Post by Andrew » Mon Nov 05, 2012 10:33 am
I thought I'd start a thread to record the progress of my new garden railway, the (Windmill Hill) Welsh Highland.
The new line replaces my old West Kent Light Railway, a Colonel Stephens inspired line that was demolished to make way for a house extension in 2010. As the name suggests the new railway draws inspiration from the Welsh Highland, encouraged by the rebuilding of that line. That said, it's not the shiny modern era with Garratts and the like that I'll be modelling, but the 1920s, when Russell and "his" shedmates struggled to maintain a viable service in the face of recession and road competition.
Since the old line closed I've been saving for WHR locos, scratchbuilding rolling stock and gradually constructing my new line. It's much closer to ground-level than my old line for increased realism (I hope!) and will feature steep gradients (1 in 50-ish) both to better represent the real thing and also to match the sloping profile of the garden.
The plan is that the line will represent a fictitious branch off the "main line", originally built by the North Wales Narrow Gauge Railways and then extended during the WHR construction in the early 20s. That will allow me to feature the solid stone and brick architecture of the NWNGR and the WHR's corrugated iron. I'm currently planning an end to end line but should be able to reconfigure it as a circuit if I find I'm getting bored.
The first section I've built will eventually become the passing station in the middle of the line and a short length of track beginning the descent to the lower terminus:
Here's my old Friog diesel on a test train, standing in what will be the platform road - obviously there's till a great deal to do! Just as First Great Western are forever making tannoy announcements about the "heightened security situation" at Bristol Temple Meads (presumably to justify the occasional presence of armed police) these dangerous times have necessitated that the Thompson Twins are on duty to ensure nothing untoward takes place.
Initial tests have shown that I need to do more work to increase the distance between the loop's clearance points before I finally fix down and ballast the track. Even then my trains may need to be shorter than I'd originally intended.
The test train ventured down as far as the current "head of steel" - hopefully that will be extended around the edge of the patio over the winter, followed by some scenic work on the existing section in the spring.
hussra
Post by hussra » Mon Nov 05, 2012 1:11 pm
Always good to see another new line starting - look forward to watching progress!
Richard Huss
in sunny Solihull
Post by Andrew » Fri Nov 16, 2012 10:37 am
Last weekend saw further progress on the new line, with construction moving to the section that will go round the patio. The trackbed will consist of modified bits of my old line together with a new curving section in front of the plum tree. My mate Mark kindly agreed to lend a hand and proved that two heads are indeed better than one, even if we did end up working in the dark by the light of the living room lamp... By the end of the session we'd got the new curve almost finished and put up the brackets that will support the rest of the trackbed. Now I need to put it all together and lay the track.
Here's Mark hard at work. Actually I think he's in the process of phoning his other half to let her know that our engineering works had overrun...
Post by Narrow Minded » Fri Nov 16, 2012 5:18 pm
Hmmm, looks familiar
Post by Andrew » Mon Nov 19, 2012 10:46 am
Yeah, it felt a bit like that! I wish I'd dug out the hi-vis vest I've got somewhere and made Mark wear that... It's a really old one in the style of a natty little waistcoat, with loads of buttons and a label inside reading "Bristish Railways" - my uncle found it on a building site years ago...
Post by Andrew » Mon Dec 03, 2012 1:27 pm
Hello again,
A couple of cold wet weekends of work have seen the new line extended by about 20' or so round the patio. This section is on a timber structure designed to take up as little space as possible - come the spring I'll add pots etc underneath to try to make it all look a bit more natural. It combines new parts with bits recycled from the old railway, but because it's all edged and fenced with old bits it looks like it's been there a while. Cosmetic tidying up will include restringing all the fencing because most of it's broken.
The line's now 40 or 50 feet long, not a lot, but enough to justify a steam-up, particularly because I was keen to see how Russell would manage the sharp (3'6" radius) curves and steep (1 in 50-ish) gradients. I raised steam and, after a quick light engine test run, coupled up three quite heavy wooden-bodied carriages - I'm pleased to report that Russell coped beautifully, chuffing merrily up and down until the batteries in the transmitter appeared to go flat. They hadn't, just fallen out (!), but I didn't spot that 'til later... Russell is fitted with a Summerlands Chuffer and made a lovely racket heading up the bank...
Unfortunately the camera batteries really had died so I couldn't capture the wonderful plume of steam in the cold air but had to settle for these shots posed as dusk fell - they've been heavily Photoshopped to make them even vaguely presentable!
Although the garden's a bit bleak and barren at the moment, when there are pots on the patio, the beds are planted up and the fruit trees (from front to rear cherry, apple and plum) are in bloom it should all begin to look quite nice...
