Post
by -steves- » Fri Oct 30, 2020 9:17 pm
metalmuncher wrote: ↑Wed Oct 28, 2020 7:35 pm
That is a nice looking loco. Quite interested in the jackshaft and cranks, did you end up with any tight spots that needed attention or did everything just fit right off the printer? I've not attempted a loco with con rods, but looking at this I think I am inspired to incorporate con rods on the next one.
You mentioned you were looking for a source of gears, this place has quite a selection:
https://www.technobotsonline.com/gears- ... ckets.html
Quite cheap too, you can get a 10pk worms and 10pk plastic gears for £2.61. 50 3mm shafts for £6.55. 10 MFA RE-280 motors for £15.48. Total £24.64, or £2.46/chassis. Combine that with a 3D printer and you have a recipe for more locos than you can fit in your shed.
R/C ends up being the most costly part...
Also, the pictures don't show up properly here either. I think its because the forum is using HTTPS and the pictures are served without HTTPS, and Chrome doesn't like that for security reasons. Your image host doesn't seem to support HTTPS.
The con rods were a little tight in places, but a small fettle with a 2mm drill bit soon sorted that out. The quartering method is built into the axles and the cranks, it worked very well indeed and I had no idea if it would work, hence not posting anything about it until it was finished and I was confident it worked as expected.
P.S. Thanks for the link I have ordered some to try
Post
by -steves- » Fri Oct 30, 2020 9:27 pm
Jimmyb wrote: ↑Wed Oct 28, 2020 8:06 am
I CAN see the photos, and it looks good to me, and a good example of what can be achieved with a 3D printer
Thank you for your kind words
Post
by -steves- » Fri Oct 30, 2020 9:30 pm
ge_rik wrote: ↑Wed Oct 28, 2020 6:20 pm
Great looking loco, Steve - after all those shenanigans! Did you use sketchup?
Hi Rik. Glad you eventually got to view the pictures. I used Tinkercad for all the CAD work, takes some doing and is quite restrictive, but very very easy to use compared to any of the proper CAD programs.
Post
by ge_rik » Sat Oct 31, 2020 8:39 am
-steves- wrote: ↑Fri Oct 30, 2020 9:30 pm
Yay! Three cheers for TinkerCAD
Here's my latest TinkerCAD tinkering.
- 2020-10-31-08-35-54.jpg (337.44 KiB) Viewed 4480 times
A Southwold Railway early closed van.
Like most of my modelling, the detailing is representative rather than perfect scaling, but I know it will print without the need for further tweaking.
Post
by -steves- » Sat Oct 31, 2020 4:30 pm
ge_rik wrote: ↑Sat Oct 31, 2020 8:39 am
Hi Rik
That is some detailing for Tinkercad, wow, I am impressed!
Post
by ge_rik » Sun Nov 01, 2020 9:38 am
-steves- wrote: ↑Sat Oct 31, 2020 4:30 pm
Hi Rik
Thanks Steve. I'm only scratching the surface of what's achievable. You only have to look at the gallery to see what some people have produced. For example ....
- 2020-11-01-09-37-03.jpg (153.44 KiB) Viewed 4022 times
- 2020-11-01-09-16-30.jpg (160.48 KiB) Viewed 4022 times
Post
by -steves- » Thu Dec 03, 2020 10:44 am
I have updated the pictures of the original post as most people could not see them.
I have actually printed a few of these off now and made design improvements along the way. I shall post some pictures up of the changes later today hopefully.
Post
by FWLR » Thu Jan 07, 2021 8:17 am
Any chance of sharing the file Steve.
Post
by -steves- » Thu Jan 07, 2021 9:10 am
FWLR wrote: ↑Thu Jan 07, 2021 8:17 am
Sorry I can't share that one as I am selling it commercially as it took weeks to design, test, redesign etc. I do sell the the complete kits but not the files.
Post
by FWLR » Thu Jan 07, 2021 9:16 am
Oh well never mind...I thought I could have a go at printing a loco and see how I got on with it....Back to fumbling along with 3d printing then....
Post
by -steves- » Thu Jan 07, 2021 9:20 am
FWLR wrote: ↑Thu Jan 07, 2021 9:16 am
Thingiverse has a 3D printable loco on it, various versions and modifications have been done to it as well, just download them and print away, that's all I did at first. That one is far simpler to print and build than mine
Main loco link
https://www.thingiverse.com/thing:2109286
Post
by FWLR » Thu Jan 07, 2021 9:24 am
Thanks Steve, I will give it a go.
Don't suppose there would be a steamer on there would the. Must have a look later...
Post
by philipy » Thu Jan 07, 2021 10:31 am
FWLR wrote: ↑Thu Jan 07, 2021 9:24 am
Rod,
Both Rik and I have written extensively about our builds and mods of that Thingiverse loco. Just do a search.
Post
by -steves- » Thu Jan 07, 2021 10:40 am
Not that I have found and I have look quite extensively.
Post
by FWLR » Thu Jan 07, 2021 11:02 am
-steves- wrote: ↑Thu Jan 07, 2021 10:40 am
Post
by philipy » Thu Jan 07, 2021 3:55 pm
Dunno if it's any good and it seems to be a weird scale (18mm gauge) but if you want to play about with the scale and design a proper chassis it might be ok.
https://www.thingiverse.com/thing:2861368
Post
by FWLR » Fri Jan 08, 2021 9:08 am
Will look at that Philip, thank you.
