She looked great and definitely benefited from running in - a very nifty little loco and a lovely build.
That does look good! I'd be inclined to use 3 x 14500 (AA sized) or maybe even only two li-ion cells, but I know some are wary of using li-ion.
Thanks for the tip about getting the rivets evenly spaced on a curved surface. Another great idea filed away!
Thanks Rik,
I have no experience of Lithium ion batteries but certainly two AA size would have been much easier to accommodate and 7.4 volts would be plenty. I am wary of LiPos but are Li ion different or is there still a need for specific charging different to Nimh?
I claim no credit for the masking tape Idea, I was given it at the 2022 Garden Railway Show in Peterborough and have merely shared it.
Hi Philgilfachphil wrote: ↑Wed Mar 01, 2023 1:45 pm ..... I am wary of LiPos but are Li ion different or is there still a need for specific charging different to Nimh?
Yes - lithium cells of whichever format need to be carefully charged and protected to ensure they don't over discharge. So saying, as long as they protection circuitry and are charged properly they are non problematic. I've been using them safely for ten years or so - and most battery powered electronic gadgetry uses them.
My latest project is a Plateway Models Alpine Balcony coach, bought last autumn at the Llanfair Caereinion show. The kit is laser cut plywood, lots of parts, some very small, and includes Binnie wheels, axles boxes and couplings and clear plastic glazing. There are several jigs included and I made up others for various tasks of the construction. I did not take photos as I went along as much was experimental and I was not confident enough in the outcome to document fully!
Here are some pictures of the very nearly finished coach, it awaits 3D printed door handles which are on order from Jerry Irwin.
Apart from the roof, which had a coat of dark wood stain followed by two of dark grey acrylic primer, and the undercarriage and brake handle which are matt black Humbrol enamel, all the plywood was finished with wood varnish or wood stains.
The wheels have been set at greater spacing than designed in the kit as I felt with a shorter wheelbase it looked a bit unstable.
The interior. The seats were glued from two side frames, seat and back. A block of timber was held in the vice, the frames clamped on either side and then the seat and back glued on with wood glue. The luggage racks were very fiddly! The same block of wood had a piece of 1mm thick plasticard glued on either side leaving about 1.5mm clear parallel with the top. A right angle line was drawn across the block and two brackets were then held either side by a bulldog clip. A second bulldog clip was used to hold the frame to the bearers whilst wood glue dried. I chickened out of adding varnish to them!
The side walls are made up of three layers of ply with plastic glazing sandwiched in place. These were sealed first with MDF sealer then had a couple of coats of antique pine varnish. The window frame layer was just dyed with a darker wood dye. The ends are two layers of ply. When gluing the layers together I clamped them to a granite worktop saver to ensure they were held flat.
The last picture shows the structure of the roof. The three cross members on the inside were slightly too long to fit between the walls, I reckon it would be a simple matter for them to be made slightly smaller in the kit to save a very fiddly operation with razor saw and chisel which was worrying in case of a slip.
Having made this one I think a train made up of several different types of this coach would look quite good.
Love it! Balcony coaches are my favourite, one of the reasons I love the Welshpool & Llanfair. It's spoiled riding trains indoors for me. I agree, a train of variants on the theme would be fantastic.
Thanks Simon,
yes, the WLLR is great and riding on the balcony one of the treats of life (but don't tell everyone!).
I fear this kit wouldn't find its way in to my collection, but you have made an excellent job of its construction an it would certainly look well with others of its kind.
I am planning a visit to Plateway Models stand at the LLangollen show.
3D printed door handles arrived from Jerry Irwin yesterday, each is in two parts, the T handle itself and the collar is separate. I used gold gilding cream to colour them. I had to shorten the stub of one of each back to back pair to allow them both to fit snuggly either side of the coach wall then glued them in.
I eventually finished painting some figures earlier in the week. This guy was too tall for other items of rolling stock, by serendipity his hand is at the right height to hold the brake handle.
In case they would be useful to others I show here some of the jigs used in the construction:-
At top left. 2 roof jigs are provided to form the curve of the roof. I found them much easier to use by gluing to either side of a block of wood of suitable size.
Top right. A multipurpose block of wood of suitable thickness to glue the seats and to bend the handrails around (Clamping it in the vice to get them a tight fit, whilst the handrail was held down on the top surface with pliers). Gluing a piece of plasticard either side also served for forming the luggage racks.
At bottom left. I used the handrail part of this jig to get them to length. I added some extra holes to also use it as a drilling jig for the handrail mounting holes.
At bottom right. The kit includes a jig for spacing the sole bars at the correct spacing. I cut three slices from it to glue into the chassis.
You can rely on Jerry to supply jigs with his kits, nothing left to chance!
'Gold gilding cream' is new to me, unless it is similar to that used on picture frames.
It certainly looks good. I thought the door handle was a brass casting.Peter Butler wrote: ↑Sun Mar 12, 2023 4:32 pm 'Gold gilding cream' is new to me, unless it is similar to that used on picture frames.
Yes, gilding cream can be used for picture frame restoration etc. It is available in different colours. I first got some when I played with wood turning where it can be used to accent grain etc.
- gregh
That's a beautiful little coach. I suspect a similar looking one might appear on my railway soon.
Greg from downunder.
I acquired a 'job lot' of these, I think some of the colours may be useful for weathering? - If applied sparingly..gilfachphil wrote: ↑Sun Mar 12, 2023 5:58 pm Yes, gilding cream can be used for picture frame restoration etc. It is available in different colours. I first got some when I played with wood turning where it can be used to accent grain etc.
When I came to try to use them, they had dried-up considerably.
You wouldn't know what I could try as a solvent (to rejuvenate them) would you?
Phil,
have a look at the Liberon website. They say use turpentine or good quality white spirits,
Thanks Phil..
All I have to do now, is find them! - I think they have not moved here yet?
PhilP
PhilP