Post by Andrew » Sun Jan 13, 2013 6:00 pm
Hello again,
I'm pleased to report that, despite the short length of line currently available and a lack of facilities usually associated with steam locos (like run-round loops, or even stations), regular train services can return to my back garden following the introduction of specially designed Railcar Reversal Ramps. Otherwise known as bent bits of old coat-hanger, the ramps enable my trusty Faller railcar to trundle merrily back and forth, the reversing lever underneath being triggered at each end of the line.
I might not look like anything that ever ran on the old WHR, but for now it will do the job while I build the rest of the line and catch up on the gardening...
Post by Andrew » Mon Jan 21, 2013 10:31 am
I was going to stay indoors in the warm at the weekend, but in the end I just couldn't resist - I had to brush the snow off my short running line and raise steam.
I imagine poor Driver Barleymow (an ex-Early Learning Farmer) was cursing whoever it was that decided that trundling two empty coal trucks about was reason enough to brave the wintery conditions, and that the open-cabbed Regner was the loco to do it with! He was probably right - I seem to have picked up a cold now...
Apologies for the poor quality photos, may try to find better ones later...
Dr. Bond of the DVLR
Post by Dr. Bond of the DVLR » Mon Jan 21, 2013 7:48 pm
Brrr, I like the wiggle in the fenced section!
Post by Andrew » Mon May 13, 2013 12:42 pm
Hello again,
The warmer weather of the last few weeks (where's it gone?!) has seen me out in the garden giving the under-construction railway a bit of a cosmetic makeover. I've refurbished the old West Kent Light Railway buildings, moved existing plants and begged new ones ferom family, and spread slate chippings round fairly liberally. It's not going to look like this in the longer-term but this work has smartened everything up while I construct the next section. Sorting out the trackbed and ballasting is waiting until that extension's built - then I'll fettle the whole lot and sget itr running really smoothly before finishing the job.
At the bottom end of the current line the recycled fencing has been re-strung with fishing wire and the first few potted plants added to soften the line's impact...
Where the line rejoins the garden proper I've added some rocks and the beginnings of some planting. I need to find a thin sice of matcing rock to place behind the hill to make a cutting - the idea is that eventually it looks like the train is trundling through the lower slopes of a larger hillside. I'm not sure what the rock is and would have prefered slate, but this was what was available in local skips!The box bush has now been moved twice since planting, iI hope it survives...
The wonky section of stone walling is an experiment using some textured expanded polystyrene found in a neighbour's skip (again!). I painted it with acrylics about 9 months ago and it's been outside ever since - it seems to be holding up OK so I think I'll use the technique for the tretaining wall and bridge abutments on this section.
The next section of line will change completely, hopefully becoming much rockier. For now there's my old PW hut and lots of slate chippings...
The station uses the WKLR's old Windmill Hill station building, a converted child's toy - and not designed to be seen from this angle!
It looks better from this side - it'll do until it's replaced with something in the NWNGR style...
The upper end of the line currently peters out underneath the deck, next to the wood store. I rebuilt that last week and although it's hardly a scenic delight it will inevitably form the backdrop to many of the (WH)WHR's workings - and it gave me an excuse to run a lumber train! I may have to fit my locos with spark arresters!
That's all for now. I think the line's likely to stay looking like this while I build the extension to the lower terminus...
Big Al
Post by Big Al » Mon May 13, 2013 2:32 pm
That's coming along nicely, starting to look good. :)
Post by Dr. Bond of the DVLR » Mon May 13, 2013 2:35 pm
Looks like there's a huge amount of potential in this line, I can allready see where some of the "photo" spots will be. Keep up the good work!
Post by laalratty » Mon May 13, 2013 8:38 pm
Nice work, getting slate to improve the look of my line I found was a great excuse to get a parent to drive me to North Wales (although I'd drive myself these days), in particular the waste tips at Cwmorthin are very accessible. Not quite sure of the legal status of acquiring slate this way though.... :roll:
Post by Andrew » Wed May 15, 2013 12:57 pm
laalratty:83399 wrote:Nice work, getting slate to improve the look of my line I found was a great excuse to get a parent to drive me to North Wales (although I'd drive myself these days), in particular the waste tips at Cwmorthin are very accessible. Not quite sure of the legal status of acquiring  slate this way though.... :roll:
Yes, I'd wondered about liberating some waste slate from a tip somewhere.
Legally I guess it must be dubious, the stuff must belong to someone whether they want it or not.
Morally I reckon it's probably OK, depending on where it's from - if it's from a slag heap hundreds of feet high that's been there unwanted for 150 years that would seem to me to be OK.
