Now that my vertical boilered loco, 'Snail' has been reduced in scale I put the old driver figure next to the new one to see the difference. Looking at the picture it seems as though the larger one is superimposed but he really is standing next to the loco.......
- IMG_6205.JPG (94.2 KiB) Viewed 6580 times
Quite a difference between the scales of my BURPS stock and the Emetts.
Time for something different.
Some years ago I installed two inclines for my disused stone quarry workings. Since then the ballast has gradually washed away down the slope revealing the underlay. It was time to fix the problem but the cause is the fact that dropping loose ballast on a slope and expecting it, and the SBR, to stay put is asking too much.
Time for a re-think on design options and the solution is to make the trackwork and ballast on a flat, horizontal surface first and then apply to the incline when finished. So a black, 1mm thick HIP sheet was cut to size and the track laid on long, raised strips of HIP sleeper strip which was grained, painted and weathered.....
- IMG_6200.JPG (92.47 KiB) Viewed 6580 times
- IMG_6201.JPG (150.66 KiB) Viewed 6580 times
As can be seen, the HIP has been scored to give the SBR a 'key' and mix of fine ballast and waterproof cement applied and well soaked in neat SBR and left to dry.....
- IMG_6204.JPG (180.48 KiB) Viewed 6580 times
Looks alarming when it is wet but will dry clear.... eventually!
The two sites for the bases, when ready, look like this and they just slide down on top......
- IMG_6203.JPG (195.78 KiB) Viewed 6580 times
- IMG_6202.JPG (193.47 KiB) Viewed 6580 times
