Latest developments
Re: Latest developments
Just putting the finishing touches to the latest to roll out of the he PLR workshops. I've rescaled the 0-16.5 GVT Glyn to 15mm. A bit more titivating before she's ready for the paintshop and awaiting delivery of some li-ions, but I'm quite pleased with how she's turned out.
I like the look of the GVT tram loco Rik. What resolution did you use? I have used 0.1mm layer with good results, but I have seen a video on Youtube which suggested that due to the rule of 2 (related to the angle of the turn of the stepper motors I believe) that 0.12 layer gives a better result. I'm not sure if this relates only to cura slicer. I'm new to 3D printing, so still learning.
John
John
John Smith
Harrogate
John Smith
Harrogate
It is a magnificent loco, but those lines would keep me awake all night! Without the rivet detail there should be a way of smoothing the surface.
When these are painted up most of the line seem to disappear, however Peter I do agree with you, and it is what has put me off a 3D printer, I am not sure I would be happy with the results, for external (to model) parts.Peter Butler wrote: ↑Sat Jul 02, 2022 10:44 am It is a magnificent loco, but those lines would keep me awake all night! Without the rivet detail there should be a way of smoothing the surface.
It is a superb looking model with obviously some impressive drawing, but like the others have said, as it stands the sideways smears off the rivet heads would annoy me too. Having said that, (a) Jimmy is correct that paint can lose much of that, plus (b) I have found myself that the photography/lighting can make it look a lot worse than it is.
At a practical level, I don't know how Rik has designed the 'kit', but I think I would have been tempted to make the tank sides, back and front as separate sheets, printed flat and subsequently glued together, which would have largely solved that problem.
Hi chaps
Thanks for the feedback.
Regarding the resolution - I think it is 0.12. I'm away from home at the moment (visiting a couple of ng railways in Lincolnshire) so can't check but I used the default which Cura provided for my printer and filament (both Eryone).
Yes, this was a bit of an experiment. Normally, I would print slab sides like this flat but it worked out ok to print them vertically in 7mm scale so I thought I'd give it a try in 15mm. But, as you say, the ripples produced from the rivets is a right PITA.
I've got a couple of options - I'll try smoothing the sides with the rivet detail intact. However, if that doesn't work I'll file them off and replace them with nail art gems.
For info, the loco body took 21.5 hours to print, by far my largest single print
Thank you Rik. I also have printed most of my parts on the flat, although I have tried a couple of vertical prints but without rivet detail.
John
John
John Smith
Harrogate
John Smith
Harrogate
- Tropic Blunder
The latest way ive managed to get around the stirations (ridges) is to give it a good sand with 120 and 240 grit then lie it on its side and give it half a dozen coats of the tamiya painter filler in the cans and sand flat. you can get quite an achievable finish. at the end of the day 3d printing isnt really any less work then scratch building it just changes the nature of the work involved
It's taken a while, but the loco is now more or less finished. A bit more detailing and she'll need a bit more weight. I think I may have to raise her up from the track by a few mm - although the height of the skirt above the rail is prototypical, my track isn't. I'm really pleased with the Micron MR603 receiver. Very fine control , maybe even more so than its Deltang predecessor. I've made a video which I'll post in due course.
Lovely job Rik... nice finish too!
Yes, I have to agree. My wargaming mate popped round at the weekend and I showed him my 3D printing set-up. He asked if I was worried about losing my scratch bash bodgelling skills and, after a few seconds reflection, I told him I was more than delighted, if not excited, by the new skill set I was developing. I don't think I'm abandoning my old skills (such as they are), I'm augmenting them.Tropic Blunder wrote: ↑Mon Jul 04, 2022 9:43 pm ...... at the end of the day 3d printing isnt really any less work then scratch building it just changes the nature of the work involved
Superb Rik, really lovely.
Those layer lines seem to have really disappeared, was that just hard work with wet 'n dry?
A combination of filler and several coats of primer with wet n dry between.
Lesson learned! Avoid printing sides vertically but if it's unavoidable then do not add rivet detail. Close scrutiny will reveal that there are still some strata lines between and beside rivet rows where I struggled to get the abrasives in.
Here she is in action with Micron MR608 receiver installed
Running nicely Rik. Doesn't it make a welcome change to have that much spare space inside for all the gubbins?!
Absolutely! It's cavernous by comparison to some of my other builds. It's also a lot easier to access the gubbins - the tank tops and boiler lift off as a single unit.
Just trying to decide whether to mount the coupling on the rear of the body or pivot it on the bogie/pony truck. I'll have to run it through my tightest reverse curves and watch closely what happens. I'll also have to raise the body by a few mm. An easy task, I'll just pack some plasticard spacers between the mounts on the motor block and the body.
BTW, I constructed this loco to 15mm/ft which is becoming my default scale since I started 3D printing the Southwold stock. I'm surprised how much difference a 15/16 reduction makes on the overall dimensions. I originally rescaled the GVT coaches to 16mm/ft and have now re-rescaled them to 15mm. Once I've finished constructing them, I'll take a few pictures of them side by side.
A fine looking end result there Rik. Will you be adding a sound card? It would round it off nicely. It's also surprising how effectively a skirted locomotive hides the need for running gear. A lovely looking locomotive.
Hi Phil
Yes, a MLS soundcard is on the agenda. I need to rationalise my stock to allow room for the new 3D printed wagons. I can then fund the soundcard from the sales of the old wagons.
- Tropic Blunder
Great outcome Rik really looks the biz! very smooth running too, what exactly is powering this beastie? I dont think you showed us what was under the skirt so to speak
Hi JakeTropic Blunder wrote: ↑Sat Jul 23, 2022 2:08 am Great outcome Rik really looks the biz! very smooth running too, what exactly is powering this beastie? I dont think you showed us what was under the skirt so to speak
Thanks. It's in the video but I'll also post the piccie here. It's the motor block from a Bachmann streetcar. I bought a couple secondhand from someone on this or the GSC forum who was replacing them with something of higher quality. The skirts hide a multitude of sins so I could have put more or less anything under it. I have actually put a trailing bogie under there although it's not really essential.
Once I've tidied up the files, I'll post them in the 3D printing section. I'll also post a version of the body without rivet detail to make it easier to rub down before painting