I don't know if there's an environmental consideration? Is a slate tip an important eco-system? Would I risk disturbing the nesting place of the Lesser-Spotted Slate Warblers or distracting the endangered Purple Crested Slag Lizard from the task in hand during the important mating season? Dunno...
Of course it would cost a whole load to drive from Bristol to Wales, but I could do with a nice inspirational trip in that direction...
Post by Narrow Minded » Wed May 15, 2013 5:42 pm
Coming along very nicely Andrew, and personally I really like the log train photo :D
Not being a Welsh based railway, I've not had the slate quarry quandary, but I too have been "liberating" stone while on my trips around the UK - just the odd one or two from here and there which is slowly building up and yes, I have suffered the "moral dilemma" of taking it.
It's never come from a wall or other structure, but always "in the wild", so I've applied the Native American philosophy - which includes Show deep respect for the mineral world.. (I bring it home to look after it! ;) )
As for Windmill Hill station building, I have one of those, the old Koala Brothers House :lol: I've replaced mine as a station building and I'm thinking of recycling it as some sort of yard office (I just love the little bell by the side door ;) )
Keep up the good work, looking forward to progress.
Post by laalratty » Wed May 15, 2013 8:51 pm
My impression has always been that the clue is in the name, "waste" tip meaning that it is just waste. I don't think there is an environmental impact as such, very little if anything appears to be able to grow in it, although eventually stuff would probably fight its way through, especially if it was removed. What does concern me is ownership (although with the company presumably only existing in skeleton form, if at all, then they might not care) or more importantly stability. The very last thing I'd want to see if several thousand tons of waste careering down the hill and landing on Tanygrisiau, which is what would happen if Cwmorthin went. Hence I tried to make sure I only took stuff off the top, or from out of the beck (which is the one the FfR crosses just before Tanygrisiau station). But yes, a visit to get some raw material can also be inspirational in other ways ;)
Post by Andrew » Wed May 15, 2013 10:29 pm
Good points chaps, thank you. I reckon I'm convinced - now I just need to convince the rest of the family that a trip to a North Wales slag heap is a good idea. Maybe I could "get lost" on the way to IKEA one weekend???
Post by Andrew » Sat Jun 15, 2013 6:23 pm
Hello again,
The better weather of the last few weeks has seen some progress on the railway, with this short extension across the back gate and round the corner.
It doesn't look like much, but this area was previously a dumping ground for building materials and assorted junk, so it took a fair bit of work just to clear the site. Some of that junk will go back temporarily while I build the next section, the lower terminus - it looks like that's going to be a relatively big job... Eventually the upper terminus will sit on top of the curve in the picture, hiding it from view.
Initial testing was carried out between showers this afternoon using my Accucraft Baldwin, just back from having a little work carried out at Chuffed 2 Bits. It ran very well, and the new Summerlands chuffer sounded great, although its sensitive front bogie did reveal one curve that will need looking at. The curve in question had already given me a clue - my FR bogie carriage derails at the same bit.
It looks as though it's going to be a tricky line to drive - steep and variable gradients and sharp curves. I've not yet got the hang of smoothly running along the whole line, I reckon it'll take a fair bit of practice. Ballasting will help by ironing out some of the smaller lumps and bumps, but I won't do that until the next section's laid...
Post by Andrew » Mon Aug 05, 2013 12:23 pm
Hello again...
I've been doing a little more scenic work recently, adding the rear wall of the short cutting pictured up the thread a little. It was a very tight location, with little space between the railway line and the fence, but I managed to scrounge some thin bits of stone from some friends who were doing work in the garden of the old vicarage where they live - and so Vicarage Cutting was born. The stone has been mortared in and I've started encouraging a little plant growth.
I had a change of plan where ballasting was concerned. I was going to complete my little line as far as the lower terminus (I started from the middle) and then worry about fettling the track, ballasting etc. But I wasn't happy with how trains were running on the first bit, too much bouncing about, so I decided to try and put that right before I built any more, starting in my nice new cutting. So the track was levelled and a mixture of ready-mix mortar, grit and sieved earth applied and watered into place. I'm quite pleased with it, although it looks a little pale when it's very dry, I may slosh some dilute brown masonry paint over it - or just leave it weather naturally.
The next section to be ballasted will be the station. In preparation for that I've finalised the track layout (better clearances and a more narrow gauge look I think, it was all too parallel before...) and added the platform edging made from blocks of slate. Here it is yesterday afternoon...
Cheers all,
hussra
Post by hussra » Tue Aug 06, 2013 10:15 am
The cutting looks great - nicely done. It's always a hard call as to whether to finish off an area, or press on and lay more track...
Richard Huss
in sunny Solihull
