The developing scenery of the ANLR
- Retired Director
Tut tut Midge, i'm afraid you will have to be stripped of that point for mis-indentifying it
Anyway to debunglyfy and de-rivereskify this topic, heres a pic of the new border on the upper loop a few months after planting
As you can see, most of them are quite established, however the middle conifer is rather a funny colour, and appears to have died This is despite the plant 2 to the right is the same plant species, planted at exactly the same time I have also planted a hebe in towards the back, behind the first conifer on the left.
"What the hell is that?"
"It's a bit big isn't it?"
Been a while since an update to this, but recently dad has decided to improve the one really shockingly bad area of the ANLR (scenecally), and so has been putting down concrete and suprising me every time I go out there (which isn't often at the moment )
As you can see, he has built a road which crosses the railway, and an area of concrete. This will have a couple of buildings on it, chiefly a model of a typical Welsh chapel which he has been working on. There may also be a house or 2 if there is room. The soil patches will have a couple of plants, although there will have like living in shady areas because this most certainly is one. The level crossing will have 4 gates (that will open and close allegdly), and is based on a certain manually operated one on the Ffestiniog Railway that Will knows quite well...
The level crossing gates. Not sure when dad will have this little project finished but hopefully it won't be too long, and hopefully it will be a massive improvement on what was there before, I might even start using the location for some of my videos
- Dr. Bond of the DVLR
- Retired Director
- Sir Clothem Cap
Wow, long time since I've had cause to update this, but dad has decided to work on another unloved corner of the garden. This is a small triangle of grass by the upper terminus next to the back fence. With the upper station of Nant Llywyd being close by, this is an obvious spot for a station building. Dad was about to start on a model of Beddgelert in the 1920's/30's, however this was vetoed by me, on the basis that the railway archtecture has enough Welsh Highland features. Instead, I challenged him to make a model of the Duffws terminus of the Ffestiniog Railway (the one that still exists in a car park) Dad complained a bit, did some rough sketches and came up with this...
I was more then a bit suprised by the size, I thought it was a small building! Anyway, I like it very much, and should look great at Nant Llywyd. Its only waited 3 years for a station building...
- taliesin001
I quite agree, seeing it come together I'm rather glad that I managed to change dads mind about the model to build. Not that the WHR tin stations arn't attractive, but the victorians did know what they were doingtaliesin001:58473 wrote: It's a very attractive building
- Retired Director
Dad can rarely stand idle for too long (having said that.... ) and today the nearly complete building was put down in the garden for the first time, on its newly constructed base
There was just grass there an hour or two beforehand when I had been running Gwydion. I go inside to tidy the stock away and give Gwydion the full attentions of a rag and some brasso and this is what was there when I came back out
Is your Dad a member of the forum he should be he has many talents..as for the incline they were steep affairs probably 60 degrees this is where the physics lie. Slate wagons travelled at a rate of 40mph! The inclination plus the mass of the load will govern the speed of the drum and is the reason they had brakes fitted. So its not the placement of the drum house or the height above the rails its the inclination..many accidents occurred on gravity inclines so they didnt run reliably as you may think..thats why power was applied when cost could afford.
Well university has rather killed off all of my spare time for running trains, hence it took until setting up for my steamup yesterday for Duffws to appear outside in all its glory for the first time
The building still isn't quite finished, there is the minor matter of two Roundhouse gas lamp kits, these come with grain of wheat bulbs and so this will become the ANLR's first lit building, on the outside at least
