Wheels and fittings
Busted Bricks designs and manufactures a range of laser cut products
Busted Bricks
Wheels and fittings
Post by Busted Bricks » Mon Dec 04, 2017 3:04 pm
As a small scale manufacturer I often have problems sourcing supplies in small amounts at affordable prices, since many manufacturers have a high MOQ.
However I have started to work with a manufacturer in Denmark with the latest in CNC machines. He produces wheels at attractive prices and a reasonable MOQ. Obviously the larger the order, the better the prices. If you are a kit manufacturer and would like steel wheels to offer with your kits, please get in touch. At the moment we only make a plain 24mm wheel with 3mm bore, but more are in the works.
Because I have not been able to find a supplier of fittings, bushes etc. at the price/qty I wanted, I have purchased an automatic lathe. I will therefore start to manufacture a range of fittings and bushes suitable for garden railway scales. Besides a standard range of parts, I will also be able to make parts to order with a reasonable MOQ.
Please be aware that I work in metric measurements and use metric threads.
