Now that is a superb model again Peter. It's looks just brilliant on the train. Jealous about how you come to think of these wonderful models..
Thank you Grant, as explained in the description of the build, the awning was the most difficult part to replicate as material is not easy to scale down to behave correctly. Having been a picture framer for most of my professional life I am used to stretching embroideries etc. This was a great advantage when fixing the material to the framework of the roof. It is bonded using PVA which gave some 'wiggle time' but then took a while to set, hence the long time-scale.LNR wrote: ↑Sat Jun 06, 2020 12:50 am Replicating the way canvas, cloth, and other soft materials appear on the real thing is always a challenge in my view, but you have certainly nailed it there once again Peter. The creases, and sag just right. Very well done.
PS I'm wondering did Diane have a hand in the hemming of the awning?
In the past, when making tarpaulin sheeting, I have asked Diane to sew hems for me, unfortunately her machine makes far too large loops in the cotton, which is not what I was trying to achieve, so, no...... no stitching this time!
As Grant says, you've modelled the canvas covers really convincingly. Another masterpiece!
Hi Peter,
Wonderful build, I would have had a hard time covering up the excellent work on the greater portion of the coach.
On the prototype, were the strangely shaped uprights to keep tension on the canvas?
Tim
Tim
Hi Tim and thanks for your comment, much appreciated. I have absolutely no idea why the supports are the shape they are, other than it was built during a period of ornamentation to anything being constructed, however, I imagine they could have a stabilising effect on sideways movement too? I think an engineer is needed to answer your question.
Continuing with the kit reviews I was doing while making up the Bug Box vehicles, I thought I would add the Ffestiniog 'Sentry' Guards Van to complete the set. I was introduced to the Jurassic range, which I have never tried before, and ordered the kit. This is the TM1 kit which Mike produces for £40.00 (including postage).
His communication was excellent and delivery prompt.
The kit includes the wooden parts only, no wheels, buffers or detail parts. It is well cut from sturdy plywood to form the inner shell and high quality hardwood outer lining side and end panel overlays with well defined planking etc...... I had one problem however..... the DVD supplied to show how to assemble the kit would not play, this was no fault of the DVD itself, rather my inability to operate my own equipment, so I had to wing it.
It went together well and was easy enough to assemble, even without instructions......
I always paint overlays separately and attach later, this was no exception and worked well...... Fortunately I had wheels and bearings in stock which I fitted to the chassis sides supplied. I added spacers to the side frames to make a complete separate unit which made it easier to attach later..... So..... overall a very well thought out kit of good quality materials. Very good service from Mike and great value for money.
I really must become more 'regular' in my browsing of the forum, but I have at least had the pleasure of reading the 'Great Ffestiniog Kit Build' in one go. Your productivity and attention to detail never fail to impress Peter - well done. Like many, I hadn't heard of the Jerry Irwin kits, so thanks for bringing those to our attention.
I had a conversation with Ivan a couple of years ago at Llanfair. I wanted another freelance 4 wheel coach and he was producing them in plywood again (my previous had been mdf). He said that was what the customers appeared to want, so he had reverted to it.. Like you, I think the mdf gives a superior finish.
Good stuff yet again.
Hi Peter,
Is the lambs tongue effect on the frame work a product of clever laser work or diligent building?
Tim
Tim
Great review on this build Peter. Another to consider, but I need to buy more wheels and bearings and axle boxes. But it confuses me on what size wheels to buy. There are a lot of kits with different sizes in height and width, so for me using the correct wheels is a bit of an issue. Still it's fun building new kits and hoping that I have got the correct wheels....
So that's what it's called. I was going to ask the same question, except I didn't know the nomenclature. I assume we're both referring to the fancy bevelling on the outside framework? If not, was it done for you or is it further evidence of your steady hand and attention to detail?
