Yes Paul, I agree about the instructions being a little vague, although originally I put it down to my own inexperience with making kits and my lack of knowledge when it comes to technical terms of the prototype. I have varied from the suggested sequence too as I didn't want any of the doors to open, neither did I want to fit the outer overlays in place until after painting. Today I have struggled to work out a section which described how to make parts from raw materials without any description of their final purpose or location. Eventually I resorted to the excellent drawing by Nigel Town, published in the 16mm Association Guide to the Ffestiniog Railway, which has helped me enormously.
I still rate the kit highly as it is well detailed and produced. To be able to manufacture something as intricate as that is a great skill in itself and requires much planning, so hats off to Lineside Hut for that.
Clearly there is still some way for me to go before it is finished as no bogies, wheels or buffers are supplied. There is no description of the wheel diameter or ride height so the 16mm drawings answer that. The handrail at the front/back (? not clarified), is very delicate and needs replacing with brass, which I'm in the process of doing now. The one supplied appears to be far too low anyway so it will be improved with a replacement, also I will add some bolt detail on the frame which is shown on the drawing.
I'm still undecided about colour as it will not be a true scale model of the prototype, as long as it looks well with my other stock I will be content.
I am content when I do anything with our line Peter.
Love where you have placed those street light’s also, they all look just perfect….
(Having a bit of an issue with my eyes this morning) not checking on what I have written first……….
Just catching up after a few days away without internet. Those photos of the village after the rain shower are so realistic, Peter. The sheen on the pavement really adds to the atmosphere. The positioning of the buildings and colouring looks so natural. Hats off to you sir, not only for your modelling skills, but also for the vision needed to visualise the whole scene when you made that initial cut into the first piece of plasticard.
- Soar Valley Light
Wow, Peter! I had to look twice to be sure of the scale Well domne indeed
Congratulations on the village Peter, really well thought out and beautifully executed, and what better than a rainy day to photograph a Welsh village
I'm following your build for the Lineside Hut kits as well. I bought a couple of their wagon kits at Llanfair, but haven't started them yet.
Meanwhile, back to the CRV kit which is progressing well. The roof is now complete with all strips carefully laid in accordance with the instructions, no problems encountered and everything in its place. It is essential that the cradle supplied is used to hold everything square while the glue sets. The cradle itself is very flimsy and light so I added an extra plywood base which helps.....
Additional detail has also been added following the 16mm Association drawing, this shows sturdy angle brackets supporting the truss rods which I made from brass angle, not the strip supplied in the kit, also bolt heads along the chassis frame and headstock.... Tomorrow, a new balcony end with handrail more to scale and stronger than the original will be finished and fitted, then to the paint shop!
After sanding the wooden strips, the material is now attached to the roof top to give the canvas appearance, although as the prototype has a white roof, black material is supplied! Instead I used white curtain lining, which is probably the same material anyway?Additional detail has also been added following the 16mm Association drawing, this shows sturdy angle brackets supporting the truss rods which I made from brass angle, not the strip supplied in the kit, also bolt heads along the chassis frame and headstock.... Tomorrow, a new balcony end with handrail more to scale and stronger than the original will be finished and fitted, then to the paint shop!
Everybody else has already said it - but your 'Village in the rain' pictures are extraordinary.
I particularly like the fourth one, appearing to look up hill towards the 'weeping angel' in front of the clock tower (which is facing the other way this time. Spooky). The wet road, blokes in doorways checking the weather after the shower, drainpipe in foreground, lean-to with corrugated roof, patchy rendering, trees in background... totally convincing, especially without the cars, I think.
Wonderful.
Wonderful.
Many thanks for your kind remarks, I'm pleased you approve! I had to look back to see what you mean about the clock tower and agree that it looks as though it has turned, however, it is because of the angle of the pedestrianised road in conjunction with the High Street which makes it look that way. True, I did initially have it facing at 90 degrees to its present view but thought it would better serve the visitors and residents if it was showing to the shopping area. A minor detail but important to them no doubt!BertieB wrote: ↑Thu Oct 11, 2018 10:56 pm Everybody else has already said it - but your 'Village in the rain' pictures are extraordinary.
Wonderful.
Incidentally, the 'weeping angel' is in fact the 'Angel of the West', my homage to Antony Gormley, who I worked with many years ago before he became a superstar sculptor.
I actually like Peter’s cars…..
And here it is.... Compare this with the original and there is a striking difference. However, I can understand why when the laser cut is so thin it needs to be as small as possible to have any chance of survival.....Peter Butler wrote: ↑Thu Oct 11, 2018 9:46 pm
I've always admired this van, unfortunately nothing like it existed down here. Another great build Peter.
Lovely work as always, Peter.
On a different subject, I hope you are OK in the awful weather your part of the world is having? (Now you'll find out just how good your village drains really are!)
Thats a nice job and it does make the original look very flimsy.
We also had very strong winds and the rain was relentless…Anne put a couple of birdhouses on the line just to see how they looked….they were the only things that didn’t get blown away……
The weather has been wild over the past couple of days, torrential rain and winds to bring oak tree branches down. I had enough warning to put the village away inside a shed, otherwise it would be in bits by now! The volume of water in the streams shows how heavy the rain has been..... During the dry spell this waterfall had flow similar to a dripping tap.....
As for the railway, I am delighted to say I am impressed with the drains which seem to be fully operational. Compare the village street with the adjacent footpath which has become a lake.....
Wow Peter, that’s a stream…….
The drains have really done their work here, they have diverted all the water to the path…..
Seriously Peter, they are a brilliant job….Worthy of “Build of the Year” for me….
Just in case anyone wondered what I have been up to during the past couple of weeks, I have concentrated on my passenger stock builds. The initial four compartment carriage from Lineside Hut looked so good (to me) I ordered another set of sides and ends and carried out my intention of cutting the sides in half to make 2, two compartment coaches.....
The interiors have been fitted with the Lineside Hut seating and passengers from a Chinese supplier.....
The four compartment carriage has also been populated.....
The CRV has progressed with all overlays now in place and decals on order to finish off the exterior. I have to say how impressed I have been with the quality of material and the way everything fits perfectly, even if the instructions have been slightly challenging. From the start I had no intention of making any of the doors open (although they can be made to do so) and it has built into a very strong vehicle which looks most convincing......
Currently adding bogies and step to the four comp. then only the roof to add.The best things in life are free.... so why am I doing this?
Magnificent paint and assembly work, Peter. I've always been an admirer of these types of coachwork with the separate overlays. Yours will be a beautiful passenger set, especially ending in the curly roofed van.
Excellent craftsmanship Peter such beautiful coaches you are modelling. Looking forward to seeing them completed.
Kevin
Fantastic builds Peter…I want them….
Who is the Chinese supplier please….
Superb models Peter. The paint finish is top quality. Your progress has put me to shame as my W&LLR Brake van has stalled because life has gotten in the way and will do so for a few more days at least .
Users browsing this forum: HarryW and 8 guests
