PITA if something were to go wrong with it later...
Post by FWLR » Tue Nov 12, 2019 11:23 am
bambuko wrote: Tue Nov 12, 2019 10:42 am
........................ :laughing3: :laughing3: :laughing3:
dewintondave
Post by dewintondave » Fri Nov 15, 2019 4:43 am
Oil blackening steel is great. I've got some filthy lawnmower sump oil that puts a different finish on steel compared to clean oil. Thickness of the job and degree of heating before plunging into the oil makes a difference. I've been oil blackening screws most recently. I copped criticism from UK based H&S types, telling me the oil was carcinogenic :D
Best wishes,
Dave
Post by FWLR » Sat Nov 16, 2019 7:02 am
dewintondave wrote: Fri Nov 15, 2019 4:43 am Oil blackening steel is great. I've got some filthy lawnmower sump oil that puts a different finish on steel compared to clean oil. Thickness of the job and degree of heating before plunging into the oil makes a difference. I've been oil blackening screws most recently. I copped criticism from UK based H&S types, telling me the oil was carcinogenic :D
Who cares what those H&S types think Dave. So long has you have what you need from doing the blackening is all that matters.....
By the way shows how intelligent I am.. :roll: I didn't have a clue what carcinogenic meant until I looked it up... :mrgreen: {Things that could cause cancer.}
When I was a young lad, :lol: I was told, if you eat burnt toast you will get cancer.... :scratch:
It's not happened yet....Now were is that piece of wood to touch..... :lol: :lol:
bambuko
Post by bambuko » Sat Nov 16, 2019 10:20 am
Had a bit of a setback :scratch: with wheels loctited on the axles.
The retention strength is nowhere near what it should be...
I don't know whether it is the age of my Loctite (I am using ancient 648 I had for years).
It shouldn't be, since I didn't have problems with it before, but just in case ordered another bottle of 638 (higher strength and tolerant of bigger gaps than 648).
It is possibly contamination caused by blackening?
Going to have to do some experiments and if necessary re-do the whole axle wheel thing :oops:
Trying not to get too depressed ...
Post by GTB » Sat Nov 16, 2019 12:54 pm
bambuko wrote: Sat Nov 16, 2019 10:20 am Had a bit of a setback :scratch: with wheels loctited on the axles.
Technically, the black coating is a thin porous layer of iron oxide, saturated with oil. As a chemist I'd classify it as a heavily contaminated surface for the purpose of making a joint with Loctite.
I doubt the age of the Loctite 648 is an issue. The bottle of Loctite 601 that I use for fitting wheels is over 30 years old and it still makes a joint that is hard to break, provided the surface is properly prepared.
Did you ream the bores of the wheels when you made them? If so, run the reamer through again which will scrape off the oxide, then degrease the bores with a suitable solvent and try the Loctite again.
If that doesn't work, there's less work involved if you just bore the holes in the wheels larger, press fit bushes and then ream for the existing axles.
bambuko
Post by bambuko » Sat Nov 16, 2019 1:08 pm
GTB wrote: Sat Nov 16, 2019 12:54 pm ...As a chemist I'd classify it as a heavily contaminated surface for the purpose of making a joint with Loctite....
thank you GBT,
that was my (reluctant) conclusion as well
as they say in the trade "cluster f**k up" on my part :oops:
GTB wrote: Sat Nov 16, 2019 12:54 pm...I doubt the age of the Loctite 648 is an issue. The bottle of Loctite 601 that I use for fitting wheels is over 30 years old ....
mine is also over 30 years old :mrgreen: and it didn't cause problems on other projects
GTB wrote: Sat Nov 16, 2019 12:54 pm...Did you ream the bores of the wheels when you made them?..
I finished with reaming, but I will try to get everything properly cleaned (and use 638 which can cope with bigger gaps)
GTB wrote: Sat Nov 16, 2019 12:54 pm...If that doesn't work, there's less work involved if you just bore the holes in the wheels larger, press fit bushes and then ream for the existing axles...
Can be done this way, but it is probably six ve half a dozen (or whatever is the correct English idiom :D )
dewintondave
Post by dewintondave » Sat Nov 16, 2019 9:40 pm
FWLR wrote: Sat Nov 16, 2019 7:02 am
So true Rod. There's a lot of scaredy cats out there. I love burnt toast too! Everything is carcinogenic, just some things more than others :D
Best wishes,
Dave
Post by FWLR » Sun Nov 17, 2019 8:04 am
bambuko wrote: Sat Nov 16, 2019 1:08 pm
"Six of one and half a dozen of the other" ....... Dave... :thumbright:
bambuko
Post by bambuko » Sun Nov 17, 2019 10:25 am
Thank you FWLR
It's just lazy of me - should have googled it :mrgreen: before posting :thumbleft:
bambuko
Post by bambuko » Wed Nov 27, 2019 4:23 pm
Sounds like I got away with it :mrgreen:
Cleaned axle holes in the wheels with wet & dry, soaked the wheels in acetone for two days, put them in a dishwasher
and after preparing them as normal loctited using Loctite 638.
Job done - they are solid :thumbup:
Next is the rear trailing pony truck, to finish all the wheels.