The lamb's tongue effect is laser cut into the kit. It is the main reason I decided to buy that kit as it represents an important detail of the prototype. It isn't shown at its best in the picture as the strong natural light reflects from the surfaces, they are not as pronounced as that when viewed close up.
I spent some time sanding, sealing, sanding etc. etc..... to make a good paint surface and I am satisfied with the result. Due to the panel being cut from plywood, the end grain of underlying layers becomes exposed making it more difficult to get a perfect finish. If this had been cut from MDF I think the effect could be improved.
What's the "lambs tongue effect"..
Not the best at these things, I have looked and looked at the photos, but I can't see a "lambs tongue effect" for the life of me...
I must admit I hadn't heard the expression 'lambs tongue' either Rod, but it seems to be the name given to the parallel bevel edges on the framework supporting the side planking. It is another detail which wouldn't be considered today on cost grounds but shows off the skill of the craftsmen building the original 19th.C. van.
Beveled edge, of course I can see it now. Funny expression that though, "Lambs Tongue"
Thanks Peter for the explanation.
I couldn't find a clear enough photo of the prototype sentry van online, but the decoration looks like what's known as a 'stopped bevel', which can be done with a spindle moulder. Although as Peter says, it would have been done with hand tools when the original sentry vans were built in the 19th C.Peter Butler wrote: ↑Thu Jun 11, 2020 9:46 am I must admit I hadn't heard the expression 'lambs tongue' either Rod, but it seems to be the name given to the parallel bevel edges on the framework supporting the side planking. It is another detail which wouldn't be considered today on cost grounds but shows off the skill of the craftsmen building the original 19th.C. van.
A lambs tongue is a more complex shape used to finish the end of the bevel. There's a blog here showing how to make one using hand tools, starting from a machined stopped bevel. https://blog.woodworkingtooltips.com/2 ... s-tongues/
To complicate matters, here in Oz the term lambs tongue is also used to describe an edwardian moulding design used for skirting boards and architraves. Bunnings still sell it.......
Hello!
Just catching up after a busy few days - that van's lovely Peter! A very nice kit, beautifully made.
They were still beveling edges after the Victorian era, at Swindon at least - I took a ride on the Avon Valley Railway's "Toad" 1940-built brake last year, and the chap who'd overseen its restoration pointed out how they'd recreated that look when they'd had to replace some wood around the windows.
The "Flying Bench" with its covers is wonderful too. There's more information here if you're interested: https://www.festipedia.org.uk/wiki/The_Flying_Bench
I've got an IP kit for one of them in their later guise, rebuilt as "porthole" bug boxes, which I must get round to building some time.
Anyway, congratulations, the two of them make a fine end to a splendid rake.
Thanks Andrew, I did use that link during my very basic research into the tent canopy structure. That is about all I could find but I was able to copy enough detail from the pictures to make a reasonable representation. I think it passes my 'looks like' test, so I'm happy with the end result.
It would be nice to see your IP 'Porthole' carriage under construction and how you find the build compares with others you have made. Every manufacturer differs in materials and assembly, which is what I tried to show with my reviews.
Thanks for your reply Graeme. It looks like the website won't work in European countries I'am afraid
Still you have explained a bit more about what a "Lambs Tongue" is. Thank you.
Having now completed the Bug Box kits I had an opportunity to run all ten vehicles on the railway today. Beforehand the weather has said 'No!' to that possibility, with rain falling heavily to make up for the long dry spell we have recently enjoyed???
It was certainly gratifying to see them all following in line behind the double Fairlie, and they all behaved themselves perfectly....
I am still unsure about the Lamb's Tongue description and having checked on Google I have discovered that it is usually more common on skirting, or other flat timber ornament, on one edge only. I then looked up 'Stopped chamfer' and this seems to be more of the style I imagine is used on the Sentry Van, although it might include a convex or concave element too?
Good question for a pub quiz, but that will have to wait !
Now that is a train. Looks brilliant Peter and so in keeping with your line, which by the way is still one of the best on the forum.
