(WH)WHR Buildings
Re: (WH)WHR Buildings
Post by Andrew » Tue Sep 04, 2018 9:45 am
tom_tom_go wrote: Mon Sep 03, 2018 9:39 pm I like the slot together design and as you are going to clad over the slots they won't show unlike on some laser wood cut kits.
It's working pretty well for me so far - I took it apart and put it back together again twice yesterday, once to cut the windows and once to modify the roof. I could've avoided all that by doing some really careful planning before I started, but I'm rather enjoying the carefree make-it-up-as-I-go-along approach. The tabs should make the finished thing stronger too, because I wouldn't have been able to brace the corners in the open waiting area.
I woke up early this morning and couldn't get back to sleep, so got up and started cutting the roof pieces at about 5:30am. Clearly i wasn't as awake as I thought because I cut them half a centimetre too short - not to worry, I'll stick on an extra bit because, as you say, it'll all get covered with corrugated cladding...
Post by Andrew » Fri Sep 07, 2018 10:02 am
Hello!
I've made a little more progress on this project, cobbling a roof together and cutting the end wall to represent the wooden framing that is a feature of the real thing:
Station building 5.jpg (258.63 KiB) Viewed 9086 times
The roof was cut from some foamboard that was going to be thrown away somewhere i used to work. It's too good to waste but not terribly pleasant to work with - dense and difficult to cut, and there's a very sticky residue left behind when I peel off the display that used to be stuck t the front. Theat's why there are all sorts of horrors stuck to the roof - they'll all be covered up eventually...
I've made a start on cutting out the corrugated cladding too. Only one piece done so far but that was much easier than I thought so I'm hoping to make more progress at the weekend.
Station building 6.jpg (214.87 KiB) Viewed 9086 times
Station building 7.jpg (205.09 KiB) Viewed 9086 times
I'm quite pleased with how the internal frame's looking - the back of the waiting area will look the same, but the framing there will only be cosmetic, I'm going to leave the rear wall intact for extra strength. There should really be a window in the back walls of the waiting area and office, but there's nothing to see there and no light to be had, so I'm not going to bother...
Cheers all,
Post by philipy » Fri Sep 07, 2018 10:47 am
That framing does look good. I didn't read it properly and I was just going to suggest cosmetic framing on the back wall, but fortunately I read it again properly before making an idiot of myself! :oops:
Post by tom_tom_go » Fri Sep 07, 2018 10:57 am
Who makes the corrugated sheets?
Post by Andrew » Fri Sep 07, 2018 1:06 pm
The one in the picture is Tenmille, purchased directly from them. It's actually their asbestos sheeting, intended for G1 I think, but it's about right for corrugated iron in 16mm. It's been easy to mark and cut, but it's quite thin (might become brittle after a while) and fairly expensive (c£5 for a 200x250mm sheet). The finished building will also feature some 25-year old Brandbright corrugated sheet, some rescued from previous projects - unfortunately that no longer seems to be available.
Post by Andrew » Mon Sep 10, 2018 8:40 am
Hello all,
I made a little more progress on the station building over the weekend - my modelling time seems to come in small chunks, an hour here, half-an-hour there, which is tricky with some projects but seems to be working OK for this one...
The corrugated cladding is now in permanently in place at one end:
Station 10.jpg (185.11 KiB) Viewed 5938 times
The back wall of the waiting area now has its cosmetic wooden frame - the black corrugated sheet here is the old Brandbright stuff, happily just the same size as Tenmille asbestos sheet. The latter will need pins adding to represent whatever it is corrugated iron's fixed with - the Brandbright stuff has that.
Station building 8.jpg (258.44 KiB) Viewed 5938 times
And at the other end a door has been added to allow access to the office - the next job will be to add another one on the other side from the office to the waiting area.
Station building 9.jpg (265.36 KiB) Viewed 5938 times
That's all for now, but it's taking shape...
Post by philipy » Mon Sep 10, 2018 8:47 am
Andrew wrote: Mon Sep 10, 2018 8:40 am
It certainly is, and very nicely too.
Post by Peter Butler » Mon Sep 10, 2018 10:41 am
Looks really good, well detailed and convincing structure. Well worth spending time adding the interior framing, makes all the difference.
Post by Andrew » Mon Sep 10, 2018 11:30 am
Peter Butler wrote: Mon Sep 10, 2018 10:41 am Well worth spending time adding the interior framing, makes all the difference.
I think so - I didn't realise how important it was until I looked carefully at some photos of the real thing. My daughter prefers the framed inside to the plain outside and wants me to reassemble it inside out... You can't tell from the photos, but the framing is scribed with a saw blade to represent the grain in the timber - I believe the technique's known as "The Butler Method"...
Post by ge_rik » Mon Sep 10, 2018 11:47 am
Looking good, Andrew. I like the combination of techniques. That corrugated sheeting looks effective.
Post by Peter Butler » Mon Sep 10, 2018 4:15 pm
Andrew wrote: Mon Sep 10, 2018 11:30 am
Peter Butler wrote: Mon Sep 10, 2018 10:41 am ...... the framing is scribed with a saw blade to represent the grain in the timber - I believe the technique's known as "The Butler Method"...
I will pass on your comments to my Gentleman's Gentleman, he will be delighted to hear his efforts have been recognised!
Post by Andrew » Wed Sep 12, 2018 9:08 am
Good morning!
Progress this week has been hampered a little by my taking my "slot and tab" construction technique a step too far on Monday evening when I attempted to cut a slot in my finger... Whilst cutting a recess into the foam board I applied too much pressure (and not enough care), snapping the end off the knife blade and sending the remaining stump through my nail and into my index finger. That was enough to stop any further modelling that evening, but on the whole I seem to have got away with it very lightly...
Somewhat gingerly, I picked up my tools again yesterday evening and set to work on the plastic "woodwork" that surrounds the opening to the waiting area. There's not much to see, the work mostly involving a lot of head-scratching and a little light Butler-ing to create the grain effect, but here's where I'm at so far:
Station building 11.jpg (260.19 KiB) Viewed 5863 times
Mr Tarkin has also sustained an injury and is rubbing his head whilst pointing to the offending piece of joinery. Those diagonal bits do come out a little low (even accepting that the figure's fairly tall), but I'll just have to use short figures there! I was wondering about a representation of Miriam Roberts, Beddgelert's "girl stationmistress", but she wore Welsh national costume and I fear the woodwork may knock her stovepipe hat off...
Post by Lonsdaler » Wed Sep 12, 2018 9:29 am
Through the nail? A very painful injury :o Very early on in the building of my garden railway I managed to introduce two of my fingers to my circular saw :roll: I strongly recommend that people do not try this at home, work or anywhere else!
The most embarrassing part of the whole palaver was fainting in the kitchen and hitting my head on the stone floor, which added a whole new level of drama to the incident!
The building looks great - can't wait to see it finished, and I wouldn't worry about the low level of the angled support - your customers will soon learn where it is :mrgreen:
Post by philipy » Wed Sep 12, 2018 11:30 am
Think Tom needs to add a banner to the top of the page " WARNING! Railway modelling can seriously damage your health"
Post by tom_tom_go » Wed Sep 12, 2018 11:41 am
philipy wrote: Wed Sep 12, 2018 11:30 am Think Tom needs to add a banner to the top of the page " WARNING! Railway modelling can seriously damage your health"
Physically and mentally!
Post by ge_rik » Wed Sep 12, 2018 1:38 pm
tom_tom_go wrote: Wed Sep 12, 2018 11:41 am
And financially
Post by Andrew » Thu Sep 13, 2018 8:50 am
Ah, but modelling can be very therapeutic too - I reckon it's all about the right project at the right time, and when you're in the right head-space...
Anyway, I added the interior door yesterday evening, before disassembling the thing for the last time, to make sure I'd got all of the protective film off the foam board:
Station building 12.jpg (279.3 KiB) Viewed 5981 times
I'm busy this evening, but I hope to cut and fit the cladding at the weekend, and then it should really begin to look the part...
Post by tom_tom_go » Thu Sep 13, 2018 9:11 am
It looks like the Empire dude has discovered the force and destroyed the building!
Post by Peter Butler » Thu Sep 13, 2018 10:24 am
Displayed on a red and white background makes me think of the barber's pole, blood and bandage...... makes me shiver just thinking about the injury sustained.
invicta280
Post by invicta280 » Thu Sep 13, 2018 8:08 pm
Craft knives can indeed be lethal. I was once hospitalized (outpatient) courtesy of Swann- Morton. The safety cover was a piece of plastic heat crimped on to the blade and Dingbat here tried to remove the cover by using my thumbnail against the cover with some force, thinking that I was applying pressure to the back of the blade. When the cover slipped off the back of my thumb opened up like a sausage cut lengthways, ; down to the bone! Forty years later the scar is still well defined. :|