The only minor complication is that I want to use ceramic burner rather than poker burner,
so I will have to make sure that it not only fits in the frames but also fits around pony truck.
I think this will call for a mock up rather than just trying to design it on CAD...
bambuko
Post by bambuko » Thu Dec 05, 2019 11:04 am
Spent couple of days pondering how to fit the burner and pony truck in the space available and here is what I came up with:
It's shown with LH frame removed for clarity.
Red block secured with two bolts to frame stretcher is both burner bracket and provides bearing surface for pony truck to slide sideways.
Red block is shown with 10mm hole for gas burner, but it could also be changed to meth burner if I find problems with ceramic burner.
Of course meth or ceramic gas burner can be dispensed with and replaced with gas poker above, in which case red block becomes only a bearing surface for pony truck.
Weight of the pony truck and it's freedom to move up and down (a bit) as well as left and right, should be sufficient to keep pony wheels in contact with rails, but...
if necessary I guess it should be easy to add some springing.
Methinks it's time to start cutting metal :mrgreen:
Hydrostatic Dazza
Post by Hydrostatic Dazza » Thu Dec 05, 2019 7:31 pm
You are doing such a nice job, put a grate in and burn the black stuff.
bambuko
Post by bambuko » Thu Dec 05, 2019 8:35 pm
Hydrostatic Dazza wrote: Thu Dec 05, 2019 7:31 pm You are doing such a nice job, put a grate in and burn the black stuff.
Thank you.
I would like to do it indeed :thumbright: but this particular model would need too much butchery to rear of the cab to permit easy access for the shovel.
Plus, adding axle pump at this stage would be a bit of PITA
I will leave it for the next one :mrgreen:
Having said so - this mod is not impossible and the way this project is meandering you never know where it might end up :D
bambuko
Post by bambuko » Tue Dec 10, 2019 6:28 pm
Something slightly different (i.e. no update, although I am making progress :thumbright: )
Here is one of the original, Leeds build Aussie Fowlers that made it's way back to UK:
She is in "Steam Workshop":
https://www.steamworkshop.co.uk/portfol ... ler-16341/
and here as she was in Australia:
http://www.australiansteam.com/fowler16341.htm
and more photos:
http://www.steamworkshop.co.uk/portfoli ... s-fowlers/
Shame I got the vids and photos only now and not when I was designing my model (which suffered from desperate shortage of decent photos of original)
OK, she is 0-4-2 not 0-6-2 (which I am building) but other than that she is much of the muchness...
Not surprising since someone like Fowler wouldn't be re-inventing the wheel every time it build a locomotive :mrgreen:
Lot of common components and familiar design aspects.
Hope you guys enjoy it as well :study:
Hydrostatic Dazza
Post by Hydrostatic Dazza » Wed Dec 11, 2019 8:46 pm
bambuko wrote: Thu Dec 05, 2019 8:35 pm
Thank you.
There were articles in AME magazine in 2017, they did thermal modeling of what happens in a coal fired wet leg boiler when run dry. The temperature rise was very little and well within the brazing and copper material stability, due to the draft on the fire ceasing as soon as the water was gone. thus in the small garden size grates, the fire dies to a ember. (if you use soft solder well ??) They backed this up with actual testing and measuring temperatures and all was very close to the thermal modeling. I saw this in action on the loco at my local ME club run. They have a small garden track there now. I know many will be :roll: with the concept of a coal fired garden steamer without a pump, but like many things, once the notions are wide spread, then the notion is all blanketing and perpetuated for decades it is hard to dispel. So maybe you do not need a pump if the boiler has wet legs and the design has a decent water volume for long runs. (less tubes) I am putting a pump in my build to just give the option of a lengthening the run, thinking it will be 30 -40 minutes with a slow trickle that will be just below the steaming rate. Still able to run it dry, it just gives more wine and smelly cheese time . Did I email the scans of these AME articles to you ?
Last edited by Hydrostatic Dazza on Thu Apr 16, 2020 11:08 pm, edited 1 time in total.
bambuko
Post by bambuko » Thu Dec 12, 2019 11:12 am
Hydrostatic Dazza wrote: Wed Dec 11, 2019 8:46 pm ...There were articles in AME magazine in 2017, they did thermal modeling of what happens in a coal fired wet leg boiler when run dry ...I saw this in action on the loco at my local ME club run...
How does it square with the boiler code which requires you to have two independent sources of feedwater (regardless of boiler size)?
I am not saying that the article was wrong, simply asking how can you run (in a club environment) something that does not adhere to the code?
What you run in your private back garden is your own business, but in public... it's another story?
Hydrostatic Dazza wrote: Wed Dec 11, 2019 8:46 pm ...I know many will be :roll: with the concept of a coal fired garden steamer without a pump...
Yes :mrgreen: and that's why I think that sharing a boiler code with "big guys" is a bit of a problem.
Hydrostatic Dazza wrote: Wed Dec 11, 2019 8:46 pm ... Did I email the scans of these AME articles to you ?
Yes, you have - thank you very much!
I personally dislike axle feed pumps in smaller scales, so these articles are very encouraging :thumbright:
